Audi S3
This is the be all and end all of AU recall threads. i want the facts.
![]() I have 2 "Field Campaign" stickers on my car, and i was wondering what they referred to. The first has the Reference Number: SRCC215/Z dated 23/03/01 The second has the Reference Number: SRCC300 dated 06/08/04 anyone know what these numbers mean?
Formally Kia Chaser
Another one? Just do a search or go to the goverment recall site.
Kia Grand Carnival (2006) Silver, Grill Mesh, Tints, Sidesteps (with lights), Towbar, 7" Touch Screen DVD Tuner with intergrated GPS & Bluetooth, Roof Mounted Flip Down 15.1" LCD Screen, Reverse Camera - 184Kw HSV Clubsport R8 VY (2003) Black, 6sp Manual, Coulson Seats, Red on black interior, Pacemaker extractors, Twin 2.5" exhaust, Custom Red 20" VE GTS Rims, Custom Red Stitching
#3 | |||
Audi S3
HLC
Almost certain the second one 08/04 is for the steering rack studs to be spot welded for safety reasons I would also like to know what the first one is for? |
Audi S3
Vehicle Recall Search Results for FORD AU Series 1 & 2,Falcon Forte,Futura,Fairmont,Fairmont Ghia,Fairlane,LTD,FTE,Ute (1 June 1998 to 22 May 2001)
-------------------------------------------------------------------------------- Problem: Steering rack mounting stud may loosen Make: Ford Model: AU Series 1 & 2,Falcon Forte,Futura,Fairmont,Fairmont Ghia,Fairlane,LTD,FTE,Ute Variant: Date Range: 1 June 1998 to 22 May 2001 VIN Ranges: Status: Active Defect: Possibility that inappropriate servicing of steering rack retaining hardware may affect the integrity of the steering rack mounting stud. Overtightening of the steering rack mounting hardware may degrade the thread locking compound on the stud. Consequences: This condition may allow the stud to loosen. In extreme cases the stud may detatch from the crossmember. Corrective action: Ford dealers will apply a weld to the end of the stud to stop it coming out if loosened. Notif. Date: 17/06/2004 DOTARS No.: R04/075 Supplier Name: FORD Campaign No.: SRCC300 found one. the steering rack one. the only other recall was for ABS on the S2/S3 cars. but my car was out of the build range and the number doesnt match.
Audi S3
Vehicle Recall Search Results for FORD AUII, AUIII (Vehicles fitted with ABS) (5-6 Dec. 2001, 13-14 Dec. 2001, 29-30 Jan. 2002)
-------------------------------------------------------------------------------- Problem: Front brake failure Make: FORD Model: AUII, AUIII (Vehicles fitted with ABS) Variant: Date Range: 5-6 Dec. 2001, 13-14 Dec. 2001, 29-30 Jan. 2002 VIN Ranges: Status: Closed Defect: Under extreme braking vehicles built on the above dates may lose all fluid from the front braking circuit. Consequences: Extended braking distance due to loss of the front brakes. Corrective action: Ford dealers will replace the affected Bosch ABS control modules. Notif. Date: 11/04/2002 DOTARS No.: R02/025 Supplier Name: FORD Campaign No.: SRCC246A/B/C Just gotta find out what the 'field campaign' in 01 was.
Tickford Equiped
Always wondered what that Field Campaign sticker meant. I have one for the SRCC215 on 27/02/01. I have had the steering rack recall done aswell, but i dont have a sticker for it.
Genuine Tickford Equiped 1998 AU Fairmont Mods: ....... Dash mat & Air Freshener, does that count as a mod?????? Sports Exahust, Tickford Intake Snorkle, K&N Filter, NGK Plugs, Top Gun Leads TS50 Front Bar with Fog lights, TS50 Rear Bar. Injected LPG System, |
Tickford Equiped
just did a search on these forums. Typed in SRCC215 and it came up with the another thread about the steering rack recall. On the third page it mentions this code, and someone called ford and found out it was for the Throttle Cable Recall. To replace the rubber grommet or something.
Hope this helps.
Well I know I don't have the steering rack stud recall ... as I just pulled the buggers out and replaced the steering rack/power steer pump on Monday.
Tickford Equiped
Problem: Accelerator Cable Retention
Make: FORD Model: Falcon Variant: AU, AUII Date Range: October 1999 - January 2001 VIN Ranges: Status: Inactive Defect: Accelerator cable slides past grommet. Consequences: Sudden loss of power. Corrective action: Ford dealers will replace the level grommet on the cable. Notif. Date: 12/02/2001 DOTARS No.: R01/016 Supplier Name: FORD Campaign No.: SRCC215/Z Problem: Front upper ball joint retaining bolts torque. Make: FORD Model: Falcon Variant: AU Date Range: 1999 VIN Ranges: Contact Ford Customer Service Centre, phone 1800 333 306 of facsimile (03) 9359 8933. Status: Inactive Defect: Incorrectly torqued front spindle upper ball joint retaining bolt(s) results in bolt(s) becoming loose or failing. Consequences: Loss of steering control. Corrective action: Inspect and re-torque the front spindle upper ball joint retaining bolts. Replace any damaged bolts if required. Notif. Date: 31/05/1999 DOTARS No.: R99/079 Supplier Name: FORD Campaign No.: SRCC183 Problem: Front centre seatbelt insufficent belt adjustment Make: FORD Model: Falcon Variant: AU Date Range: 1998-1999 VIN Ranges: Refer Customer Assistance Centre Phone 1800 333 306, fax (03) 9359 8933 Status: Inactive Defect: Airbag warning label on belt prevents the seatbelt from moving freely through the adjustment mechanism. Insufficent adjustment to meet ADR 4/02 clause 6.1.2 requirements. Consequences: ADR non-compliance, front centre seatbelt does not have required range of adjustment to restraint occupant. Corrective action: Front centre seatbelt, tongue (including adjustment mechanism) replaced. Notif. Date: 31/05/1999 DOTARS No.: R99/080 Supplier Name: FORD Campaign No.: SRCC184
Tickford Equiped
Problem: Front suspension upper arm security
Make: FORD Model: Falcon, Fairlane Variant: AU Date Range: 1999 VIN Ranges: Refer Ford Customer Assistance Centre, phone 1800 333 306 or facsimile (03) 9359 8933. Status: Inactive Defect: Bolts securing the upper suspension arm to upper arm bushes affected by hydrogen embrittlement. Bolt failure causes upper arms to separate from the bush(es). Consequences: Loss of steering control of vehicle. Corrective action: Replace Right Hand and Left Hand front suspension upper arm assemblies. Notif. Date: 16/04/1999 DOTARS No.: R99/058 Supplier Name: FORD Campaign No.: SRCC176
#12 | ||
HLC was saying that the problems the steering rank becoming loose where between 1st June 1998 and 22nd may 2001. Just brought a auii yesterday manufactured on the 23rd May 2001, makes ya wounder if it too needs repaired? ONE DAY>really!
I used to be a Holden man, but thanks to this forum and driving a few XR's lately I changed my tune. So thanks all you guys out there who have added some really important information and helped me make the right decisions when purchasing. TNX |
#13 | |||
Drought Breaker
Its only a preemptive measure to limit liability. Thats just the 0.2 cents Ford had to say about it.
2002 AUIII XL W/- Custom Tray
ALL COUNTRY: SW Platt Mccann 5 Poster, GME 4706 7' Whippys, Uniden UH015SX UHF AND Scanner combo, Narva Taurus Bull lights, Hawk Grille, Series II Pursuit Side Skirts, Stickers on the back window and more eartags than a mob of cranky angus ![]() ALL GO: XR6 VCT donk and ECU NO MORE!! Now even MORE fun with 200kw XR8 and 5 speed, Tickford Cluster, 3.45 LSD, full custom twin system w/- 3" chrome angle cut tips ![]() |
#14 | ||
Its gone V
STOP POSTING ALL THESE DEFECTS IM SCARED..........................lol just kidding.
you people are all scaring me i havent got one sticker on my car and its a S1 and now im scared, i think i better hire a tandem trailer get the trusty/rusty old XF out and prey that it doesnt over heat on the way to bayford. once again im just kidding :yeees: |
#15 | |||
Audi S3
#16 | |||
As long as they are torqued to 80Nm you should be fine ... I went back and get them checked just after I had it done .... and they were fine.
#17 | ||
FORD ? Have manufacturing DEFECTS ? Nooooooooo!! LOL
#18 | ||
Flairs - Truckers Delight
You threadmined 9 years to troll?
Wow, step up your game son.
#19 | ||
meh ! was searching SRCC300
