Old 19-12-2010, 11:01 PM   #1
fast gt
Default Rally car motor
Im at a crossroads with my new rally car. Do i rebuild the motor thats in it, get a race motor thats been built or stick a AU motor in it. Just need some different opionons on the topic cheers . BTW its an eb2
fast gt is offline   Reply With Quote Multi-Quote with this Post
Old 20-12-2010, 12:10 AM   #2
yift
Technical Contributor: For members who share their technical expertise. - Issue reason: Countless sensible, accurate mechanical advice on all things Falcon and Territory.
go for a ba motor modded, will rev hard and fast and produce better torque.
yift is offline   Reply With Quote Multi-Quote with this Post
Old 20-12-2010, 12:17 AM   #3
my_gxl
Unintended Perfectionist
my_gxl's Avatar
boss 260 in it
my_gxl is offline   Reply With Quote Multi-Quote with this Post
Old 20-12-2010, 12:19 AM   #4
TheInterceptor
Cruising...
TheInterceptor's Avatar
Bugger ba, go bf if you can, if you can't or if its not posible (computer control complications?), au is the goods.
157kw of dirt munching power....
FBT '98
BA XT '04
F100 4x4 '82
Subaru Outback '02
TheInterceptor is offline   Reply With Quote Multi-Quote with this Post
Old 20-12-2010, 01:32 AM   #5
mik
mik's Avatar
another vote b series, but maybe a dedicated lpg 6, i seem to remember reading they have stronger rods and higher compression? may be some one can confirm?
Old 20-12-2010, 12:07 PM   #6
yift
mik yes you are right on that one.
Old 20-12-2010, 01:05 PM   #7
makattkd
RallyNav
Are you racing in a particular class? as you will find most CAMS events require the original type of block and same number of cams/valves for eligibility..
That said if your doing AMSAG go a BA Turbo conversion :p
makattkd is offline   Reply With Quote Multi-Quote with this Post
Old 20-12-2010, 01:48 PM   #8
fast gt
I live in adelaide so no amsag here :(. I wish i could put a ba motor in it,but not allowed.I went and saw a guy that races e series salon cars and he is going to do a motor for me and brand new box for 3500 Thankyou all for your opinions
Old 20-12-2010, 06:27 PM   #9
ebxr8240
Performance moderator
ebxr8240's Avatar
EB motor with AU internals..Esp if N/A ...
E.B head with AU valves and cam gear..Is an option with larger ports, lighter valves from A.U .. The AU valve guides will need to be fitted..Which should be replaced anyway..
I guess you can't get away with latter model manifold ??
Raise compression to around 10 to 1..
Lighten pistons and balance assembly..
Windage tray in sump with crank scrapers to keep oil off crank and oil in sump...
An MSD A6L2 or similar ignition box...If legal ??
Daily driver GTE FG..
Old 20-12-2010, 06:58 PM   #10
Melz
Melz's Avatar
Depends what class you want to do... not all rally classes have a 'free for all' on what you do with the car. Check regulations first
Melz is offline   Reply With Quote Multi-Quote with this Post
Old 21-12-2010, 08:43 PM   #11
fast gt
They have just started a new class where you can put a late model motor into a older car say for instance an sr20 into a 180b
Old 22-12-2010, 06:35 PM   #12
Melz
Melz's Avatar
That would be off tap
Originally Posted by Jeremy Clarkson
“The Americans lecture the world on democracy and then won’t let me turn the traction control off!”
Old 23-12-2010, 08:42 PM   #13
fast gt
There is a 180b with an sr20 turbo in it at our club he uses it in rally sprints the thing is nuts
