Old 15-11-2005, 09:36 PM   #91
CAMS290
trying to get a leg over
CAMS290's Avatar
Originally Posted by Lowride260
Phasing is very important not right can cost you lots of torque/power also now by re phasing the existing cams Chris knows were the right phasing the new cams should be at, when these are avaliable you should see some execellent grunt out of these motors. It sounds good having bigger cams but the wrong phasing makes them pointless as the ones avaliable at the moment have found out.
Interesting.....Are they adjustable with vernier gears ?? or are they reground with the same lift/duration ???
I thought that they wernt adjustable
Cameron
CAMS290 is offline   Reply With Quote Multi-Quote with this Post
Old 15-11-2005, 10:17 PM   #92
Bossxr8
Peter Car
Bossxr8's Avatar
I'd like to know the same thing, can the cam timing be adjusted with a set of vernier gears like some Jap turbo cars. I've seen a few RB Nissan engines pick up 4-5kws with this alone.
Old 15-11-2005, 10:49 PM   #93
CAMS290
CAMS290's Avatar
I believe there are some gears available in the states or maybe the original gears can be slotted ?????
Cameron
Old 16-11-2005, 12:55 PM   #94
ALS008
I'm BOSS
ALS008's Avatar
Location: Where all Fast Fords are From, Northern Melb.
Just like to put in my Congrat's to Chris on the PB - and Record!!! Awesome stuff there and more to come no doubt.:Up_to_som
Spent some time at the Bluepower Shop yesterday and it has given me the erge to pursue a slot in the 12's Club. "Its only and exhaust away" as Chris put it......
So I'll be back - as a great man once said. :
~Big Al
====Past Rides====
'04 BA XR6T 5spd T5: Nizpro Tuned, Valve springs, CIA, Injectors, 256RWKW
'04 BA XR8 4spd BTR:Bluepower Tuned, BPR CAI, Big Boy exhaust, Hi Stall, 4.11s, 248RWKW PB:13.2@105mph
'92 EB Fairmont GHIA 5.0LT 5spd T5:Stock with a cat back exhaust.
'06 BF Fairlane GHIA 230Boss ZF 6spd: BPR CIA, cat back Exhaust.
====Present Ride====
'10 FPV GS Ute ZF 6spd:#108. With all the fruit.
ALS008 is offline   Reply With Quote Multi-Quote with this Post
Old 16-11-2005, 02:05 PM   #95
Craig
RIP Craig - 13/11/08
Craig's Avatar
~Big Al
Should I book you in big man???????
Craig is offline   Reply With Quote Multi-Quote with this Post
Old 18-11-2005, 12:19 PM   #96
ALS008
I'm BOSS
ALS008's Avatar
I will let you know guys...... not to long tho!!!
====Past Rides====
