Old 13-10-2012, 01:07 PM   #181
MonsterFG T6
Default Re: Wheels That Fit Brembo Brakes
Originally Posted by fusion_m8
WOW... I never knew the BA/BF or FG could fit 9.5 wide rims at the rear? In that case, will 265/275 tyres fit on the rear too?
FG can fit 10 inch wide rim, I had fittted 20x10/275 not much space left though.
MonsterFG T6 is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2012, 01:31 PM   #182
MonsterFG T6
I have bought another set of wheels from ozzy tyres they are called "Initial D" so I couldnt find any info whether they can clear 4 pot Brembo's. Here is the pic of the wheels in question...Its a 19x8
Old 13-10-2012, 01:44 PM   #183
05_ENFORCER
05_ENFORCER's Avatar
Offset?
2015 FGX XR8 5.0 S/C 645 RWKW
05_ENFORCER is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2012, 04:05 PM   #184
MonsterFG T6
Originally Posted by 05_ENFORCER
Offset?
I have no idea mate, I think its probably same offset as stock FG again not sure, I forgot to ask them and on their website offset isnt listed so I was hoping someone on the site actualy has the same wheel's and not sure if they are open now I have got u number saved when they called about tyres(they supoosed to deliver Pireli P zero but they "run out") of them so they delivering them with Pireli Rosso instead. Friend of mine said he doubt they can clear Brembo's so I want to make sure otherwise I'll have to go with DBA's set up.
Old 13-10-2012, 04:22 PM   #185
05_ENFORCER
I reckon you will need +33 or higher offset to clear the Brembos
Old 19-11-2012, 05:18 PM   #186
Stagg
Stagg's Avatar
Have 19" GMAX Avant Garde wheels on my Fairmont, plenty of clearance here!
DAS IT MANE
Stagg is offline   Reply With Quote Multi-Quote with this Post
Old 03-12-2012, 02:02 PM   #187
BAGT514
BAGT514's Avatar
My Zumbo Vaiges have +30 and has plenty of clearance. It's the profile of the center & spokes that makes the difference
Official member of the OCMD Club
"Semi - Silhouette" 2003 BAGT #514
2007 GT500 factory supercharged motor built!
Sensation Blue 2011 FG GT-P # 101
KPM Streetfighter Monster
5.2lt MMR short motor / Stage 3 MMR heads / Boss 302 Exhaust cams
FR20 Simmons / Tein Coilovers / Eaton Tru Track / Very scared 305/25/20" Nitto Invo's
ZF fitted with a NIZPRO Stage 2 input shaft & Excedy Clutches
http://www.fordforums.com.au/showthread.php?t=11408502
BAGT514 is offline   Reply With Quote Multi-Quote with this Post
Old 03-12-2012, 02:23 PM   #188
05_ENFORCER
That's a nice looking rim
Old 03-12-2012, 08:57 PM   #189
marcyeo
Regular member
marcyeo's Avatar
And very cheap too on ebay..
CURRENT
2013 335 GT - BMC twin filter, Herrod IC, injectors, fuel pump, oil breather, SC pulley and balancer, X-force 2 1/2" cat back with high flow cats = 453rwkw. Thanks to Lee at Real Dyno performance.
OLD
2010 FPV F6 FG - Herrod CAI, Pedders extreme XA's, Whiteline fr & rear swaybars, PWR stepped IC, injectors, turbo dump pipe with Venom cat, Herrod piping kit = 350rwkw
marcyeo is offline   Reply With Quote Multi-Quote with this Post
Old 03-12-2012, 10:38 PM   #190
comagutsa
Pethy FG XR8 Ute
comagutsa's Avatar
anyone know if Varrstoen 2.2.2s will fit over brembos
size 19's 9.5 +30 offset
FG XR8 Ute 2010 Nitro,
Mods so far: Herrod CAI, headers, Ballistic cats, Cat back Manta dual 2.5" with X pipe and hotdog mid section, Mellings oil pump, Summit racing 60mm twin throttle body, and Yella Terra plenum
Powerbond 25% under drives, Sports bar,
now fitted with Koya Inox R1's, the rears are 20x10 with a 40mm offset and the fronts are 20x8.5 with a 35mm offset
total of 285.5 rwkw and 642nm
when Herrod cams in 290rwkw
GSXR 750K7 with goodies, dyno'd 136rwhp,
10.567sec for the strip
comagutsa is offline   Reply With Quote Multi-Quote with this Post
Old 03-12-2012, 11:20 PM   #191
05_ENFORCER
They look as if they will based on current data and other posters.
I thought + 33 offset was the minimum but +30 will fit based on BAGT514 comment.
As always you need to experiment.
Old 03-12-2012, 11:33 PM   #192
comagutsa
Pethy FG XR8 Ute
comagutsa's Avatar
yeah im hoping someone has them on theirs as i dont really want to buy them and find out they wont at a later date
the 19's 10.5 come in a +34 offset but i think they might be to wide for the front
Old 04-12-2012, 12:29 AM   #193
kempy311
BEN
kempy311's Avatar
No more modding hahaha
My Thread. The new whip: 2014 FGX XR8 Auto in victory gold. Mods : BMC air filter, 1500cc injectors, Walbro 485, 58mm kpm snout, kpm intercooler, 35% front and 20% rear tint, pedders supercar coilovers, whiteline sway bars, Phillips HIDs, lenso d1r wheels.
331rwkw.
12.7 sec stock as a rock with a passenger.
Now with 620rwhp ready to run the 10
built zf, built tailshaft, corn juice all to come.
The old rig: 2008 FG XR8 Auto in dash green with a tonne of mods to make 311rwkw.
kempy311 is offline   Reply With Quote Multi-Quote with this Post
Old 04-12-2012, 03:31 AM   #194
comagutsa
Pethy FG XR8 Ute
comagutsa's Avatar
so want to buy someones brembos they have up atm ..hey enforcer haha but have to watch money atm
Old 04-12-2012, 11:40 AM   #195
05_ENFORCER
They won't get any cheaper bro!
Old 04-12-2012, 02:07 PM   #196
timmeh6402
Domination
timmeh6402's Avatar
Hey I just want to find out what would be a minimum clearance between the caliper and spoke? I have about 1-3mm of clearance is this acceptable or not? http://i1006.photobucket.com/albums/....jpg%5B/IMG%5D
2012 MK2 FPV 335 GT
coyote 335 bitches
timmeh6402 is offline   Reply With Quote Multi-Quote with this Post
Old 04-12-2012, 03:06 PM   #197
data_mine
GT-P With An Ego
data_mine's Avatar
unless you wheels are flexing/wobbling the clearance won't change.
Note to keep you wheel bearings in good condition.
1998 DL LTD in Sparkling Burgundy, daily, mild 5.0L, high end stereo, slow'n'thirsty - 138.8rwkw.
2006 BF GT-P in Ego, 5.8L all alloy, Kenne Bell 2.8HLC, Nizpro Stage 2 ZF - 440rwkw.
2008 SY F6X in Silhouette, stock for now nope.
Ford Performance Club of ACT
data_mine is offline   Reply With Quote Multi-Quote with this Post
Old 04-12-2012, 03:19 PM   #198
timmeh6402
Domination
timmeh6402's Avatar
Dumb question the rim shouldn't flex or wobble when tight right? And my cars a big baby gets looked after very well !
2012 MK2 FPV 335 GT
coyote 335 bitches
Old 04-12-2012, 03:31 PM   #199
data_mine
GT-P With An Ego
data_mine's Avatar
you're right. the thing to look out for is the wheel bearing, if that is worn the entire hub+rotor+wheel will be able to move relative the the caliper.
Old 04-12-2012, 03:31 PM   #200
kempy311
BEN
kempy311's Avatar
You will need quite a bit more then that because you have to think about the other set of pistons.
331rwkw.
Old 04-12-2012, 06:15 PM   #201
data_mine
GT-P With An Ego
data_mine's Avatar
the photo (which the link is broken, but easily fixed), shows what appears to be already a 4-pot Brembo in place.
Old 08-02-2013, 12:30 AM   #202
Saski
Saski's Avatar
So BF II xr6/xr8 18 inch wheels are not compatible with 6 pot brembos?
Saski is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2013, 12:54 AM   #203
comagutsa
Pethy FG XR8 Ute
comagutsa's Avatar
no they are not
Old 09-02-2013, 11:54 AM   #204
Wolfinsheepsclothing
preying on lions
Wolfinsheepsclothing's Avatar
these also fit-motegi racing mr122's in 8.5-9.5'' by 20'' they're now on me gs
2014 FG2 Falcon XR6 luxury in Black, - New toy 2022 HD Lowrider S 124hp/136flb's
Wolfinsheepsclothing is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2013, 01:42 AM   #205
DAN-427
THE BOSS
DAN-427's Avatar
Just fitted a set of brembos to my car tonight and the front calipers clear the rims by barely 1mm! Will this be an issue at all? I have driven the car and there seems to be no rubbing etc.
DAN-427 is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2013, 02:34 AM   #206
data_mine
GT-P With An Ego
data_mine's Avatar
Shouldn't be,the 18"s I race with have tiny clearance too, they've never caused a problem under the harshest conditions.
Old 23-02-2013, 09:55 AM   #207
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Yeah generally not but 3mm is what we prefer to be the minimum.
MATTHEW PEARCE
Phone 02 9609 1101
sales@racebrakessydney.com.au
www.racebrakessydney.com.au
Old 07-03-2013, 10:04 PM   #208
twr7cx
Member
twr7cx's Avatar
Very very very handy thread, thank you Race Brakes. I cam in here seeking information about retaining my current spare wheel, and was lucky to find the following:
Originally Posted by Lightning Strike GT View Post
BA XR 18 - yes
The only FORD (non FPV) wheel that will clear them is the ENKEI BA XR option series in 18 X 8
if you click the link and have a look at the Enforcer these rims definately fit over Brembos. (2005 Ba Mk2 option rims)
http://www.autoscene.com.au/products...i-xr8-enforcer
These - I had them wrapped in semis for track work - Brembo compatable
Current vehicles: MY12 Land Rover Discovery 4 TDV6, MY03 Land Rover Discovery 2 HSE Td5 off road modified and 1989 Mazda NA MX-5 toy car.
Previously: 1992 Ford EBII Fairmont, 1994 Ford EF Falcon XR6 supercharged, 2003 Ford BA Falcon XR6 Turbo 325rwkw, and 2002 Ford AU3 Falcon XR8 Pursuit 250 270rwkw.
twr7cx is offline   Reply With Quote Multi-Quote with this Post
Old 07-03-2013, 10:06 PM   #209
twr7cx
Member
twr7cx's Avatar
Has anyone tried ROH Modena the modular three-piece wheels in 19"? I currently have a set on my P250 with the Tickford twin piston calipers. i would like to upgrade the brakes but retain these wheels. Might see if I can find someone with Brembo's locally who would allow me to fit the wheels for clearance testing onto their vehicle.
Old 14-04-2013, 08:22 PM   #210
cz888
What's the best offset for 20" KMC Rockstars on a FG GT (4p Brembos)?
Can I do a staggered setup without touching the fenders?
cz888 is offline   Reply With Quote Multi-Quote with this Post
