18-01-2011, 10:25 PM | #1 | ||
Ford T3 Partsologist
g'day all would like some help to varify a N.O.S. crate engine that i have, i'm pretty certain its correct but would like some help to varify please any help would be greatfully appreciated - thanx
engine builder ADAM DOYLE, GT40P HEADS modified with Yella Terra gear date stamped july 02, didnt come with the Tickford throttle body was souvenired by a Ford employee
2002 Blueprint T3 TE50 Manual Koni Suspension # 161 T-Series Club of Australia - www.tseriesclub.org Last edited by Dingo; 18-01-2011 at 10:41 PM. |
18-01-2011, 11:08 PM | #2 | ||
not here much anymore
I havent heard of that engine builder before but that doesnt mean it's not legit.
What aspect of it are you trying to confirm?
RAM 1500
19-01-2011, 01:39 AM | #3 | ||
Miami Pilot
July 02 would be last of the AU3 XR8s - probably genuine then.
19-01-2011, 02:36 AM | #4 | |||
LOL JC your the reason why i'm trying to varify this engine, some time back you quoted that my engine would likely to be a 200kW and not a 220kW.
do 200kW have GT40P heads ? Quote:
2002 Blueprint T3 TE50 Manual Koni Suspension # 161 T-Series Club of Australia - www.tseriesclub.org |
19-01-2011, 09:27 AM | #5 | |||
RAM 1500
19-01-2011, 10:23 AM | #6 | |||
T3/Sprint8
19-01-2011, 11:42 AM | #7 | ||
Tickford
Is this the one that's been on ebay for $16k?
ED XR8 Sprint - 306ci SBF, GT40, Comp XE270, T5, 3.45 LSD AU T3 TS50 - 345ci SBF, AFR 185, Comp XE274, 2800 stall, ESS LE97, 3.45 LSD BA XT SZ Territory TS RWD TDCi |
19-01-2011, 11:43 AM | #8 | ||
What if it was a ute engine...
335 S/C GT: The new KING of Australian made performance cars.. |
19-01-2011, 01:25 PM | #9 | |||
yup thats the one - didnt sell it, had some stupid offers and wasnt pre-pared to give it away decided to keep it will post pics of it
19-01-2011, 01:29 PM | #10 | |||
was the 200kW GT40P heads modified with Yella Tera bitz.
19-01-2011, 01:30 PM | #11 | |||
RAM 1500
19-01-2011, 11:12 PM | #12 | ||
here's som pics of the crater ive made a couple of errors in my opening post to this thread, the engine builder is Sam Doyle and the date stamp is June 02
25/06/2002 07/12/2000
2002 Blueprint T3 TE50 Manual Koni Suspension # 161 T-Series Club of Australia - www.tseriesclub.org Last edited by Dingo; 19-01-2011 at 11:29 PM. |
19-01-2011, 11:23 PM | #13 | ||
rexnet
its ok
19-01-2011, 11:52 PM | #14 | |||
Miami Pilot
Even the 200s did get RRs, but they would have been 1.6 ratio, whereas the 220s got 1.72 ratio. Though the wrong rcokers have been found on even T3 motors! But the 220 Auto sticker (ID 320 GA) is probably the biggest clue as to what this is and what it was destined for.
20-01-2011, 12:14 AM | #15 | |||
wouldn't know where to start at Ford as i have no contacts anymore, thats why im hoping here can help
2002 Blueprint T3 TE50 Manual Koni Suspension # 161 T-Series Club of Australia - www.tseriesclub.org Last edited by Dingo; 20-01-2011 at 12:20 AM. |
20-01-2011, 12:25 AM | #16 | ||
Miami Pilot
Is there any way you can check the roller rocker ratios? If they're 1.72, then it's highly likely they're the 220 engine.
20-01-2011, 12:40 AM | #17 | |||
20-01-2011, 08:57 AM | #18 | |||
Miami Pilot
Here are the engine specs for the 220 from the FPV site (http://www.fpv.com.au/theheritage/fa...onxr8-220.aspx): Engine AUII XR8 220kW: Windsor 5-litre V8, OHV, electronic multi-point fuel injection, 9.4:1 compression, reworked Explorer GT40P cast iron crossflow heads, roller rockers, special camshaft, cold air intake, low restriction twin exhaust system, 70 mm throttle body, oil cooler, match-ported inlet manifolds,upgraded fuel pressure regulator, 220 kW@5250rpm, 435Nm@4,000rpm.
20-01-2011, 03:46 PM | #19 | ||
thanx JC i'll use this info to do some checking with what i've got here, so these engines were used in AUII & III XR8's. Would they have used them in utes as well you reckon ?
20-01-2011, 03:59 PM | #20 | ||
found some info on a quik id of yella terra rockers used for 200's & 220's - 1.6 has a circle with a # 6 with in the circle & 1.72's have the circle with no number with in.
Info from Yella Terra (03) 9555 5522 so it's likely this engine has all the right signs to be a 220kW
20-01-2011, 08:34 PM | #21 | ||
see the orange paper decal (this orange decal is also on the oil filter and RH R/Cover at the rear) 1D320BA and maybe re-engineered to a 1D320GA as to the purple/mauve decal, could that be the engine ID, like how the XW XY XA D block GT engines had them example CK617J1 ?
21-01-2011, 01:05 AM | #22 | |||
19-01-2014, 12:01 PM | #23 | ||
MoPar man 11
Ive got the same sticker JM 1D320BA code on my AU11 (Nov 01) "FULLY OPTIONED AU111 XR8 UTE.......
Is that cool ?? |
19-01-2014, 12:27 PM | #24 | ||
MoPar man 11
19-01-2014, 12:27 PM | #25 | ||
MoPar man 11
and its a UTE..... UTE UTE UTE
22-01-2014, 07:07 PM | #26 | ||
Miami Pilot
AU3 Utes only ever got the 200kw motor......Pursuit ute excepted
22-02-2014, 06:00 PM | #27 | ||
Sales Representative
