#31 | |||
Sent from my SM-G986B using Tapatalk |
#32 | |||
#33 | ||
My setup is in 2013 SZ Petrol Territory, the PCM doesn't have the hardware to control boost. I run a seperate Eboost Street boost controller, however that's not the point I made.
I run a 15psi turbosmart actuator. With that actuator the duty cycle is around 45% to get a commanded 21psi boost. So with this setup I get around 9psi of boost control (15-24psi) which is what I want. The turbo runs out of efficiency @ 24psi boost, no point wringing its neck past this point.
2021 BMW M550i in Black Sapphire Metallic.
11.52 @ 120mph stock |
#34 | |||
#35 | ||
Are you expecting the small 3576 to do the same job as a GTX3582R, Gen 2, 84RS, PTE or BW by simply changing the actuator? What are you getting done to the wastegate port? And what about the flapper valve?
Just change the turbo and be done with it. Expect around a 100rwkw increase changing the stock 3576 with a GTX, PTE or BW turbo.
#36 | |||
#37 | ||
Will it blow, will it not, who knows. Anything modified is higher risk.
Personally boost levels seems excessive and unnecessary with your set-up, but if you are happy with it who cares what I and others think. |
