13-08-2020, 01:52 PM | #721 | |||
Critical Thinker
"the greatest trick the devil pulled, is convincing the world he doesn't exist" 2022 Mazda CX5 GTSP Turbo 2018 Hyundai Santa Fe Highlander 1967 XR FALCON 500 Cars previously owned: 2021 Subaru Outback Sport 2018 Subaru XV-S 2012 Subaru Forester X 2007 Subaru Liberty GT 2001 AU2 75th Anniversary Futura 2001 Subaru GX wagon 1991 EB XR8 1977 XC Fairmont 1990 EA S Pak 1984 XE S Pak 1982 ZJ Fairlane 1983 XE Fairmont 1989 EA Falcon 1984 Datsun Bluebird Wagon 1975 Honda Civic |
13-08-2020, 02:04 PM | #722 | |||
Cabover nut
I live offgrid and have found you can normally get everything which will power 12 24v devices. But my ASUS eep has this weird 18v power supply with a unique power plug no one sells so use this for said duties. Powering a frig is the hardest thing to reasonably achieve with solar/battery unless to are moving most days.
13-08-2020, 03:09 PM | #723 | |||
Rob
UA2 TREND 4WD BI TURBO |
13-08-2020, 03:11 PM | #724 | ||
hahaha, I got banned from Caravaners Forum for a month Prydey - too political apparently
13-08-2020, 03:25 PM | #725 | ||
Cabover nut
Yes and why its hard to find the odd square plug adaptor, Its technically not a laptop, 18v mate.
13-08-2020, 03:36 PM | #726 | |||
Critical Thinker
https://www.goalzero.com/shop/last-c...power-station/
13-08-2020, 03:43 PM | #727 | |||
Cabover nut
What the Yanks call Jackery's, shows the ones you linked here just gotta watch what you use them for. The biggest problem with them is recharging them as via power they are slower to recharge than via a larger solar panel due to a panel supplying a much higher boost rate (with no controller) than the regulated power coming in from AC. I can recharge mine in a couple of hours using an unregulated 64W Canon solar panel, where as I have used a 240v regulated socket (at a motel) to recharge, with it taking something like 6 hours. Note.. the MPPT built in controller can regulate the boost charge from a unregulated solar panel, hence why they are more efficient at recharging than mains power. Normally for anything else, never use a unregulated solar panel over 40W.
13-08-2020, 03:52 PM | #728 | ||
Critical Thinker
Well the laptop is an occasional item, the battery will mainly power a small waeco fridge, camera batteries and phone and a usb light. But getting the right unit is the thing Im having trouble with. I dont want to overkill the spend but I dont want to underdo it either.
I do intend on getting a portable solar setup though. So if Im off grid I dont mind setting that up and charging during the day while I still use the battery. My laptop is a 17" HP unit. Im assuming its 18V. So I was hoping either the Goal Zero unit or can I get away with a smaller unit like this? https://itechworld.com.au/collection...-power-station
"the greatest trick the devil pulled, is convincing the world he doesn't exist" 2022 Mazda CX5 GTSP Turbo 2018 Hyundai Santa Fe Highlander 1967 XR FALCON 500 Cars previously owned: 2021 Subaru Outback Sport 2018 Subaru XV-S 2012 Subaru Forester X 2007 Subaru Liberty GT 2001 AU2 75th Anniversary Futura 2001 Subaru GX wagon 1991 EB XR8 1977 XC Fairmont 1990 EA S Pak 1984 XE S Pak 1982 ZJ Fairlane 1983 XE Fairmont 1989 EA Falcon 1984 Datsun Bluebird Wagon 1975 Honda Civic Last edited by blueoval; 13-08-2020 at 03:58 PM. |
13-08-2020, 04:14 PM | #729 | |||
Cabover nut
Just an example....Some of those little camping frigs might consume 5 amps per hour, cycle on and off for upto 16 hours a day/night depend on ambient temps. At 80amp/h from 100amp/h deep cycle LiPo 80% discharge and that just the frig. Something not possible with a lead acid battery bank. Like others have said, you need to work out exactly what you might use and base your battery bank/ solar array to be capable to recharge the storage capacity then allow extra for cloudy wet days when the panels are deeply shaded. Most appliances have there power ratings listed. NB your laptop is probably like Pyrdey said a 19V unless its a goofy 12V, 18V EEpc or there is a 21V one floating around I've seen.
13-08-2020, 04:21 PM | #730 | |||
Critical Thinker
I will probably get a small Dometic type fridge for the types of off grid camping I do. Probably better off getting that first then working out all my appliances and getting a battery to suit.
13-08-2020, 04:27 PM | #731 | |||
Cabover nut
yep work out your power consumerables (is that a word) first.
13-08-2020, 04:28 PM | #732 | ||
Rob
Haha, really? Not that you'll miss much
13-08-2020, 06:21 PM | #733 | ||
Critical Thinker
Been reading up on the Wacaco Nespresso pod coffee unit Rob and the reviews arent great. Can you provide your review on it? Need to know if its worth getting or not. Anaconda are selling them for $56 at club prices.
Otherwise I'll just use the ROK unit Ive had.
13-08-2020, 07:26 PM | #734 | |||
Rob
I'm happy with my nanopresso, and have bought the pod adapter as well, but it's not as solid as what you already have. The downside is ones like yours need a bench of some sort. What I have is very fiddly as well. There is one that is rechargeable and has a motor instead of a pump but I can't remember the name of it. Brother just bought a Flair one. Similar process to the Rok. If I had my time again I wouldn't have bought the nanopresso... Not saying it's bad, just not as cheap as first thought once all the extras were bought (bigger baskets, water container, tamp, pod adapter...)
13-08-2020, 07:41 PM | #735 | ||
The Terrain Tamer
Early tech here in Aus atm, but there is a lot of noise about 48V battery systems in caravans etc now...
https://www.safiery.com/mega-240v-power-RV-48V-lithium
Current Ride : A Ford owned D3... |
13-08-2020, 09:53 PM | #736 | |||
Critical Thinker
I think I'll stick with the ROK. Ive had it for years just never used it much.
13-08-2020, 09:58 PM | #737 | |||
Rob
The pumping action is pretty good. If it's too hard you just grind the beans slightly more coarse. But yeah, don't buy one if you have a Rok already.
14-08-2020, 02:31 AM | #738 | ||
BLUE OVAL INC.
I cant fathom a discussion about coffee machines in the camping thread, harden the **** up ladies and grab yourselves a billy and jar of Nescafe..
As for the fridge, considered a 3way which will run on LPG? The key to maintaining appliances on 12v isn't about how much reserves you have, its about how much generation you need to bring it back up as quick as possible. |
14-08-2020, 05:46 AM | #739 | ||
in the Victorian COVID thread, idiots from interstate were posting what I thought was inappropriate stuff abut Victoria so I climbed into them - nek minit BANNED
I am debating whether I will actually go back - it doesn't add much value to my life |
14-08-2020, 05:48 AM | #740 | |||
14-08-2020, 05:50 AM | #741 | |||
I do have a 40ltr Engel in the back of the Ranger, I plug in a portable 250w solar panel to keep the battery at its peak |
14-08-2020, 08:09 AM | #742 | |||
Cabover nut
1st world problem. Gas or Kero frigs are they only real way to achieve true offgrid food storage. LONG TERM. Unless you are prepared to lug around huge solar arrays with matching banks. Little top loading frigs in the back of your car are impossible to live with full time.
14-08-2020, 08:29 AM | #743 | |||
Rob
Not relevant to off grid discussion but this comes with me whenever I have access to power. I don't care what other people think is right or wrong or 'proper' camping.
14-08-2020, 11:58 AM | #744 | |||
Critical Thinker
May as well fill the billy with dirt and sift the remains through a sock! As for the fridge and battery setup. Been talking to the mrs on what we want and need. Plan is to get a Avan camper (the A frame units) with kitchenette etc all built in. If thats the case, they come with AGM battery, a/c, lpg and HWS built in, negating the need for a portable setup. So I may hold off for now if that is the direction we will take in the next few months. The information in this thread has educated me a lot though.
"the greatest trick the devil pulled, is convincing the world he doesn't exist" 2022 Mazda CX5 GTSP Turbo 2018 Hyundai Santa Fe Highlander 1967 XR FALCON 500 Cars previously owned: 2021 Subaru Outback Sport 2018 Subaru XV-S 2012 Subaru Forester X 2007 Subaru Liberty GT 2001 AU2 75th Anniversary Futura 2001 Subaru GX wagon 1991 EB XR8 1977 XC Fairmont 1990 EA S Pak 1984 XE S Pak 1982 ZJ Fairlane 1983 XE Fairmont 1989 EA Falcon 1984 Datsun Bluebird Wagon 1975 Honda Civic Last edited by blueoval; 14-08-2020 at 12:21 PM. |
4 users like this post: |
14-08-2020, 12:10 PM | #745 | |||
14-08-2020, 12:23 PM | #746 | |||
Critical Thinker
To each their own.
14-08-2020, 12:25 PM | #747 | |||
Rob
Camping to me isn't some competition as to who is more genuine or authentic. Just get out and enjoy the country. And to clarify, never camped in a caravan park except in halls gap, and plenty of space there with no neighbours.
UA2 TREND 4WD BI TURBO Last edited by prydey; 14-08-2020 at 12:39 PM. |
14-08-2020, 12:33 PM | #748 | |||
Cabover nut
Hows that serenity.
14-08-2020, 12:37 PM | #749 | |||
Rob
Not sure if you are planning to tow with your subie (if you still have it) but some cars are limited with how much they can have on the ball so check that out too... I know avans don't weigh much so should be ok on that front but always cheaper to check everything out first.
14-08-2020, 12:44 PM | #750 | |||
Cabover nut
