el runs on gas wont run on fuel. fuel pump runs & full tank
are the injectors getting a pulse ?
can pick up a pulse lame real cheap and unplug an injector and plug in the diode lamp to see if injectors are getting pulse think i paid under $20 for mine and turned out to be the problem , then had to work out where and why they wernt getting the pulse from the ecu , think it was a bad connection some where but cant remember as was quit a few years back
yes still (as money n time permit) doing the rebuilding the zh fairlane with a clevo 400m 4v heads injected whipple blown with aode 4 speed trans to a 9" ....... we'll get there eventually just remember don't be afraid to try something new. Remember, amateurs built the Ark...Professionals built the Titanic! I have taken up meditation... at least it's better than sitting around doing nothing !! |
could also be a fuel blockage and/or bypass valve stuck open so rail isnt getting pressure to the injectors
Custom user title
Just check you have 12v at the injectors when running on petrol. Used to cut the power on gas. . Most likely wire has been knocked of the relay check the loom, most likely spliced near the idle speed control solenoid ( as this needs 12v on both fuel and gas)
