20-01-2022, 07:33 PM | #601 | ||
New ELM arrived today, but still having the same issues..
Though I've got it working though by flipping the high and mid wires around and running full speed. Doing a dump on my FGX dash currently, when its done i'll go pull the GT-F dash out of the car |
20-01-2022, 07:37 PM | #602 | ||
Away on leave
Whatever works, I say!
20-01-2022, 07:39 PM | #603 | ||
20-01-2022, 07:41 PM | #604 | ||
Away on leave
Oh, I guess we will talk again in a few hours! (ha ha)
20-01-2022, 07:44 PM | #605 | ||
20-01-2022, 07:47 PM | #606 | |||
How tall a step it is from here to adding stuff here and there, eg display a small engine diagnostics menu like many newer cars have, and successfully flashing that modified firmware back into it successfully? Steering Wheel Controls could be implemented to control the menu as well.....the list goes on.
testerPresent Diagnostics & Software | Github Profile Jakka351 | Fg Falcon Git Repo | email:jakka351@outlook.com |
20-01-2022, 07:48 PM | #607 | ||
Away on leave
Yeah, I know, it's slow, sorry...
For the cool things my software attempts, it doesn't need a great deal of speed... And for the limited use stuff (like getting 'that' part of the firmware) once it's done, we never have to do it again. I know though, it's a bit annoying. |
20-01-2022, 07:50 PM | #608 | ||
I think it.will work.already without modification.
20-01-2022, 07:52 PM | #609 | |||
This first run, was just going to be a test |
20-01-2022, 07:53 PM | #610 | ||
Away on leave
Ha ha, Jakka... I get it as 406! That's what you get when you're using Window Calculator with a mouse! And the Mk1 firmware is using all of the 256KB of flash it has available, so there's no "adding" to it - only small patches are realistic.
20-01-2022, 07:59 PM | #611 | |||
20-01-2022, 08:05 PM | #612 | ||
Away on leave
The biggest problem with the Mk1 (other than the ELM not being up to the task, due to the high speed of the data extraction's routine) is that it's not designed to be "updated" while it's in the car. You need to get into the programming mode by powering up the unit (from OFF, totally OFF) while sending in a "denial of service" type attack on it! Your car will not like it, unlike the EEPROM (and RAM) stuff I got working on it.
20-01-2022, 08:24 PM | #613 | |||
After I get a handle on reading the EEPROM with socketcan I will try for the deeper stuff.
20-01-2022, 09:07 PM | #614 | ||
Laptop went to sleep, starting the dump again.
Sorry |
20-01-2022, 09:15 PM | #615 | ||
Away on leave
Lol!
20-01-2022, 09:34 PM | #616 | |||
Silly me.
Now got an error, will start again :( Quote:
20-01-2022, 09:36 PM | #617 | ||
Away on leave
Hmmm, maybe it's best not to do all 5 at once... You did get the one part we need (5000-10000)...
20-01-2022, 09:42 PM | #618 | ||
20-01-2022, 09:44 PM | #619 | ||
Away on leave
From what I understand (latest) EXE is the same in the GTF as it is in the normal FG2.
It's the SIGCFG that's different (5000-10000). |
20-01-2022, 10:00 PM | #620 | ||
Ahh I understand the naming of your buttons now.
I'll just dump the signal config then for you now, that one doesn't take long. Just so you know, last time I had it connected to forscan AR79-14C025-AB was the 2nd boot loader AR79-14C026-AH was the strategy BR29-14C318-AA was the signal config |
20-01-2022, 10:04 PM | #621 | ||
Away on leave
Ha ha! I know, right - that BR one is new... 2011, where everything else is Terry SZ numbers 2010.
20-01-2022, 10:28 PM | #622 | ||
Away on leave
Thank you Superb! That's awesome!
https://github.com/Jasoroony/Ford-Fa...n/extracted_fw The firmware converted over perfectly - and I can see the magic number (at the end) is correct - so I've uploaded it to github. I'll be checking out the differences soon! |
21-01-2022, 08:41 PM | #623 | ||
Away on leave
The question is... Does it work? Well, after fighting Forscan for a few hours (seems it doesn't necessarily like programming firmwares in devices that didn't come out of your car - I had to revert some saved config files to get firmware programming back!)... Yes, it does work:
I stuck a slightly better [glare wise] picture in there. And yeah, that Cluster is made up from spare parts from a Terry SZ, a Mk1 G6E and a Mk1 5.0 FPV... All the really good stuff ended up in my car, but I had enough nice stuff left over to make a spare MKII Cluster |
5 users like this post: |
21-01-2022, 08:53 PM | #624 | ||
You might wanna slow down, that's a pretty high speed to be travelling in your lounge room.
25-01-2022, 09:38 PM | #625 | |||
25-01-2022, 09:44 PM | #626 | ||
Away on leave
Yeah, I thought of that about 2 minutes after I had posted... And I checked. And I couldn't find any in the extracted firmware with either the real number, or the number multiplied by 4. And I'm not even sure your description of that is true, the cluster is a gateway, so it can transmit (some of) those in that function.
25-01-2022, 09:45 PM | #627 | ||
Away on leave
White LEDs
25-01-2022, 09:50 PM | #628 | ||
Away on leave
What may also make your head hurt (it does mine) is the FGII signal configuration doesn't contain the CAN IDs that control the dials - unless it's the GTF specific file, which transfers data through the CAN bridge. They are well hidden.
25-01-2022, 09:57 PM | #629 | ||
Away on leave
Oh, and 0x720 is there - and it "just" knows to add 8 for replies - so you won't find that one.
25-01-2022, 10:06 PM | #630 | |||
Looks pretty cool but you don't want to get a speeding ticket so be careful..
Pew. pewpew. Quote:
Thread Tools | |
Display Modes | |
