17-03-2024, 07:30 PM | #1861 | |||
19-03-2024, 10:39 PM | #1862 | ||
Regular...with metamusal
Hi Legend, how have you been?.
just wondering if you can tell me what this item is suitable for as the listing says Fg Fgx - Sx Sy Sz Ambient Air Temperature Sensor. Part number - 8R2Z12A647 AA Many Thanks |
19-03-2024, 11:04 PM | #1863 | |||
That part is the little ambient ait temp sensor that sits in the passenger underside mirror of FG to FGX Falcon and SY to SZ2 Territory. Is that the answer you were looking for? GT |
20-03-2024, 05:09 PM | #1864 | |||
Yes thank you GT. dunno why the seller put the SX bit in?. there was a previous question re BA/BF memory mirrors assemblies and i presume they are no longer available ?. keep looking after yourself. cheers [thanks again for your time] Ps. found another seller [ebay] claiming fits BA/BF/FG/SY/SZ!. same part number too. |
20-03-2024, 06:34 PM | #1865 | |||
BA BF never had the ambient air temp sensor in the mirror. |
20-03-2024, 08:45 PM | #1866 | ||
Hi GT, BA/BF did have the ambient temp sensor in the LH mirror. BA17683CP & BA17683EP had the sensor. BA17683DP - Did not have the sensor.
20-03-2024, 09:23 PM | #1867 | ||
21-03-2024, 12:18 AM | #1868 | ||
*SILVER SERVICE PILOT*
Hi GT, could you advise if the electric adjustable pedal boxes are different in any way between BA and BF Fairmont Ghia/Fairlanes please?
Robbos in Melbourne have both BA and BF in stock and reckon that they're different. I've fitted half a dozen to BA and BF cars over the years, but they've all been BF Fairlane pedal boxes, so I have nothing to compare to a BA power type. I do know that the Territory pedal box is completely different to BA/BF, maybe that's what Robbo is talking about? I might have to give him a call perhaps.
BUILD THREAD
https://www.fordforums.com.au/showth...71#post6891271 2006 Lightning Strike BF Fairlane Ghia...HIS 2024 Titan Grey Hyundai Tucson Highlander...HERS |
21-03-2024, 08:00 AM | #1869 | |||
From what I can work out yes there are different pedal boxes but the change was during BA not into BF. See if I can explain it below. In saying that I am only going by part number and not sure what the difference is, so if they are interchangeable or not I am not sure. From parts when you buy a pedal box it comes with the brake pedal. 1. 1/7/2002 to 30/4/2003: Auto Only BA2450H 2. 1/5/2003 on: Auto Only Plain Pedal BAF2450K 3. 1/10/2005 on: Auto Only Sports Pedal BAF2450E I think number 3 and 2 are the same except for the sports pedal pad, but not 100% sure. Below is all the BA BF Pedal Box combinations. BA BF Pedal Boxes.png Hope this helps.. GT |
21-03-2024, 08:53 AM | #1870 | ||
Gtlegend, any luck with a FG/FGX driver's window?
21-03-2024, 10:34 AM | #1871 | |||
BUILD THREAD
21-03-2024, 12:36 PM | #1872 | ||
23-03-2024, 08:03 PM | #1873 | ||
24-03-2024, 12:17 AM | #1874 | |||
UTILITY HOUSING - REAR AXLE, WITH M86 SERIES AXLE, TAG ID:8R29/G*, TAG ID:8R29/H*, TAG ID:8R29/J*, TAG ID:8R29/K*, TAG ID:8R29/L*, TAG ID:8R29/M*, TAG ID:8R29/N*, TAG ID:8R29/S* (2.73, REAR AXLE LESS LIMITED SLIP DIFF, 4 WHEEL ANTI-LOCK BRAKING SYSTEM OR REAR AXLE LIMITED SLIP DIFFERENTIAL, LESS ANTI-LOCK BRAKING SYSTEM OR 3.73) |
24-03-2024, 12:05 PM | #1875 | |||
thanks, but is it from an FG tho?. |
25-03-2024, 03:24 PM | #1877 | ||
30-03-2024, 09:23 PM | #1878 | ||
Hello GTLEGEND.
Could you be able to help me out on the part number and if they are still available. I'm seeking the air conditioning solenoid vacuum pack or vacuum solenoid for the AU2. 6 cylinder year 2000 car. Not Climate Control. Thanks |
30-03-2024, 11:10 PM | #1879 | ||
Are your referring to the heater box end or the dash control end?
31-03-2024, 09:03 AM | #1880 | ||
Good question.
I'm not certain. I was not aware there are two areas. |
31-03-2024, 09:49 AM | #1881 | |||
AU Heater Box.png AU AC Controls.png |
31-03-2024, 12:33 PM | #1882 | |||
I was referred back to this post today and I just realised, 18 months on, that I never came back to question the date you specified. I had the right part number so I think I just left it there. You put Feb 2009, but I'm guessing 2009 had to be a typo? Maybe? Can you check and come back with the date of the change over to the B-series stainless fuel rail. I'm assuming it should have been 2005 or 2006 maybe? And a Happy Easter / Chocolate day to you! |
31-03-2024, 02:41 PM | #1883 | ||
Yeah I thought BF got the stainless rail, Territory had it standard from release I believe.
31-03-2024, 07:17 PM | #1884 | |||
Happy Easter to you and yours.. |
31-03-2024, 08:49 PM | #1885 | |||
This helps, I'll be in touch as soon as I can work out which one. |
03-04-2024, 02:32 PM | #1886 | |||
Thanks
-15 Ford Falcon FGX XR8 Auto -14 FPV Pursuit Ute #47 Auto -12 FPV Pursuit Rspec #44 Manual -11 FPV GS Ute #225 Manual -10 FG XR8 Ute Manual Sold -06 BF XR8 Ute -75 XB Falcon Coupe 351 GT replica -73 Ford Mustang convertible 351 -20 Ford Mustang GT Convertible |
03-04-2024, 05:57 PM | #1887 | |||
Assuming you mean for the 5.4 not 5.0. Here is the 5.4 one, let me know what parts your chasing and we can see if there are any around. FG 5.4 Power Steering.png |
04-04-2024, 09:52 AM | #1888 | |||
Kelpro makes a new 3A212 (which I have), but it seems no one makes anything for 3691 or 3A005 (which I need). Also what are the seals that go in the rack for 3A212? My Kelpro kit only came with one but I assume there are actually two? Finally I think Ford is not making that reservoir anymore either? If those things crack that's going to suck for a lot of owners. I see Aeroflow makes an aftermarket aluminium tank which I may end up having to do if I can't find hoses to fit in the factory way. Thanks again
04-04-2024, 01:12 PM | #1889 | |||
There are a handful of resevoirs left, around $200 plus freight. GT |
04-04-2024, 07:02 PM | #1890 | |||
Can you tell if anyone in Sydney has stock of the seals? I really don’t want to wait past this weekend for those. Sent from my iPhone using Tapatalk
