#31 | ||
without wider and stickier rear tyres, all of this supercharged V8 power is wasted.
Ford really need to fix this, it's responsible for those bad launches and ordinary times against Holden V8s. And while they're at it fix those darned diff bushes and skinny axles that are prone to stick slip. They're not a problem now but when you get a good blown engine hanging of them, look out |
#32 | |||
Whole driveline and all bushes will need a serious overhaul if the numbers I've heard are true. |
#33 | |||
So "traction issues" are a complex mix of circumstances.. There's more to it than just tyre width, the suspension geometry will also dictate how it puts its power down.. Better compounds, better ratios and better rear suspension geometry will help.. not just 1 element in isolation...
335 S/C GT: The new KING of Australian made performance cars.. ![]() |
#34 | |||
They did for Holden.. |
#35 | |||
The person controlling the right pedal will dictate how much traction they do or don't have...
#36 | ||
Thailand Specials
They could just add it as an option, or make a set of really good street tyres standard on the XR and FPV series?
#37 | |||
Giddy up.
Even if the Patrol has 300kw, ask yourself, do you see a Nissan Patrol outdoing or blowing away a XR8 powered coyote ???. |
#38 | |||
JAFO
#39 | |||
#40 | ||
The power figures just don't add up...
#41 | |||
Chasing a FORD project!
a few questions have been popping up in my head of late, and one of those was this: with a fairly exponential curve upwards of power from early 90's to now(read: V8's starting around the 160kw mark and progressively gaining more as the years go on, 200 by mid AU, then T series 220 and 250, XR8 260 and XR6T 245, F6 270 GT 290, then swap those high numbers for even higher ones, 310 and 315, 302 for the specials, and 290 and 270 become the norm for lower spec) how long is it before they just can't make anymore power? i dont think theyre going to "run out of puff" so to speak. you can make monstrous power if you want. but Gov wont let them and at some stage, economically, it will not be viable. the constant upgrading of transmissions and drivelines, researching new and improved bushes and the like, will mean that these peak power and torque figures should plateau at some point...shouldn't they? far be it from me to hope that they do in the near future...i'd love to see a production car built in Aus with 500kw in 10 years time...but surely its going to be stopped at some point?
point two, and that is, while reading an old street machines magazine, it had a bit on 9inch alloy diffs for VT and VX commodores. swap em over, retain the IRS etc and you have a bullet proof diff assembly. should ford research a 9inch alloy diff to slot into the control blade IRS to make it a nice strong diff for the power upgrades planned from factory for coyote? and beyond?(probably a bit late for FGII release.) the units i was reading IIRC where around 5500 bucks. now, if that was a cost spread throughout the cost of the whole car, then obviously bulk buying power or whatever, would reduce the cost further...well, is this a good idea??
1996 BMW 740iL V8. TV, phone, leather, sunroof, satnav, all as standard. Now with 19" TSW Brooklands, 2 1/2" stainless steel exhaust, plus more coming soon. |
#42 | |||
I see the future of performance vehicles in reducing weight, fuel consumption and improving handling over wholesale power increases. Hell even my N/A FG XR6 is as fast as my AU220XR8 was..... For a base model engine its extremely lively and feels as fast as the best from Ford/Holden only 10 years ago... The power upgrades can't keep on climbing at its current rate because human reaction skills and driving abilities havent kept up with technology....
#43 | |||
You dig, we stick!
#44 | |||
not here much anymore
Are you kidding me? You cannot win with some people - they do nothing, add a few KWs they get criticised for not doing enough, now they put a fantastic engine in it like this one and you think they've done too much?! ![]()
2024 F150 XLT
#45 | |||
#46 | |||
The Destroyer
Also Im well aware that the 315kw power output is for the xr8. Which is the model I'm planing on purchasing.
Toy- Blown XR8 Ute. Black on black "Front-drive cars are for children" |
#47 | |||
The Destroyer
#48 | ||
I personally dont see what all the fuss is about the FWKW rating. I would have been happy to see a 300kw XR8 with improved low/mid range torque. To me 315kw for an XR8 sounds very exciting, and I am not fussed at all that is only a few kw up on the mustang. If it has a meaty low to mid range, with a nice top end to matched (which supercharged 8s normally seem pretty good at doing), then I will be wrapped.
Theres none so great as a thumping V8 |
#49 | |||
If you scale the power of a GT to the same as a new 300kw Patrol (KW/Tonne) you'd end up with 196KW GT......
#50 | ||
I think it's safe to say that Ford/FPV wouldn't waste significant investment, development and time on an engine program for only a handful of kilowatts and no performance/economy advantage over the out-going model.
I think we should wait and see how things pan out before judging what this 315kw number really means. |
#51 | |||
FORMERLY TX3DUDE
We are getting a supercharged 5.0 v8 that is almost certainly underrated by at least 30-40kw. We KNOW it will be much faster, lighter and more economical. It will be backed up by one of the worlds finest 6speed automatics and we're complaining about the specified power output number in the brochure????? ![]() Cant wait to see what the aftermarket is going to do with this engine OHHHH BABY! |
#52 | ||
Well said there, Ghiadude. 25 more badge kws than the current XR8, lighter, better power delivery due to forced induction (more torque at low rpms), better fuel economy. This is a huge win for Ford. The XR6T is a great car, now the XR8 will match it at the least. People shouldn't be complaining (no one complains about the XR6T...), they should be rejoicing.
Put it this way. This new XR8, by the sounds of it, will compare to HSVs in terms of performance. This is very exciting news, especially if this upgrade is an indication of what FPV have in store. The only things I would be worried about is rubber and brakes, which are already a problem for the XR6T and the current XR8.
Ego BF MkII F6 Typhoon - 6 Spd Auto
#53 | |||
Front : 355x32 Rear: 328x26 |
#54 | |||
Barra Turbo > V8
-2011 XR6 Turbo Ute - Lux Pack - M6 - OEM+ Tuned by LS Tuning and Performance -2022 Hyundai Tucson Highlander Diesel N Line |
#55 | ||
I am already piecing together in my head a new XR8 - first mod exhaust to get the V8 note, then pulley to get the supercharger whine. Dark argents transferred off my current XR6T and lowered. Exciting times for Ford.
1966 Ford Mustang coupe. 347 stroker, PA reverse manual C4, TCE high stall converter, B&M Pro Ratchet, Edelbrock alum heads, Edelbrock intake manifold, MSD ignition, Holley Street HP 750 CFM carb, gilmer drive, wrapped Hooker Super Comp Headers, dual 3" straight through exhaust, Bilstein shocks, custom springs, full poly suspension, American Racing rims, Open Tracker roller spring saddles and shelby drop. Still to go - Holley Sniper EFI with integrated fuel cell. |
#56 | |||
Guess Who's Back?
The 18th Letter |
#57 | ||
Cheers JPFS1.
Good bloody knews that, even if it increases the price of the XR8 some! Makes it a bit more likely that the Pursuit and Super Pursuit might go, I'm thinking (NB: I can't remember if that has been confirmed or not yet...).
#58 | ||
Hmmm. Sounds like Coyote will be a sweet engine in S/C form, but I wouldn't be popping the champagne quite yet for wildly improved 0-100 times. Wonder how many torque tags will be built into the engine management software to save drivelines?
This engine is more likely to shine in the areas of allowing better handling (less front end weight), rolling start responsiveness, and ease of day to day driving when at low to middling revs. |
#59 | |||
The Destroyer
#60 | ||
Some people are never happy.
I would have a supercahrged XR8 ANY DAY! i wouldn't care if it made 250KW! Give it to me! Poor Ford...Even it's fans winge. |
