Race Brakes Sydney Street and race performance pad / rotor combinations as well as brake upgrades and Exedy clutch kits. Website Link |
01-09-2012, 10:12 AM | #31 | |||
Race Brakes Sydney
MATTHEW PEARCE
RACE BRAKES SYDNEY = When you want it to stop Street to track is what we expertise in Phone 02 9609 1101 sales@racebrakessydney.com.au www.racebrakessydney.com.au |
01-09-2012, 12:56 PM | #32 | ||
Driver Returns On Foot
ok so Ive got a BF V8 non XR ute.. I need to replace the rotors.. I can pay $60 for brand new stock ones.. and they work.. if I wanted slotted etc.. are they purely just for **** factor when it comes to everyday use? IE: unless I participate in track days is there really any point in upgrading ?
I do understand that with more power you need better braking power.. but again this would be in racing situations.. right? because the ute slows down perfectly fine from 175kph (thats where it cuts out) but I dont see myself racing everywhere I go.. opinions./advise would be appreciated.. insults will be returned. |
01-09-2012, 03:50 PM | #33 | ||
GT-P With An Ego
H.G I put it this way. Never skimp on tyres, brakes or suspension. They're the only things keeping you on the road. Racing or not, wouldn't you rather have better brakes than not?
1998 DL LTD in Sparkling Burgundy, daily, mild 5.0L, high end stereo, slow'n'thirsty - 138.8rwkw. 2006 BF GT-P in Ego, 5.8L all alloy, Kenne Bell 2.8HLC, Nizpro Stage 2 ZF - 440rwkw. 2008 SY F6X in Silhouette, Ford Performance Club of ACT |
03-09-2012, 01:47 AM | #34 | ||
Call me dirt... Joe Dirt
Matt, can the factory front Brembo rotors be skimmed?
Apart from them potentially being warped/hotspotted, I've noticed a slight ridge has developed on the outer edges of the contact surface. I want to keep them as spares. Is skimming expensive and do you know/recommend anyone in Perth? Cheers.
2007 BFII FPV Cobra Ute|Boss 302|6M|#23/100 Mods so far: Billet Products Shifter|X-Force Exhaust|Herrod Oil Breathers|Whiteline Sway Bar|Tein SuperStreets|Kings FOR-303SL Rear Springs|Melling Oil Pump|Mace Manifold Spacers|Powerbond Underdrives|Pacemaker Headers|Ballistic Cats|XFT Custom Tune @ 308.3rwkw|DBA T3 Rotors|Ferodo Pads|Goodridge Braided Lines Mods to come: 4.11 Diff Gears|Chromoly Tailshaft I use & recommend: Castrol|Motorcraft|Mainlube|Penrite Check Out My Build Thread |
03-09-2012, 01:07 PM | #35 | |||
290 BF XR8
EL Series 2 XR8 In the build Boss 290, ZF6, BF K Frame BF XR8 in Bionic Back burner for now NL Pajero Camping/adventuring vehicle Faded paint and smells funky Honda CBR 300R Daily |
03-09-2012, 03:33 PM | #36 | ||||
Race Brakes Sydney
MATTHEW PEARCE
03-09-2012, 04:04 PM | #37 | ||
try Perth brake parts for skimming mate.
Matt the $1100 for the 5000 series rotors you quoted me in pervious post is that each of for the pair?? |
03-09-2012, 04:50 PM | #38 | |||
Race Brakes Sydney
MATTHEW PEARCE
03-09-2012, 09:55 PM | #39 | |||
04-09-2012, 10:46 AM | #40 | |||
Race Brakes Sydney
MATTHEW PEARCE
05-09-2012, 01:58 AM | #41 | |||
05-09-2012, 10:52 AM | #42 | |||
Race Brakes Sydney
MATTHEW PEARCE
05-11-2012, 09:41 PM | #43 | ||
Hi Matt
I have a BF II FPV Force 8 with brembo 4 pot front could you PM me price on Bendix ultimate pads. cheers
FTe Venom T2 TS50 man Build # 23... Sunroof , tri y's , custom twin exhaust, Hooker mufflers FPV BF FORCE 8 Ego Build # 26........... S/Steel xforce exhaust,Blue Power air filter, ZF trans all tuned by "Autotech", 254rwk ,brembo's,factory sunroof |
06-11-2012, 01:00 PM | #44 | ||
Race Brakes Sydney
No worries
MATTHEW PEARCE
06-11-2012, 11:52 PM | #45 | |||||
My car: 6 piston front/4 piston rear Brembo setup. DBA5000 front discs and standard FPV rear (about to be replaced by DBA4000). Currently on my second set of front Hawk Performance ceramic pads. Love ‘em! Changing pads is easy enough if you have the right tools, so swapping between Hawk ceramics for daily use and 2500s for track days is realistic. You’ll need a nail punch and brake pad spreader to make it easy though. Photos: http://www.fordforums.com.au/showthread.php?t=11374011 A GiroDisc brake pad spreader isn’t cheap, but makes pushing the pistons back in very, very quick and easy. If you end up with Hawk pads for daily use and Ferodo 2500 pads for track days then you’ll want to get one of these spreaders. A bit under $300 including postage, but you'll keep it for the rest of your life. I use mine on conventional two piston calipers as well. Photos: http://www.fordforums.com.au/showthread.php?t=11344308 I find that the easiest way to push the pistons back in is to apply the GiroDisc pad spreader to the outer parts of the pads (ie before removing then). ie: Quote:
Also: If doing a track day, make sure that your brake fluid doesn't contain too much moisture. I paid way too much for a Wurth brake fluid tester last year - there are other, much cheaper brakes (eg Kincrome). http://www.fordforums.com.au/showthread.php?t=11330321 Flushing the brake fluid with a Brembo setup is easy enough, especially if you have speed bleeders fitted: http://www.fordforums.com.au/showthread.php?t=11355948
Click here for my previous Photo Essays and Build Threads.
------------------------------- Good people. Bad people. Smart people. Dumb people. Car crashes. Vomit. Read about it all at Cabloid, the web site that has stories and photos about my life driving a taxi at night. www.cabloid.com.au Last edited by Phildo; 07-11-2012 at 12:06 AM. |
07-11-2012, 10:01 AM | #46 | ||
Race Brakes Sydney
FYI - Once a year fluid flushes for std street cars and regular fluid flushes for any cars doing track days will maintain optimum performance from your brake fluid.
MATTHEW PEARCE
