09-10-2005, 09:02 AM | #31 | |||
Chairman & Administrator
You mean like THIS one??
Observatio Facta Rotae
07-11-2005, 05:11 PM | #32 | ||
SUMP PLUG
Might be a little late here russell, but do you have a diagram on the pinout for the eec-v module?
I need to identify a few wires coming out |
07-11-2005, 10:41 PM | #33 | |||
Hi Mack6
You'll find the pinout information in the Tech Article Database HERE Cheers Russ Quote:
28-12-2005, 06:47 PM | #34 | ||
How handy are these diagrams? Well, let me tell you. I was at the in-laws, and wanted to install some little tweeters in the front A pillar trim. I ran speaker wire to the back of the head unit, but then wet to look up my book to show me which coloured wires to use, and guess what? Left the AU workshop manual at home. So onto the net, go to FF, into this thread, and found the info I needed.
Thanks Russ - without your diagrams, I would be speakerless tonight!
28-12-2005, 07:02 PM | #35 | ||||
Cuban... nothing like it
28-12-2005, 07:16 PM | #36 | |||
26-02-2006, 10:17 PM | #37 | ||
im wanting to change my standard tape player with stacker op to a single din pioneer cd player in my au1 xr8 ute and i just need to know the colours of the wires. can anyone help??
21-03-2006, 10:39 AM | #38 | ||
hi russ just wondering if u had a clear copy of the audio wiring for a 1999 au falcon or could tell me the wire colours behind the head deck plz
thanks |
13-10-2006, 12:34 AM | #39 | ||
WOW Thats not for the amatures like me.lol
ps. does anyone know the code for an AU radio cassette player? |
13-10-2006, 08:30 AM | #40 | |||
Audi S3
15-11-2006, 01:26 PM | #41 | ||
BEER I NEED BEER
do you have wiring diagram for au2 cruise control
worked hard to get my new beast and i love it, it rocks. MYR16 the beast |
15-11-2006, 11:17 PM | #42 | |||
Cheers Russ
30-11-2006, 12:28 AM | #43 | ||
Is there a key for the wiring colours
03-04-2007, 07:03 PM | #44 | ||
Do you have, or can you get the wireing diagram fur the AU ABS system. I have a high earth resistance, & need to know where the earth's are located.
Walmec2003. Thank you. |
06-04-2007, 08:34 AM | #45 | ||
Monsta
Hi guys how are you all? I have a slight problem with the sterio in my AUI. I've upgraded the sterio to a cd player from an AUII. Everything works fine appart from the steering wheel controls. I know this isn't a big thing, but I hate having something on my car that doesn't work. Any help at all would be greatly appreciated
Thanks heaps Cooky : |
11-04-2007, 09:21 AM | #46 | |||
Cheers Russ
11-04-2007, 09:23 AM | #47 | |||
Cheers Russ
11-04-2007, 09:25 AM | #48 | |||
Cheers Russ
11-04-2007, 11:45 AM | #49 | ||
hi all i know this is off the subject of the AU but has anyone got a pinout for the BA ECU
thanks Brett |
27-04-2007, 11:47 AM | #50 | ||
Fuzzy Logic
looking for wiring for starter motor for au2 from ignition to starter, also watertemp sensor wiring
27-04-2007, 02:51 PM | #51 | ||
Bob
Russ,
Is a wiring diag available for the AU3 Forte 4.00Lt Auto which tells me what each of the wires from the ECU to the trans does? Also for factory cruise? Bob |
27-04-2007, 05:56 PM | #52 | |||
Water temp sensor is under the BEM section. Cheers Russ
27-04-2007, 06:01 PM | #53 | |||
Cheers Russ
03-05-2007, 09:49 PM | #55 | ||
drive it like u stole it
hey mate, was wondering if a wiring diagram was available that showed what and where the tacho signal wire is on a AU series 2 xr6 ute manual.
if you were able to point me in the direction of it i would be very thankful
www.aufalcon.com/phibza |
03-05-2007, 10:51 PM | #56 | ||
it is pin 45 on the ECU pink with a blue trace or pin 16 on the cluster
03-05-2007, 11:19 PM | #57 | ||
it is pin 45 on the ECU pink with a blue trace or pin 16 on the cluster where it is bink with a white trace not sure where the connector is where it changes colour but it does these colours are for AU2 but i assume it suits all
04-05-2007, 06:42 PM | #58 | ||
thanks mate, im trying to wire up a shift light so i will probably just try and use the wire that goes into the cluster. I no there is 2 plugs that go into the cluster which one of these would the wire be in? also do you no which pin power and earth is out of all the wires that go into the bak of the cluster?
06-05-2007, 11:15 PM | #59 | ||
would anyone know how to remove the cover to the traction control button to change the globe and the power windows cover thanks
17-07-2007, 04:21 PM | #60 | ||
russellw great diagrams, was wondering if you have a schematic that covers the Oxy Sensor to the ECU, keep up the good work....I,m doing a project car that i'm installing the oxysensor in, have the ECU and fuel/air mixture gauge etc
