19-10-2006, 04:38 PM | #61 | |||||
XR & FPV Owner
With a manual, in gear if the foot is on the gas it goes, take it off and it starts to engine brake. It won't "float" unless you clutch it. Or do you mean it will not keep a constant speed with a constant throttle input? The "thump" does it happen in the dry too? Can you get it to thump when you brake hard? What about on hard throttle, does it thump then? Does it sound like it's coming from the floor, boot or rear seat?
2005 BF GT (6sp manual - Build #183) 2015 SZ MkII Territory Titanium 2016.75 LZ Focus Sport Quote:
19-10-2006, 08:16 PM | #62 | ||
02/90 EA II Fairmont
what if it's running really rich or something, have you checked basics like plugs, leads etc
211RWKW EA |
20-10-2006, 08:38 AM | #63 | |||
With da Warlords
Braking Hard No it doesnt thump, except where one of the twin exh pipes hits underneith. If I accelerate & turn, yeah it'll thump a bit, sounds like its coming from the back seat, or under it.
You don't have to be faster than the bear, you just have to be faster than the slowest guy running from the bear. For Sale: Parachute. Only used once, never opened, small stain. Windsor Warlords AU III XR-8220 300+ rwhp of Manual fun XR50T Ute - 300rwkw (give or take depending on the day)
20-10-2006, 07:14 PM | #64 | ||
SII XR8
I have had similar throttle issues with my XR8.
I found that after not driving the car for a week or so the initial pedal movement would be very stiff, resulting in surging while driving, and spinning or stalling when taking off. Eventually tracked it down to carbon build up in the throttlebody going realy hard and crusty when the ute wasn't being driven. Cleaned the throttlebody and the problem hasn't come back. Anyway, at least you don't have an auto changing gears on you mid slide, very scary in a 6cyl lsd work ute. |
20-10-2006, 11:27 PM | #65 | |||
Back to Le Frenchy
I'm gonna say **** tyres. Mine is now running nice and smooth but is a real ***** in the wet with the crappy Wanli tyres that are on it (85% tread left). Get yourself some decent rubber under it and see how you go.
22-10-2006, 05:03 PM | #66 | ||
nitroman
I've got Maxxis maz1's all round on my au1 xr8 and I find them great in the wet and dry. Turn those sava's into smoke and get Maxxis for the rear as well. If you have a manual use the clutch as traction control when she starts to get loose. I actually enjoy wet driving, it's like double the horsepower for free!
22-10-2006, 06:25 PM | #67 | ||
Back to the AU
I had the ST sideways this morning at about 30km/h with a breath of throttle (ie less than 1mm of throttle). It is definately the dodgy firenza's that are on the rear. Shows the difference between the decent dunlops i have on the fronts and some dodgy no names.
2001 Ford AUIII Falcon XR8 Manual - Can't get enough of the AU 2001 VW Bora V6 4Motion - If I squint it almost looks like a Sierra Cosworth |
22-10-2006, 07:32 PM | #68 | ||
nitroman
Wheel alignment also has a lot to do with traction wet and dry. After you get a couple of new maxxis tyres get a decent wheel alignment (not just front toe in like most tyre shops) and you will be amazed at the handling transformation. If it oversteers like buggery it probably has too much toe in and neg camber up front.
AU1 XR8 E303 cam,Crane Rockers,Crane double valve springs,Rollmaster roller timing gears,Crow +80" pushrods,SS cold air induction, 2 1/2 inch custom exhaust,Capa flash tuner.KONI shocks. EF fairmont wagon. GASGAS 400 enduro. Honda hr192 mower |
08-11-2006, 03:19 PM | #69 | ||
Formely FG G6E Turbo
Just wanted to add my 2c worth, I have had my BF XR8 auto for 3 weeks now and drove in the rain for the first time last weekend, what a shock! I should point out I came from driving a Subaru Outback 3.0R (2004) which you could literally floor the throttle in any conditions apart from hard cornering, with zero slip.
In the dry the XR8 easily out grips the Subaru, but in the wet I found it quite interesting, the car was easy in a straight line, even with some wheelspin the DSC controlled it, but on any sort of corner it was very easy to step the rear out of line. I am sure I'll get used to radically changing my driving style in the wet, but I sure am glad to have traction control and DSC to help out. |
08-11-2006, 06:52 PM | #70 | ||
I work at Beaurepaires and both the tyres you mentioned are crap the savas are acually made in the dunlop factory but are still a really cheap budget tyre, and the maxiss are well lets just say the savas are better. But the 220kw's and a manual would proberly be the reason
Its not peer presure..........Its just your turn! XE project underway |
08-11-2006, 07:46 PM | #71 | ||
Actually, Walker, the Maxxis are a pretty god tyre. Plenty on the forums swear by them, and I have personally used the savas for over 12 months in an auto V8 and had no trouble at all. But then I'm 37 and have finally worked out how to control the right foot when I need to (which is pretty much only in the wet).
08-11-2006, 09:55 PM | #72 | ||
AU II XR8
a falcon is a heavy car and once they start to slide they keep going as i found out on monday while going just that little bit to fast in what you could call a dirt skid pan. no damage though. doesnt take much for them to start sliding.
08-11-2006, 10:00 PM | #73 | ||
I have Sava's on the spare Fairmo........... Sava + V8 + Rain = Most Fun with Clothes on!
09-11-2006, 05:27 PM | #74 | ||
Barra Turbo > V8
Honestly i dunno why people say their cars are a pain in the wet i manage my TE in the wet (when it rains) i have about 60% 245 toyo trampios on the rear even with traction control off i can drive around and not let it spin. Although i have heard a few stories about SAVA tyres.
-2011 XR6 Turbo Ute - Lux Pack - M6 -2022 Hyundai Tucson Highlander Diesel N Line |
09-11-2006, 06:33 PM | #75 | |||
Audi S3
i get them from the Bob Jane i go to. excellent tire, wet and dry. will still let go if you push it, but generally very good. mine are a little on the low side.. 3-5mm tread left, so all this rain in sydney is helping the cause
