Old 10-10-2010, 01:47 AM   #61
frd906
cheers for the price, sounds pretty good
Welder/Fabricator at Beaudesert Exhuast
Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors
frd906 is offline   Reply With Quote Multi-Quote with this Post
Old 10-10-2010, 08:49 AM   #62
Day-mow
rexnet
Day-mow's Avatar
none of my guides are broken so im not gonna worry about it. guides came to a total of 48 chain was 14. both non geniune
MY06 WRX Build Not Bought
Collingrove Hill Climb- 38.79
Old 11-10-2010, 10:26 PM   #63
frd906
Hows the progress going mate?
Old 13-10-2010, 03:13 PM   #64
Day-mow
rexnet
Day-mow's Avatar
Got all my parts yeste. I got front timing case cover. Timing case gasket. Timing chain and rocket cover gasket. That came to a total of $220
A friend is coming over tonight to help me with the timing chain then I'm away. Hopefully I'll get it started tonight
Old 13-10-2010, 03:56 PM   #65
frd906
Cool. Post some pics
Old 14-10-2010, 12:51 AM   #66
Day-mow
rexnet
Day-mow's Avatar
tried to fit tonight. with the sump attached. and failed. so 2morro nite im going to try to fit the timing case after lowering the sump a few mm. after doing this life should be easy and everything should go super......... i hope
Old 15-10-2010, 08:26 AM   #67
Day-mow
rexnet
Day-mow's Avatar
Finished at 3 am seems to b not leaking still only early days tho. Pretty challenging but I feel proud that I achieved this on my own most of the time. Sure I made a few calls but normal inwould of had dad there the whole way. Kudos to me
Old 28-10-2010, 12:19 AM   #68
Day-mow
rexnet
Day-mow's Avatar
realise this is super old.
still leaking from the front crank seal i believe. i tapped it in with a hammer moving around.
a friend said i should use a socket or something fitting to make sure its in. any suggestions/ideas as to what i can use.
Old 28-10-2010, 12:20 AM   #69
frd906
you didnt pinch the front seal did u when u slipped the balancer over it
Old 28-10-2010, 12:29 AM   #70
Day-mow
rexnet
Day-mow's Avatar
dont beleive so. when i put the balancer on i didn't have the car in gear. so it was sticking out a bit didn't leak.
realized it was sticking out a bit so i nipped it up and now its leaking. so i've done something.
Old 28-10-2010, 12:38 AM   #71
frd906
What do you mean by sticking out?
Old 28-10-2010, 08:25 AM   #72
Day-mow
rexnet
Day-mow's Avatar
It wasn't fully tightened when I tightened it in gear it moved back a few mm
Old 28-10-2010, 10:03 PM   #73
AMB
Technical Contributor: For members who share their technical expertise. - Issue reason: Always has a helpful answer in the technical sections, wether it's giving information on a simple diagnosis with a small issue, Helping someone fix their car if they are stuck on removing/installing something, or just need information on what works how.
Did you put sealant in the key way like I said way back? If you don't, it leaks oil through the keyway.
AMB is offline   Reply With Quote Multi-Quote with this Post
Old 28-10-2010, 11:06 PM   #74
Day-mow
rexnet
Day-mow's Avatar
ahh possibly not.
fail @ doing work on your car @ 3am
Old 30-10-2010, 09:05 AM   #75
Day-mow
rexnet
Day-mow's Avatar
so how do you put the seal in? do i need to use special tools? the guy @ sprint auto said u just push it in with your hands. its an all rubber design.
Old 30-10-2010, 10:18 AM   #76
frd906
Just pull it out and have a good look at it first before you do anything
Old 30-10-2010, 12:46 PM   #77
Day-mow
rexnet
Day-mow's Avatar
Put a new seal in seems ok.
When taking the balancer off tho it looks like it's pulled the outer half off slightly on an angle. The inside spins fine but the outsides a bit wobbly is this mega bad?
Old 30-10-2010, 04:08 PM   #78
frd906
You got any pics of it,
Old 30-10-2010, 04:16 PM   #79
Day-mow
rexnet
Day-mow's Avatar
can take a movie.
Old 30-10-2010, 05:08 PM   #80
frd906
so you saying the harmonic balancer is wobbling really bad when the engine is going
Old 30-10-2010, 09:21 PM   #81
Day-mow
rexnet
Day-mow's Avatar
Yeah kinda it prob moves 10mm or so
Old 31-10-2010, 03:13 AM   #82
AMB
Sounds like you f'd it. This is the new one is it? And you pulled it off using the outside pulley part?
Old 31-10-2010, 08:36 AM   #83
Day-mow
rexnet
Day-mow's Avatar
Yep so I need to get a new one? What happens if I drive it could I use a mallet of sorts to wack it level?
Old 31-10-2010, 08:53 AM   #84
Day-mow
rexnet
Day-mow's Avatar
watch the edge's of the balancer.
http://www.youtube.com/watch?v=gf7JszLdf78
Old 31-10-2010, 11:08 AM   #85
frd906
my new one does the same thing, i think its due to my idle tensioner
Old 31-10-2010, 11:58 AM   #86
Day-mow
rexnet
Day-mow's Avatar
Really? So it'll b ok you rekn? It's only the belt part that's a bit pulled of. That part that is bolted on is still fine.
Old 31-10-2010, 12:08 PM   #87
frd906
Was it doing it the first time you put it on ?
ps, ill try and get a video today
Old 31-10-2010, 02:19 PM   #88
Day-mow
rexnet
Day-mow's Avatar
I Deff pulled oneside off a bit well moved it
Old 31-10-2010, 04:59 PM   #89
AMB
The video is a bit dark and the camera moves, I can see some wobble but can't judge how much. 10 mm is too much wobble, an old balancer wobbling that much needs to be replaced. If its only a slight wobble then it ok, new ones sometimes wobble a little bit. You probably distorted the rubber from pulling on the outside of the pulley. Have a read of this, the last paragraph is the important bit.
http://www.ehow.com/how-does_5009034...ncer-work.html
Old 31-10-2010, 07:06 PM   #90
Day-mow
rexnet
Day-mow's Avatar
I think I'll mark a side then record it. Ive driven it a bit and it feels normal
