Old 29-03-2011, 06:27 PM   #91
jpd80
jpd80's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Thoughtful contributions to our community
Default Re: Ford Falcon VS Ford Tuarus
Originally Posted by Buntz93ED
I don't know of any bias or lacking quality of Motortrend. But they did not like the new Explorer.
http://www.motortrend.com/roadtests/..._explorer.html
FYI,
Motortrend in the USA is considered similar to Drive here, very pro GM.
They love sticking it to Ford at every opportunity.
jpd80 is offline   Reply With Quote Multi-Quote with this Post
Old 29-03-2011, 06:31 PM   #92
Road_Warrior
Pity the fool
Road_Warrior's Avatar
Yes and I remember Motortrend had a **** over the first time the "OMG NO MORE RWD FALCON FWD LOLOL" article got published. In fact, they quoted Drive.
Fords I own or have owned:
1970 XW Falcon GT replica | 1970 XW Falcon | 1971 XY Fairmont | 1973 ZG Fairlane | 1986 XF Falcon panel van | 1987 XFII Falcon S-Pack | 1988 XF Falcon GLS ute | 1993 EBII Fairmont V8 | 1996 XG Falcon ute | 2000 AU Falcon wagon | 2004 BA Falcon XT | 2012 SZ Territory Titanium AWD
Proud to buy Australian and support Ford Australia through thick and thin
Road_Warrior is offline   Reply With Quote Multi-Quote with this Post
Old 29-03-2011, 06:51 PM   #93
Buntz
Straight Eight
Buntz's Avatar
They gave the Mustang convertible the win over the Camaro.
The Falcon is dead. Long live the Mighty Falcon.
Buntz is offline   Reply With Quote Multi-Quote with this Post
Old 29-03-2011, 06:52 PM   #94
jpd80
jpd80's Avatar
Motor trend and Drive actually used each other's reports to validate the report...
Like a couple of cowboys eating pudding.....
Old 29-03-2011, 07:08 PM   #95
Road_Warrior
Pity the fool
Yes that was it. But in their case the cowboys analogy was more like Brokeback Mountain.
Old 29-03-2011, 07:16 PM   #96
Buntz
Straight Eight
Buntz's Avatar
After reading a few articles.... seems they collaborate with drive... and another article called Wheels magazine "a respected Aussie mag".
Old 29-03-2011, 11:52 PM   #97
FPV GTHO
Technical Contributor: For members who share their technical expertise. - Issue reason: Sharing his knowledge of performance exhaust setups for the NA 6 cyc Barra Falcon from BA to FG.
We have an AWD vehicle based off a sedan platform that could easily become a sedan or crossover thing for the US.
In my limited view anyway. I'm just basing it off things like the RTV and Territory.
But again, Territory only shares a few bits directly with Falcon in the frame, its not on the same platform though.
FPV GTHO is offline   Reply With Quote Multi-Quote with this Post
Old 30-03-2011, 06:14 AM   #98
chevypower
chevypower's Avatar
Didn't Motor Trend's Chief Editor, Angus McKenzie work for Motor Magazine, another pro-GM publication?
chevypower is offline   Reply With Quote Multi-Quote with this Post
Old 30-03-2011, 08:05 AM   #99
jpd80
jpd80's Avatar
Wheels.
Old 30-03-2011, 01:04 PM   #100
Buntz
Straight Eight
Buntz's Avatar
Wheels.
It just gets worse. Okay... no more quoting Motor Trend.
True. But Territory could scale down to the sedan crossover that is Taurus. Seeing as America's excuse is they need AWD for snow.
Old 30-03-2011, 02:40 PM   #101
Happymate
Wheels, motor trend, and motor all love fords... Jeremy Clarkson is a pro ford man, so if thats not good enough, who knows what is.
The taurus chassis is the old volvo s80 chassis apparently, that was a good car too.
Happymate is offline   Reply With Quote Multi-Quote with this Post
Old 30-03-2011, 02:55 PM   #102
jpd80
jpd80's Avatar
Incorrect.
D3 was derived from the early XC90 chassis, that's why the sedans and SUVs all have the same hulkish proportions.
Give Taurus a proper sedan floor pan, lower hip point with matching top hat and watch the weight drop away...
You could almost call it a falcon if it had RWD.....
Old 30-03-2011, 03:14 PM   #103
Happymate
Incorrect.
Thank you for the correction Why on earth would they choose the xc90 for a sedan base... It would be interesting to know if ford have chassis changes lined up for it in the way that you mention at any point, or if ford aus got stuck with it, if they would do something similar.
I am somewhat confused as to why they didnt use a stretched s60. I had an awd s60 a few years ago and it was incredible in corners, wasnt too hefty on the weight either.
Old 30-03-2011, 06:33 PM   #104
outback_ute
Ute Forum Moderator
Contributing Member
outback_ute's Avatar
Yes but the system does not do AWD at a sedan ride height it would need to be redesigned to do so if it was possible at all (currently the driveshaft runs under the engine, lower everything for a sedan and you would need to raise the diff relative to the engine which would then be in the way of the driveshaft). ps the RTV is not AWD.
Old 31-03-2011, 02:14 AM   #105
Buntz
Straight Eight
Buntz's Avatar
They could doa BMW X6 competitor with it then.
Old 31-03-2011, 11:07 AM   #106
jpd80
jpd80's Avatar
Isn't the Territory's Front differential integral with the I-6's sump / oil pan?
I thought that the engineering for AWD had been "preserved" on FG,
Old 02-04-2011, 05:06 PM   #107
outback_ute
Ute Forum Moderator
Contributing Member
Yes but if you try to lower the ride height (raise the driveshaft) would the engine/crankcase be in the way of the driveshaft?
Old 02-04-2011, 09:18 PM   #108
jpd80
jpd80's Avatar
Most of the additional height comes from larger wheels and slightly raised suspension...
IIRC, the front diff housing is no lower than the lowest part of the rear sump.
Anyone with an AWD Terry able to confirm that?
A picture of underside sump/cross member would be nice...
Old 02-04-2011, 09:23 PM   #109
jpd80
jpd80's Avatar
Maximum commonality of parts to save as much money as possible, early
Fivehundred and later Taurus cars look huge in size due to high hip point.
There is a move to make the next all new Taurus an extension of next Fusion/Mondeo,
that implies it will be more car like and have much less weight, that's in a few years time...
Old 02-04-2011, 11:20 PM   #110
Buntz
Straight Eight
Buntz's Avatar
