Go Back   Australian Ford Forums > The Sales Yard > Spare Parts and Other Accessory Items > Genuine Ford Parts
Genuine Ford Parts A forum for the purchase of genuine Ford parts via an AFF member.
Old 01-05-2023, 08:15 PM   #1381
GTLEGEND
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Every advice post I visit where OP are seeking advice for their new vehicle, he is there and adds valuable support and advice for rectifying the problem. Really is a Legend. Technical Contributor: For members who share their technical expertise. - Issue reason: The quality of information he provides is in depth and highly valued by those posting questions.
Default Re: Genuine Ford Parts
Originally Posted by aussiblue View Post
Hi GTLegend. Can you help us out on this thread https://fordforums.com.au/showthread.php?t=11497819and advise not only the price and availability of the spherical vacuum reservoir in tne FG, but also confirm it's actual purpose please?
Have replied..
GTLEGEND is offline   Reply With Quote Multi-Quote with this Post
Old 01-05-2023, 08:53 PM   #1382
GTLEGEND
Originally Posted by Vicusj View Post
Hi GT, I tried to search online for these trim clips, but no luck yet.
These metal clips are for holding in place the piece of plastic strip in the Territory's rear tailgate upper sill, where the coiled power cable to the tailgate goes into the roof cavity.
I haven't been to SCA etc to look for alternatives, was just wondering what are these called, perhaps availability of originals?
Are you referring to the clips labelled HC1 in the image below:
Old 02-05-2023, 12:26 AM   #1383
bondy99
GT,
I managed to obtain a working electric car aerial for the AU2.
Problem is, the plug connector is missing.
Would those plug connectors still obtainable? If not, do you have a diagram / pic as to what they look like?
Thanks bondy.
bondy99 is offline   Reply With Quote Multi-Quote with this Post
Old 02-05-2023, 03:15 AM   #1384
If it's like this ebay one https://www.ebay.com.au/itm/23494409...Bk9SR_zms4H7YQ do you mean the pliug on the blacker aerial coax or the power cable red and green wires i.e. this bit hat's wrapped in foam?
If so, you should be able to crimp a two pin molex like this on https://www.altronics.com.au/p/h2309...ine-connector/ to the wire you have and on the aerial. RS Components likely will have the exact fitting part if that's your preference see https://au.rs-online.com/web/c/conne...rchTerm=molex. etc. Possibily this https://au.rs-online.com/web/p/wire-...-plugs/7976569 but if not, and you search with the string "Molex 2-way" on the RS Components site you'll find other options in the thousands they list..
If the aerial coax this: https://www.altronics.com.au/p/p0184...-antenna-plug/ or https://www.jaycar.com.au/solderless...0f94423916de00 will do it.
Old 02-05-2023, 08:00 AM   #1385
bondy99
aussieblue,
Yes, it's the power cable plug where the green and red wires go into.
Photo does help.
Cheers.
Old 02-05-2023, 11:06 AM   #1386
Vicusj
Attachment 106410
Thanks for checking GT, I'm unsure if those are the same, but these are the clips I'm after in this trim. I lost 2 of them and the others are sooo rusted, it started to rust the lip they clip into as well.:
'19 Wildtrak PX3 3.2 6spd, White
'09 SY1 Terri TS AWD - still going strong, now wifey's
Vicusj is offline   Reply With Quote Multi-Quote with this Post
Old 02-05-2023, 06:27 PM   #1387
GTLEGEND
Let me see if I can confirm. Give me a couple of days to get my hands on them and get back to you.
GT
Old 02-05-2023, 11:42 PM   #1388
GTLEGEND
Are you able to take a closer picture or write down the part numbers that are on the back of the trim you are holding please.
Old 02-05-2023, 11:49 PM   #1389
GTLEGEND
Originally Posted by bondy99 View Post
GT,
Thanks bondy.
I would need to see the connector face to see if one is available, cant remember what one looks like and the image provided is not clear enough.
Old 03-05-2023, 11:10 AM   #1390
BFIIGhiaZF6
George
BFIIGhiaZF6's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: The experience, information and willingness to help and share data in regards to the ZF cooling system options has probably cleared a lot of doubt about air/oil coolers and the ZF transmission.
Hi GT, could you please try and source a tailgate pull down strap for me, 434A14, like the one in this pic,
I would like to fit one to my boot lid.
Thanks, George.
BFWSM
https://www.fordforums.com.au/vbport...articleid=1708
http://fordforums.com.au/wsmpub/ba/501-05.html
2007 BFII Fairmont Ghia I6 4L, ZF6 Auto, Ego Charcoal, Warm Charcoal.
R/U 2019:Winner 2023 2025:, Best BA-BF Geelong AFD.
PWR Air/Oil Cooler, K&N, Egas elbow, V8 upper F6 lower CAI.
1997 Fairmont EL Ghia Tickford 4L Auto
1985 Falcon XF GL 4.1L Auto.
1979 Fairmont XD Ghia 4.1L Auto.
1971 Cortina GL Estate Manual.
BFIIGhiaZF6 is online now   Reply With Quote Multi-Quote with this Post
Old 03-05-2023, 01:11 PM   #1391
bondy99
Hi GT,
I do understand. I too have not seen what it looks like, the image I seen earlier was wrapped around with some type of foam material.
Old 03-05-2023, 07:16 PM   #1392
Vicusj
The only number on it is VT3273. And the matrix thingy denoting the manufacturing year and month.
Don’t spend much of your time on this one GT, if this number doesn’t lead to anything, i can just stick the trim back with some good quality double sided tape 👍
Old 03-05-2023, 07:52 PM   #1393
They are wrapped in foam to prevent them rattling behind the dash. I think the EL used the same power antenna if that's any help. My parts microfiche for the EF /ELdoes not list the connector as a separate part though.
Old 03-05-2023, 08:26 PM   #1394
GTLEGEND
Thanks, George.
Hi George,
Not a problem, $25 plus postage, choice of Warm Charcoal or Medium Eucalyptus colours.
Let me know which one you want.
PM if you want to get.
GT
Old 04-05-2023, 12:51 PM   #1395
Vicusj
Thanks GT, here couple of closer piccies:
Old 04-05-2023, 02:42 PM   #1396
FPV 460
Hi GTL. any chance of NOS FG FALCON RADIATOR HEADER TANK OVER FLOW BOTTLE availability and price for 2011 boss335?
cheers
FPV 460 is offline   Reply With Quote Multi-Quote with this Post
Old 04-05-2023, 11:13 PM   #1397
GTLEGEND
I need a close up of those numbers to the far right where the Ford symbol is..
Old 04-05-2023, 11:37 PM   #1398
GTLEGEND
cheers
Yeh should not be an issue, $80 plus postage (radiator cap not included).
If you need the cap as well they are obsolete so would need to go searching.
Old 05-05-2023, 10:25 AM   #1399
Vicusj
Ah ok, that's just the matrix showing the DOM i think :
Old 05-05-2023, 04:45 PM   #1400
GTLEGEND
I was trying to see where that part sits because it soes not look like it is in that picture I added earler?
Anyhow I have some of the clips I mentioned coming, see what they look like.
Old 07-05-2023, 08:56 AM   #1401
Ozboi
Hi GT
I am after part number, price, and availability for the front hub/bearing unit mounting bolts for a FG Falcon i6 4L 2008, VIN: 6FPAAAJGCM8C75922, Rego OZB01 please.
Thanks
Jason
Ozboi is offline   Reply With Quote Multi-Quote with this Post
Old 07-05-2023, 12:17 PM   #1402
GTLEGEND
Originally Posted by Ozboi View Post
Hi GT
Thanks
Jason
Hi Jason,
Part number of the hub to knuckle bolts is W705821S439, $19.50 each and still available. I am sure there are 3 per side required. $10 for tracked postage if need be.
GT
Old 08-05-2023, 01:32 PM   #1403
Vicusj
Hi GT,
Correct, this trim is not on the tailgate itself, but on the vehicle body where Ive circled in red in this piccie.
Thanks again ;)
Old 08-05-2023, 08:31 PM   #1404
GTLEGEND
Hi GT,
Thanks again ;)
Ok so I have found that trim and seems the clips were never sold separate, I have others coming to see if they are the same. Wait and see..
Old 09-05-2023, 09:29 AM   #1405
FPV 460
thanks GTL. can i get the part number so i can be sure its the one im after? i want a smooth finish on the plastic as per OEM and not the frosted/matt finish as per DAYCO ones.
thanks again.
Old 09-05-2023, 08:08 PM   #1406
Linz
*SILVER SERVICE PILOT*
Tech Writer: Recognition for the technical writers of AFF - Issue reason: For his technical submissions. Technical Contributor: For members who share their technical expertise. - Issue reason: Always willing to help out with good, solid advice.
Hi GT, are the BA/BF front guard side repeater lights still available please?
P8250021 by Linz, on Flickr
There's heaps of non genuine ones out there, but thought I'd check if genuine are still available.
BUILD THREAD
https://www.fordforums.com.au/showth...71#post6891271
2006 Lightning Strike BF Fairlane Ghia...HIS
2024 Titan Grey Hyundai Tucson Highlander...HERS
Linz is offline   Reply With Quote Multi-Quote with this Post
Old 09-05-2023, 08:12 PM   #1407
GTLEGEND
thanks again.
No worries, part number: AR2Z8A080BA.
Old 09-05-2023, 09:04 PM   #1408
GTLEGEND
imageP8250021 by Linz, on Flickr
Sorry mate all gone
Old 10-05-2023, 12:06 AM   #1409
The arrow points to where a steel water transfer pipe sockets into a cast alloy housing which also supports the thermostat above.
(Picture from BBT Jap Parts of Lambton NSW, via Fleabay.)
Is the o-ring seal for that steel pipe, anything unusual like a square profile? I have a modest leak on the Territory’s one, and maybe also the white ute… If it’s a specific Ford part, are they still available? (I’m using 2:1 green coolant which has a knack of finding small leaks.)
Old 10-05-2023, 12:21 PM   #1410
Bossxr8
Peter Car
Bossxr8's Avatar
It's not a square profile. Just your regular o-ring.
