09-04-2022, 06:37 PM | #1501 | |||
Most foam cannons are 1000ml in capacity. For NV Snow and Koch Chemie GSF, I do the following - Add about 750ml of water to the bottle first. Then I add 120 - 150ml of soap to fill the rest of the bottle. Some will do the opposite, adding soap first then water, but this is how I have done it for years. Now, Koch Chemie actually recommend only 30ml of product into 950ml of water. Ignore that, you will need 100ml+ for good thick foam. For Reset, CarPro don't actually specify a dilution ratio for foam cannons, nor do they promote it for such use. Again, ignore that as Reset foams beautifully, using the same 100 - 150ml as the other two.
PX MK II Ranger FG XR6 FG X XR8 Mustang GT T3 TS50 - gone but not forgotten |
09-04-2022, 07:26 PM | #1502 | ||
Rob
If you add product first, you have to add the water very slowly otherwise it foams up. It can be done but requires a lot more patience.
UA2 TREND 4WD BI TURBO |
09-04-2022, 07:46 PM | #1504 | ||
Detailing Shed have just launched a new mini polisher from Maxshine this past week.
https://detailingshed.com.au/collect...dless-polisher The Maxshine Mini Cordless Polisher Kit is a rebranded unit also sold by Refract, although $54.00 cheaper. https://refractccp.com.au/collection...-polishing-kit The Maxshine and Refract units look to be a little bulkier than the Rupes iBrid and Mint ProTools RO Polisher Nano Hybrid (Rupes copy), although not quite as bulky as the Flex PXE-80 which can also be converted to a 3 inch machine. Mint - https://www.carcareproducts.com.au/m...no-hybrid.html Rupes (Long Neck) - https://www.waxit.com.au/products/ru...d&_ss=e&_v=1.0 Flex PXE-80 - https://detailingshed.com.au/collect...-ec-2-5-bundle With the exception of the Flex, these machines are designed to use 1.0 and 1.5 inch pads. All can be used in either rotary or dual-action mode depending on the chosen adaptor. These sort of polishers are a luxury item. Do you absolutely need one? No, not really. Do you want one? Probably.
09-04-2022, 07:54 PM | #1505 | |||
(Skip to 11min 20sec to see what I mean)
09-04-2022, 11:11 PM | #1507 | |||
I really would like to know though what people use to clean carpet with those spinning drill brushes. Is there like a go to carpet shampoo? |
10-04-2022, 12:11 AM | #1508 | |||
https://carcareco.com.au/product/koc...erior-cleaner/ https://carcareco.com.au/product/p-s...stery-cleaner/ I would be inclined to say you would only use the combination of a drill brush and carpet cleaner if you intended to follow up with an extractor to remove the chemical residue. Drill brush with a cleaning solution certainly helps to lift dirt out of carpet, but they also fling it around the surrounding surfaces.
10-04-2022, 10:19 PM | #1509 | |||
11-04-2022, 06:56 PM | #1510 | ||
Here is another question for you DFB.
So typically with DA polishers most people use them to compound and polish. Once that is done and the cars paint is in good condition, how do you maintain that? Do you just use spray sealants or wax's or do you sometimes use the DA polisher with a wax or a sealant as well? I really like the spray on rinse off sealants because its just so easy and quick. I'm just wondering now that I have a DA polisher if there is any benefit in using it to apply liquid wax's or sealants for maintenance from time to time. |
11-04-2022, 07:25 PM | #1511 | |||
If you like using the spray and rinse protection products, then go with it. I find there is a tactile pleasure to be had from applying and buffing off wax every 12 months or so. (Keep in mind I get that much out of a wax due to the garage queen aspect). Also, you don't need to polish each time you apply a wax/sealant, do it on an as-needed basis. I'm about to polish my Mustang and Ranger as it seems like its "time", especially the Ranger. Using a DA to apply wax/sealant speeds up the process and allows for a more even and thin coat. A thin coat is easier to buff off. When doing this, I'm using a very soft pad designed for this task and run the machine on the lowest setting. I also use a small foam applicator for smaller areas that a DA would not be appropriate (wing mirrors, boot garnishes ect). Another reason for using the DA to apply wax is that it gives me an excuse to use it.
11-04-2022, 11:09 PM | #1512 | ||
Speaking of Waxes, i would love to try some of this, but I do not think it is available in the country yet.
They went to town on this one. It has a blend of 10 Waxes including SiO2 and Graphene.
2004 Mercury Silver Falcon XR6T - 5 Speed 2017 Platinum White Mustang GT - 6 Speed 2022 Blue Thai-Special for Daily Duties - Auto |
11-04-2022, 11:29 PM | #1513 | |||
12-04-2022, 11:27 AM | #1514 | |||
Do you do a strip wash with NV+ or similar before doing your yearly wax/sealant or just go over the top of whats left of it? |
12-04-2022, 04:48 PM | #1515 | ||
Yes, NV Snow+ in prep for a new wax or sealant. Normally the use of this product finishes off any remaining wax/sealant, and from experience, a contact wash is more effective with Snow+ rather than just a pre-soak.
13-04-2022, 07:04 PM | #1516 | |||
13-04-2022, 09:23 PM | #1517 | |||
Has anyone tried Bowden Own new wax yet? It’s taken them years to develop and it’s certainly not cheap. |
13-04-2022, 09:37 PM | #1518 | ||
Rob
There must be a few shops around that start to worry something has happened to you if they don't hear from you for a few days
14-04-2022, 03:21 PM | #1519 | ||
Whats you favorite wax/sealant to apply with the DA polisher DFB?
Something like Collinite 845 or Gyeon Q2 Wax should work well with a machine I assume right? Thats probably where the black Shinemate pads would be good too. |
14-04-2022, 07:08 PM | #1520 | |||
Using a D/A to apply 845 has ensures a thin, even coating. 845 can be a bitch to remove if applied too thickly. Another I still really like using is Wolfgang Deep Gloss Paint Sealant. This is now probably considered old fashioned, but I just love how it makes paint look. I know I trot this pic out a lot, but it really illustrates what a good old fashioned paint sealant can do........ Menzerna Power Lock is another really easy product to use on a D/A. Probably one of the easiest buff-off products around. You are correct with the assumption that the black Shine Mate pad is used for application of waxes and sealants. When using a D/A to apply waxes and sealants, it's important to have the machine on the lowest setting and to apply very little to no pressure on the pad, just let the machine glide over the paint. Unlike paint correction, you can move quicker over each section as you are simply distributing product. Use the DA on the larger, flatter panels and follow up with a small handheld applicator for the smaller and more intricate areas. It's also worth highlighting that, unlike polish residue, getting waxes and sealants out of foam pads is a nightmare. I soak them in microfiber detergent and rinse under running water as best as possible with a lot of scrunching and squeezing. I have also heard of people just putting them in a zip lock bag and storing them like that until next needed. Or just throw them away and buy another one.....
14-04-2022, 07:16 PM | #1521 | |||
I think I can get Gyeon Q2 Wax from Repco. Thanks again DFB. I'll give it a go! |
14-04-2022, 07:22 PM | #1522 | ||
Just as a follow up to my previous post, out of the products I listed, each has a more defined usage case.
Gyeon Q2 Wax - I would reserve this for garage queens only. Gyeon do not quote a longevity claim for this product that leads to the assumption that it would be very limited. Think 3 months for a daily, 12 months tops on a garage queen. Wolfgang Deep Gloss Paint Sealant - Another product that I don't know of an official longevity claim. If get 12+ months on it but I have heard it will be closer to 4-6 months on a daily. You also need to allow the product to cure for 12 hours after application for best results. Again, great for garage queens. Collinite 845 - Expect 5 - 7 months longevity on a daily. I have it lasting on 12 - 18 months on my Mustang. I like this for it's ability to resist contaminants and I will be applying it on two daily drivers in the next week. Menzerna Power Lock - I can't find an official figure on this but have had it last for 8 months on a daily driven, outdoor parked car. The label states it's protects from "environmental influences", it certain performed beyond what I expected.
14-04-2022, 07:23 PM | #1523 | |||
Realistically, you will only need one black pad.
14-04-2022, 07:42 PM | #1524 | ||
2 users like this post: |
14-04-2022, 08:19 PM | #1525 | ||
I offered to give the delivery van at work a quick clean for the weekend. I can't begin to describe how soul crushing it was to use THE BRUSH!
3 users like this post: |
14-04-2022, 08:47 PM | #1526 | ||
Two more Easter detailing sales -
Supercheap Auto have 30% off all detailing products - https://www.supercheapauto.com.au/ea...2-wk42-ods-thu Autobuff have up to 15% off selected brands including Koch Chemie, Gyeon and The Rag Company - https://autobuff.com.au/?_kx=NAmBDx4...iZ4U%3D.NbPnt6
14-04-2022, 11:43 PM | #1527 | |||
Damn I'm getting so impatient now. I wish I had my Mustang to pamper already. Its going to be a long wait. Hopefully worth it in the end. |
15-04-2022, 10:06 AM | #1528 | |||
Lazy 200 bucks spent at Autobuff, I think I might have a detailing problem. |
15-04-2022, 05:59 PM | #1529 | |||
Better still, get the Collinite 476. Harder to use, but will last much longer.
His: 2019 Ford Focus SA Trend with Driver Assist Pack: 1.5 Ecoboost 3-cylinder (yes, 3 cylinders!), 8-speed automatic in Ruby Red. Hers: 2020 Ford Puma JK: 1.0 Ecoboost 3-cylinder, 7-speed DCT in Frozen White. |
15-04-2022, 06:25 PM | #1530 | ||||
That's where 845 comes in. I don't think you would be disappointed with the level of gloss 845 provides, or it's durability.
