03-09-2013, 07:16 PM | #1 | ||
Bought it for 1150 on a big gamble unseen. Owner hasn't driven it in over a year. Gave it a decent service, air filter, fuel filter, oil filter, spark plugs, quick break and diff check over but didn't change the oils. It is pretty stock except I can tell some rust repair has been done and I'm wondering what else has been changed.
I think the decal down the side is wrong? the front radiator support lower part being black I think might be factory like a stone guard but I think the sills might have been painted? Also I ripped off the vinyl roof and there are bits of rust 6 cm wide and 30 cm long. I don't want it to be a show car, I will most likely get it on club rego so possible plans are. New radiator - 300 Vented discs front - 150 pair? New pads front - 60? New break lines - 50? New battery - 80 Rust repair for roof for the turret so pretty much the whole roof where the vinyl was - BEEN QUOTED 1150 by one shop and 700 by another. It has rust down the chrome trim that goes down both sides of the roof gutter. I have seen some people repair the gutters down the car, some people cut them off and some people trim or not trim them. What is recommended? Here are some pictures. I like this community I am trying to involve myself with it. Thanks for any help. Also is this the pre emission or post emission vehicle? I hope it's easy to get it on club rego. Last edited by bris-escort; 21-10-2013 at 11:25 PM. |
04-09-2013, 11:36 PM | #2 | ||
Well hello Mr Fancypants
aside from a bit of surface rust, it looks like a straight and solid little bus. you would never see a huge return on any money spent on it, but the items you have listed seem reasonable and would make driving it a lot better. these cars are rare now and seeing a tidy one is a treat. if it was me, I would spend what you have suggested and possibly a bit more. for a smidge over $1500, you will have a nice and reliable little runner. enjoy it.
1965 Ford Anglia 1980 Ford Escort RS2000 2006 Mazda SP23 2012 Ford Focus ST |
05-09-2013, 12:05 AM | #3 | ||
3..2..1..
Is it a 2 litre one?
I'd go all in on it, escorts are great fun to drive, and they're getting pretty rare these days. It's only money... |
05-09-2013, 12:58 AM | #4 | ||
It's a 1.6 xflow with a carbie off it that is common for 1300s and geminis.. can't remember the name. Is this pre pollution or post pollution? Also what is the best new radiator I should look into?;
05-09-2013, 05:54 PM | #5 | ||
Looks to me like a post pollution. Anything after 76 is post pollution.
05-09-2013, 10:05 PM | #6 | ||
Tippy-tronic Free Zone
Post pollution generally means it complies with ADR27A - check your compliance plate.
Some model codes: Code Body Description Style Year 11612 "L" Sedan - 2 Door 62B 10/75 to 6/77 11616 "XL" Sedan - 2 Door 62D 10/75 to 6/77 11636 "XL" Sedan - 4 Door 54D 10/75 to 6/77 11638 "Ghia" Sedan - 4 Door 54J 10/75 to 6/77 11739 "Ghia" Sedan 2.0L - 4 Door 54J 6/77 to 12/78 http://www.rsmotorsport.com.au/ford_...scortmkii.html |
06-09-2013, 12:31 AM | #7 | ||
What is different about post pollution that will effect registering it etc? also will 3 core radiators fit? any other tips/comments/ideas thx
06-09-2013, 07:38 AM | #8 | ||
Rally Nut
If you car is a 76 1600 the pollution gear is very minimal on it, If i remeber correctly it will have a carbon canister with a couple of vacuum lines, not like the later 2 litre setup
As in your previous post on Radiators...maybe post a pic of the engine bay to work out if it has already been modified tips....for just a little run about fit 2 litre struts when you do your brake upgrade - later models have larger bore & inserts are easily found, Escorts like & handle well when they are a little lower and firmer Being a ghia it should have the twin barrel weber carb - if not fit that with a set of extractors with a nice exhaust...nothing too big 2 inch would be heaps with the age of the car I would be swapping out all the rubber bushes with nolathane Then the list car start to from there.......get it going & on the road then look at swapping things over depending on what you want to do with it quick rack, 1 piece tailshaft, adjustable strut tops, LSD, GT gearbox (close ratio - makes a huge difference), swap out the 1600 - the list could be endless..... |
07-09-2013, 01:25 PM | #9 | ||
ADR27a dulled performance, increased fuel consumption, made things run really poorly....all because the motors weren't designed to run so clean. Modern technology / redesigns means cars are very clean running these days (check the 'green' ratings') .
Would agree wholeheartedly with puzzlescort re 'tips' - bushes, fluids, check seals etc. Do some basic things to bring it back into a very usable state....and then improve whilst still enjoying it. If you go thw whole hog now.... .....it can take a long time for no return enjoyment .....the $$$ can seem endless .....you risk losing that all important little bracket to hold that thingy in place .....you can't remember how it goes back together (doh!) .....you put it back together wrong (after realising the point above) .....cars don;t like sitting around doing nothing - seals dry out, get damp/smelly inside, collect unrelated junk, etc etc .....and lastly, sadly, you might lose interest and move on to something else (or general life changes impinge) without reaping your reward for you efforts |
08-09-2013, 01:23 AM | #10 | |||
So the high compression and low compression 1.6 kents are really just pre and post pullution? are there any mk2 76s that are pre pollution from factory?
17-10-2013, 04:03 AM | #11 | ||
anyone? got a new battery for it today and got it all fitted up I have a few questions. I got a larger one I think it was 350 cranking amps however once I start it the headlights are very dull and the indicators won't work. However once I get driving it they generally will start to work. Does this mean the alternator is playing up? also the terminals aren't exactly the right size but they are very firmly attached. Hope I don't **** this battery. :( Thanks all.
17-10-2013, 07:16 PM | #12 | ||
C pillar rust is the killer, it's a big job as the original design trapped water and created the rust thru the vent, new C pillars are a custom job and require a high skill level, I had to replace both c pillars in my RS from the guard to the roof. And it about a 8 hr plus job to do at panel rates,
As the pollution bit, the early Ghia has the 1600gt engine with weber, Ford letters on the grille, blue oval grill single ford Carby and heaps less power Cost to restore any car is the depth of your wallet
RS2000 5 speed Twin 44idf webers + other goodies |
18-10-2013, 12:47 AM | #13 | |||
18-10-2013, 02:45 AM | #14 | ||||
18-10-2013, 10:23 AM | #15 | ||||||
Get some photos up of the rust and we can advise a best course of action from a fellow escort owner JP |
19-10-2013, 04:07 AM | #16 | |||
I will need to take pictures to show you better. When I said about it being welded on I mean similar to how the escorts front guards can't be removed without breaking the welds? I'm most likely confused. And I thought 1000 was cheap most 'smash' repair places only do insurance jobs and I had trouble even finding a shop that would touch it.
19-10-2013, 08:53 AM | #17 | ||
Any rust repair must be done well, a bog job will only last 6 months
Rust repair panels can be brought , except A and C pillar they will have to be made by hand, having trouble finding someone, contact your local TAFE that has a panel shop, the teachers will know who in the area specialise in rust repairs
21-10-2013, 11:25 PM | #18 | ||
my rust is similar to this and has rust where the boot opens and meets where the hard top used to end on the rear guard.
22-10-2013, 08:16 AM | #19 | |||
Muz
26-10-2013, 02:58 AM | #20 | ||
between my front and rear doors the pillars are VERY dented. What could this be from? even slamming the door, I don't see what is metal there that could seriously damage it?
26-10-2013, 09:03 AM | #21 | ||
Unusual to damaged B pillars
A and C are the rusting ones I could only guess at roll over in a previous life.? And it would be a guess
26-10-2013, 07:30 PM | #22 | ||
I posted a pic of the of the rust remove C pillar under the yass car show
27-10-2013, 06:12 AM | #23 | ||
what would be a fair price to sell this for? thinking it's more effort than I can put into it
27-10-2013, 08:42 AM | #24 | ||
That's bad news, that's the thing with escorts they are all pretty stuffed with rust and the man hours to fix is huge, check out eBay it a fair guide on people will pay
28-10-2013, 07:08 PM | #25 | ||
You might get more parting it out depending on the general state of things and what bits are on offer (again, research feebay for a guide).
Anyone out there looking for a Ghia parts car ? Sad to hear this might be the outcome. (p.s. the brand new battery will fit your next Escort purchase !!) |
