09-11-2006, 12:38 AM | #1 | ||
theres a little patch where it looks like power steering fluid on my garage floor even smells like it. anyways theres a bit on the spill cover/belt cover thingy i got, when hot (i mean hot damn tville) the level is like halfway between the hot and cold level, top it up...fine next few days the pump will start whirring and i check levels and its done to the exact same level...
checked the hoses behind and tighten/adjusted (looked like it was leaking from there) went for a bit of a drive tonight, checked levels again and its done there again but it doesnt seem to be coming from the pump now....where else might it be leaking from? but it always goes to the same level (still enough to use it) anyways any help appreciated
My Cars: 2002 Ford Falcon AU S3 SR 2006 BF MKI Falcon XR6 2008 Mazda BT50 SDX 2004 BA XR8 ute 2006 AUDI A4 B7 2013 FG II XR6 Ute 2006 Ford Territory TX 2003 Ford Falcon XR8 2009 Territory Turbo Ghia Current: 2012 Audi A4 B8 2.0T Quattro |
09-11-2006, 12:57 AM | #2 | ||
Walking with God
Can't tell without looking at it of course, but I bet the little nut that has the seals inside is gone. It's a dodgy design and often needs replacing, just had one replaced on my SR a few weeks back.
The nut is worth about $30 bucks from Ford, and you cut the old one off and slip the new one on. I didn't do this myself though mind you, so talk a mechanic mate that I hope you have. If this is the bit leaking, you'll most likely end up with PS Fluid on your alternator. All the best with it. GK
09-11-2006, 01:42 AM | #3 | |||
My kids think I'm cool
Haven't done one on a six, but mine went and I had to replace the whole thing ($130 from Repco). You can have the fittting welded on but I reckon it would be easier and ultimately cheaper to replace it, but like I say, only done a V8 one, sorry Also- make sure you top it up with Castrol Syntrans 75W85 oil and not power steering fluid- it will stuff the pump and the rack. I've said it before but just to recap- post 1996 Falcons use manual transmission oil and not power steering fluid..............
2011 FPV GT 335 >My Build Thread< (Posts 3511-3515 has a compilation of most of the pics, page 118 @ 30 posts per page) BLUESTREAK built 5.2L flat-plane-crank VOODOO with 3.2L Intercooled Kenne Bell blower, 1000rwhp/746rwkw @ 8000rpm @ 20psi on E85. Built ZF with BLUESTREAK 2C Circle D converter. Unbloodybelievable... 2018 Ford Ranger RAPTOR 2013 Audi SQ5 |
09-11-2006, 01:51 AM | #4 | ||
OLD SKOOL BABY
Is it a matter of draining the normal power steering fluid (as this is in the wifes au6), and replacing with the Castrol one? I have a new pressure hose I want to replace to.
Went to an oil place the other day to get some fluid to suit the xr8 but couldn't find any : Thanks James for the correct brand of oil. Mick
XB Sedan - Trick Mansweto built 351 3V Alloy Headed Cleveland,Demon Carby ontop of CHI Hi Rise Manifold - 600HP 83 F100 XLT - 351 Cleveland C6 Auto wrapped in Black snake skin vinyl, daily tow rig.1976 XB GS COUPE (waiting to start the rebuild)
09-11-2006, 02:14 AM | #5 | |||
It's not a big job to change it Mick........ (the pressure line on a V8 is a PITA though)
09-11-2006, 02:24 AM | #6 | ||
OLD SKOOL BABY
Thanks mate, where did you get yours?, probably have to go to a Castrol distributor is guess or would Ford have it?
09-11-2006, 02:33 AM | #7 | |||
Who would think you would need to run Manual Tranmission Oil in your P/S system?
09-11-2006, 12:15 PM | #8 | |||
i just bought some valvoline power steering fluid (one with the red au xr on the cover) thanks GK ill check that hose and the nut, power steering fluid on the alternator means disastor soon doesnt it.... should i just replace that as well?
09-11-2006, 09:25 PM | #9 | |||
Walking with God
I have used that same fluid also, it meets the Ford spec so should be fine! Cheers, GK
10-11-2006, 11:30 AM | #10 | |||
10-11-2006, 11:38 AM | #11 | ||
Posts: n/a
Power steering pressure switch/sensor. $10 fix.
