27-06-2022, 09:53 PM | #1 | ||
Old drag racer
Not real sure where to post this so will give this a try.
Base question is why did Ford bring out a HP car with a single rear wheel diff? In my extended experience over many years i have found a limited slip diff much more stable than a single wheel drive diff. Take a wet road take off as an example. Single drive diff "usually" will just power you in a straight line BUT on occasion i have had a very nasty "hook" effect usually to the left. In fact that was so bad in an EF wagon i got to the point i was actually a bit scared to do a wheel spin takeoff in the wet with this car. With a LSD i have found you can get a "fishtail" type effect which can get out of control but not nearly as quickly as with a single wheel drive diff. On the other hand i have driven many Fords with LSD rear ends and have never had this "hook" effect. Last was with a highly modified Detroit locker setup. So am asking i suppose why did Ford put a single wheel diff in a top of the line performance car? Thanks. |
27-06-2022, 10:18 PM | #2 | ||
Yep, pretty stupid, when a Holden Calais could be equipped with an LSD (even XR6 falcons in the BA series could be, and you go back further and the 108kW-less EL Fairmont Ghia had an LSD).
But, it's been 14 years since FG release, so if one really wants a limited slip rear end, there are aftermarket options galore now. Ford Australia has never really been in tune with what enthusiasts and motorists want
My Resume: Current: Alfa Romeo Giulia Quadrifoglio in Vulcano Black MY18 Black WRX STi Spec-R Previous: '16 White FGX XR8 '09 Black FG FPV GT 5th Anniversary '04 Blueprint BA XR8 '97 Mocha Foam EL Fairmont |
28-06-2022, 07:45 AM | #3 | ||
XR6T and XR8's in FG's only came factory LSD equipped....as to why well I guess they figured G6ET buyers wouldn't need it......obviously a cost thing really in the end.....I had one from new back in 2008, never really missed not having an LSD but then again I really picked my times where I pushed it in the wet....
28-06-2022, 07:47 AM | #4 | |||
28-06-2022, 08:23 AM | #5 | ||
In the older V8 Fords on rainy days, you could select 2 and take off in second gear with no nasty Rear wheel torque steer to the left
28-06-2022, 03:07 PM | #6 | ||
Peter Car
Someone in marketing would have figured the G6ET would be driven by older gentlemen who would never resort to such tomfoolery as spinning wheels. And ditching the LSD would be a nice little cost saver.
Did that turn out to be wide of the mark. Probably see more getting heavily worked over than XRT's now. I could never figure out why they didn't at least offer it as an option. |
28-06-2022, 03:23 PM | #7 | ||
Old drag racer
Fondly remember a test cell with 4 HO engines all at peak revs, red hot exhausts etc. Went home at night to come back the next morning to see 3 survived and 1 unfortunately dead. To say the engineers were excited would be a gross understatement. Test cell was completely covered in thick wood on the inside for obvious reasons. Also remember an exec driven phase 3 on the board for sale at $4250. Hindsight is wonderful.
28-06-2022, 05:36 PM | #8 | |||
28-06-2022, 05:54 PM | #9 | ||
I haven't driven a G6E but do they have ESC or Traction control at least?
Edit I'm pretty sure they do, So for the G6E being more of a Luxury car than a sports car I guess Ford decided that would be adequate Should have been an option though
______________________________ 2015 Territory Titanium RWD Diesel - SOLD 2016 BMW X5 xdrive 30D Msport Seadoo Challenger 210SE 310HP Last edited by Vesper Martini; 28-06-2022 at 06:23 PM. |
28-06-2022, 06:22 PM | #10 | ||
Was the G6E T marketed as a "performance" car?
Would guess it was to further differentiate the G6E T from the XR6 T. Have sat in a G6E T of a mechanic's car. Very nice!
~~~~~~~~~~~~~~ Rides (past and present) Current: 2004 Ford Falcon 5.4L 3v Barra 220, Manual Past: Mitsubishi Sigma (m), Toyota Seca (m), Toyota Seca SX (m), Toyota Vienta V6 (m), Toyota Soarer 4L v8 (a), BA XR8 ute (m), T3 TE50 (m), BMW Z4 (m) AFF motto - If contrary views trigger, please use ignore button. |
28-06-2022, 06:58 PM | #11 | ||
Member
Would a G6ET with LSD have earned many additional sales, or mainly cannibalised XR6 Turbo sales? It was probably a good move to differentiate them.
I assume Ford's thinking was that with a decent stability control system (which they had), you don't necessarily need an LSD. The G series DSC tune was more conservative than the XR tune I believe (which would allow the car to fishtail with the system turned on, it was great). The C63 AMGs of that era didn't come standard with LSDs in several markets either, similar thinking perhaps. |
28-06-2022, 07:14 PM | #12 | ||
I remember there being a similar thread posted in the F6, XR6T and G6ET sub-forum on this topic a number of years ago. There was some consensus that G6ET was faster in a straight line due to the single spinner. Not sure what that was based on though.
As mentioned, these were marketed as executive expresses, designed for the open road. An LSD was considered not required.
28-06-2022, 07:19 PM | #13 | ||
Similarly, the 5.4L 3v (barra 220), which I think has a flatter torque curve than the XR8, did not come with LSD either (unless it was a manual, which was rare).
Again, I think it was just a differentiating factor, aside from body kit and interior. And the barra 220 was never marketed as a "performance" car.
29-06-2022, 11:26 AM | #14 | ||
Falcon RTV - FG G6ET
Mmmm, interesting to see the comments here of 2nd hand (potential) buyers of a G6ET.
I am an older gent (69old) with a G6ET, it has been (tastefully), modified to 450rwhp. and when desired go like an express train on steroids. But only when I need it to. I don't want a 'race car', I want a car that delivers the goods for me. The G6ET fit well, I can cruise down a Motorway at the speed limit an get to where I'm going. It was designed by FoA to be an 'Executive Express', and it does deliver. Sadly for me I wanted more & set out to get it. The It, I refer to is up to the buyer. FoA was certain, if you the buyer wanted a race car, the GT & F6 & GT-P were there as a choice.
BAII RTV - with Raptor V S/C. RTV Power FG G6ET 50th Anniversary in Sensation. While the basic Ford Six was code named Barra, the Turbo version clearly deserved its very own moniker – again enter Gordon Barfield.
We asked him if the engine had actually been called “Seagull” and how that came about. “Actually it was just call “Gull”, because I named it that. Because we knew it was going to poo on everything”. |
5 users like this post: |
29-06-2022, 11:40 AM | #15 | |||
In my case I wanted all the performance plus all the luxury without needing to add any options and really wanted the sleeper looks of the G6ET... (It still bugs me to this day the G6ET had drop down lhd side mirror when reverse gear is selected and adjustable foot pedals all sync'd with each key fob while the Titanium Terry's doesn't even have them at all.) If was quite funny in my first few months of ownership in '08 and before the wider public really new what they were performance wise how much fun it was having SS drivers think they could overtake on the inside...should have handed out specs so they could read the red TURBO badging. As Boss mentioned, LSD should have been at least an option. Last edited by Dr Smith; 29-06-2022 at 11:45 AM. |
3 users like this post: |
29-06-2022, 11:52 AM | #16 | |||
fb photo upload
______________________________ 2015 Territory Titanium RWD Diesel - SOLD 2016 BMW X5 xdrive 30D Msport Seadoo Challenger 210SE 310HP |
7 users like this post: |
29-06-2022, 01:48 PM | #17 | |||
Peter Car
When my tax return comes in i'm buying a tru-trac for mine. |
29-06-2022, 01:52 PM | #18 | |||
Peter Car
Even with 300rwkw they still put the power down reasonably well with good tyres if you feed it in, and don't just mash it to the floor. 275 wide PS4S Michelins anyway. Great tyre. |
30-06-2022, 01:59 PM | #19 | |||
30-06-2022, 03:12 PM | #20 | ||
Proper Gearbox User
Whats all this if you have an LSD you'll have grip nonsense
2011 XR6 Turbo Ute - Manual - Lux Pack - Twin 2.5" Stainless Exhaust - Antz Turboside Intake - CCForged Phatlux wheels |
30-06-2022, 04:12 PM | #21 | ||
30-06-2022, 06:25 PM | #22 | ||
Proper Gearbox User
You missed my joke.
I have the ute in my signature. Even standard with an LSD fitted grip is minimal. Add some mods and T/C just throws its hands in the air
30-06-2022, 06:27 PM | #23 | |||
30-06-2022, 06:49 PM | #24 | |||
Proper Gearbox User
But i also disagree. With the way prices are with turbo falcons now, i think that desire to churn out massive power might have diminished. Seems people wanting them prefer standard/less wild versions. I know if i were buying again id want a standard one, as i did when i purchased mine.
30-06-2022, 07:29 PM | #25 | ||
Very regular
I remember stamping my feet at the local Ford dealer when I found out that the G6ET came without the LSD, whilst on the lowly XR6T it was standard. “Not even an option? Really? FFS!”
Figured I’d ring Ford direct and got hold of some old buzzard deep in the bowels of the Ford factory who claimed she was part of the Direct Customer support/liaison team (or something similar) and she simply said “nyet”. Anyway, she ripped me a new one, told me I was more than a little forward in ringing the factory direct and then promptly terminated the call. She ended the call even quicker when I rang back next time! So has it really matter not having the LSD? I can say after 14 years, not at all. The only issue was that initially when I had it, it spent a lot time travelling from point A to point B at warp 7 and it wore out a couple of sets or rears, one side wearing quicker than the other. These days it’s only driven on the odd occasion sedately around town when it’s pulled out of storage and the non existent LSD isn’t missed. As an aside, took it for a rip down through the Adelaide hills over the last couple days to give it a descent run and they’re still a great vehicle to do a road trip in. It’s comfortable, has more than enough power when you want it, and it still feels planted through the wiggly bits. You wouldn’t think it was a 14 year old motor car.
G6E Turbo Ego Cashmere .....The velvet sledgehammer |
4 users like this post: |
30-06-2022, 07:38 PM | #26 | |||
Unmodified stuff always has the higher price tag. |
01-07-2022, 06:58 AM | #27 | |||
01-07-2022, 09:02 AM | #28 | ||||
It would have been a waste of money developing and maintaining it as an option given the likely uptake and little return of this option. It would be similar to why BF FPV's never got DSC. FPV couldn't afford to develop a DSC tune for these vehicle combinations, so it remained a ABS/TCS braking system and advertised it as "real FPV drivers don't want/need an interfering stability control system". If they couldn't afford to amortise it over all the cars they made then LSD as an option would be even less of a probable business case for the G6ET. So just save the money. Quote:
My favourite was coming off the old Kings Way exit in Melbourne with this d*ckhead in some clapped out VT or VX egging me on down the exit. I'd speed up and brake very late (because I could) all the way down the exit, semi normal driving for me while still having my bit of fun. It was early Saturday night, so traffic was a bit busy. Get to the bottom of the exit and light turns yellow so I hammer through knowing I can make it and stop quickly behind the cars at the next set of lights. Thought I'd finally be free of d*ckhead. But no, Mr Hero, d*ckhead of the clapped out Commo, attempted the same, but his brakes were nowhere as good and rammed the rear end of the car in the next lane at prob 30 or so km/h. I remember just sitting there looking at him giggling while Mrs D*ckhead in the passenger seat ripped him a new one. |
01-07-2022, 12:06 PM | #29 | |||
Peter Car
FPV's were a different case on BF's because they had suspension/wheels etc that were different from XR. They had 19's and Brembo's when BF XR didn't have that option. Those 2 things do change the way the DSC would react, as it brakes individual wheels, and the 19's would have had different grip levels to the 18's. I know one of the brake department engineers who does EBD and DSC calibration. I'll ask him next time I see him, if I remember. |
01-07-2022, 12:09 PM | #30 | ||
Peter Car
