14-02-2012, 10:57 PM | #1 | ||
Hey guys, just changed the coil pack in the mothers AU2, it all went smoothly (so i thought), until i put it all back together and fired it up and its running very rough, and theres a strong smell of unburnt fuel.
I double checked ive put all the leads back correctly, and also everything else looks fine. Any ideas would be great, thanks guys.
'96 EL Fairmont Ghia 5L |
15-02-2012, 12:46 AM | #2 | ||
When in doubt, GAS IT!!
Check it again, two of the leads must be out of order.
Bushbasher
15-02-2012, 01:30 AM | #3 | ||
Got Ghia?
didn't managed to disconnect the map sensor?
2007 BF MKII Ghia V8 - BA GT Exhaust| F6 Intake | Superlows | 19" GT-P's | 30mm Swaybar | - Sold 2002 AU2 XR8 Ute - Manual | Leather | Injected LPG | Pacemakers |
15-02-2012, 09:59 AM | #4 | ||
U got a coil pack of a wreck for cheap and it's ******?
15-02-2012, 10:24 AM | #5 | ||
I checked many times that their all in the correct spot, as i said in the original post.
Where abouts is the map sensor?? No i bought a new coil pack, i dont buy any second hand parts..
15-02-2012, 11:18 AM | #6 | |||
AU DIE HARD
Sounds like it could be a Dud, put the old one back on and see if it is,then go from there .
17-02-2012, 06:00 PM | #7 | ||
Any update on this OP?
Did you remember to reattach the electrical component (a capacitor if I remember correctly) that has a spade connector that sits under one of the "legs" of the coil pack? Have you tried disconnecting each spark plug in turn (with engine off) to see if there's any change in the engine note... or in this case, probably more likely, NO change when it's unplugged? Sounds like you haven't replaced the leads. How old are they? Is it possible you've damaged one when replacing the coil? |
18-02-2012, 03:03 PM | #8 | ||
Got it sorted mate, one of the leads was damaged on the coil pack side, new set of leads and good as gold!
