Old 17-02-2010, 12:21 AM   #1
AU00XR8
AU00
Default AU2 XR8 fuel pressure?
Hi All,
I have a AU2 XR8 200kw and was wondering what pressure the pump should be pushing out. Also when i boot it should it give more pressure??
The reason i ask is when i boot it the car seams to lag like it is not getting enough fuel..
Thanks
: http://www.aufalcon.com.au/cgi-bin/index.cgi?act=item&i=549
AU00XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 17-02-2010, 02:33 AM   #2
mik
mik's Avatar
6 cylander and v8 pumps deliver a maximum out put of 85 litres per hour at 300 kpa,
idle pressure 225 kpa
in another part of the book it says (i6ho) 300 kpa and it reads like the v8 might be 275 kpa delivery , so i`d say between 275 and 300 kpa , it also says maximum pressure drop once switched off is 10% in 10 seconds from max ellerys shop manual .
Old 17-02-2010, 07:48 PM   #3
hankb
If the pump can deliver 240ml of fuel in 10 seconds @ 275 kPa she's good.
hankb is offline   Reply With Quote Multi-Quote with this Post
Old 19-02-2010, 10:40 AM   #4
xr8ute
Back on the road
xr8ute's Avatar
The fuel pump delivers the volume, and the regulator sets the pressure.
The AU 200kw XR8 has the standard fuel pressure reg; 39psi at the fuel rail with the vacuum reference disconnected.
The fuel pressure regulator maintains a constant pressure drop across the injector e.g. as manifold vacuum increases, fuel rail pressure is reduced and vice versa.
Old 24-04-2014, 06:49 PM   #5
Chucks_XR6
Cool Re: AU2 XR8 fuel pressure?
Originally Posted by AU00XR8 View Post
Hi All,
Thanks
I got same issue now as I just replaced maf sensor
Leads tps sensor a dead injector .... Now I have a new problem
Chucks_XR6 is offline   Reply With Quote Multi-Quote with this Post
Old 24-04-2014, 07:20 PM   #6
Chucks_XR6
Default Re: AU2 XR8 fuel pressure?
Can some one send me a pic of the fuel vacuum regulator???
To chuck14u35@hotmail.com please it's urgent
Old 24-04-2014, 07:23 PM   #7
Chucks_XR6
Can some one email a pic of the efi vacuume reg
Chuck14u35@hotmail.com as I'm fitting nos ATM and
Wanna make sure I'm doing it right
