Old 26-04-2005, 06:09 PM   #1
Casper
Contributing Member
Casper's Avatar
Default AU Fairmont Ghia Diff Ratio?
Just curious, what diff ratio did the AU Fairmont Ghia sedans get? I'm sure most were not LSD but were they 3.45 or something else?
Older, wiser, poorer.
Old 26-04-2005, 06:12 PM   #2
jonbays
TL40 Wagon?
AU Fairmonts all of them auto's no manuals available got 3.23 diffs but the Ghia got IRS and 3.45 but none got LSD although it was an option
jonbays is offline   Reply With Quote Multi-Quote with this Post
Old 26-04-2005, 06:15 PM   #3
Casper
Contributing Member
Casper's Avatar
So the Ghia got the same diff as the XR6 but no LSD right?
Old 26-04-2005, 06:20 PM   #4
Perana
Perana's Avatar
Ghias didnt get LSD and wasnt an option either as they had 4 channel ABS and Traction control (which would put the brakes on the spinning wheel thus transferring drive to the other wheel) and im pretty sure it was 3.45:1 ratio
'09 SYII TTG | Mystic
'06 BF XR6 | Mercury Silver
Perana is offline   Reply With Quote Multi-Quote with this Post
Old 26-04-2005, 06:58 PM   #5
jonbays
TL40 Wagon?
The fairmont Ghia and the VCT XR6 in auto have exactly the same drive train. ecu changes the gears differently and the 215/55R16 vs 235/45R17 tyres and wheels is the only difference i can think of.
Old 26-04-2005, 08:42 PM   #6
buickman
buickman
buickman's Avatar
You are correct. The XR's got adaptive shifts in the autos where the ghia did not. Traction control great in wet conditions.
buickman
buickman is offline   Reply With Quote Multi-Quote with this Post
Old 26-04-2005, 08:49 PM   #7
Casper
Contributing Member
Casper's Avatar
Thanks, just needed to know what the std diff ratio was.
Old 27-04-2005, 12:10 AM   #8
AUGhiaV8
Posts: n/a
LSD was not fitted and was not an option in the series one but was optional in the series two onwards - I'm unsure of the ratio though. My diff in the S1 Ghia was a 3.23.
Old 27-04-2005, 05:32 PM   #9
jonbays
TL40 Wagon?
Yes just to get it right in the AU fairmonts all 6's and V8's got 3.23:1 diff ratios.
AU Fairmont Ghias with VCT I6 got 3.45 diff with no option for LSD ( traction control fitted)
AU fairmont Ghia V8's 3.23 diff as above
LSD was an option on all non IRS models in AUI but dropped in AUII/AUII when traction control became standard across the range not just in the Ghia.
Old 30-04-2005, 05:07 PM   #10
|2aebird
Resident Volvo Driver
My series 1 Au Fairmont 5ltr has 3.23LSD...
|2aebird is offline   Reply With Quote Multi-Quote with this Post
Old 30-04-2005, 09:25 PM   #11
jonbays
TL40 Wagon?
Exactly all fairmonts got 3.23 diffs LSD an option on S1 cars so yours was optioned up.
Old 02-05-2005, 07:02 PM   #12
TCK-098
TCK-098's Avatar
Well mines got 3.45 and no .L.S.D but does two legged marks i think my center is fooked and the traction control i hate.
18 T6 Multivan
03 Ba Xr turbo 300rwkw
TCK-098 is offline   Reply With Quote Multi-Quote with this Post
Old 06-05-2005, 08:46 PM   #13
the black pig
the black pig's Avatar
Default erm? er?
Yeah. 3.45 diff, switchable traction control, and
switchable economy/performance shift patterns.
I leave the trans in performance mode alla time
and hit the TC-off button when I get in the car,
xcept if it's raining I leave it on.
a silver pig
the black pig is offline   Reply With Quote Multi-Quote with this Post
Old 07-05-2005, 12:37 PM   #14
b2tf
not here much anymore
b2tf's Avatar
Our is an S2 Fairmont Sedan (non Ghia) and it has a 3.45 diff, which im told is a bit unusual. Was an ex Ford exec car though so that may explain it.
RAM 1500
Old 07-05-2005, 03:20 PM   #15
jonbays
TL40 Wagon?
back2thefuture that is odd as in the AUII they dropped the LSD from the option list in the Fairmonts.
Not to say it couldn't be done as the option was still there for the AUII Forte and Futura.
Old 07-05-2005, 10:23 PM   #16
AUGhiaV8
Posts: n/a
Every thing I have says LSD's wern't ever optioned for S1 Ghia's... only S2 onwards.
Old 07-05-2005, 11:07 PM   #17
b2tf
b2tf's Avatar
Same here, i was under the impression that there were problems getting the LSD to work with the traction control which couldnt be rectified till S2.
RAM 1500
Old 08-05-2005, 10:51 AM   #18
jonbays
TL40 Wagon?
No AU Fairmonts came with LSD as a standard feature.
AUI Fairmonts except Ghia's or models with IRS option had the option for LSD.
AUII/AUIII Fairmonts the option for LSD was dropped.
I agree that traction control is the most likely reason as in AUII on traction control became standard across all Fairmonts not just the Ghia.
Here is the AUI brochure on the forum.
http://www.fordforums.com.au/photos/...cat=728&page=1
I can post up the AUII spec brochure if you want to compare them.
