Old 20-05-2012, 06:40 PM   #1
bunnyr31
Default msd's and 9mm now breaking down
as title says i just put msd's and ice 9 mm leads on my series 1 xr8 and whenn i hit 4000rpm the car brakes down and struggles and push higher in the rpm... any ideas
bunnyr31 is offline   Reply With Quote Multi-Quote with this Post
Old 20-05-2012, 06:46 PM   #2
dc_todd
Seasoned Visitor
Default Re: msd's and 9mm now breaking down
collapsed cats?
blocked fuel filter?
Air filter?
fuel pump starting to die.
could be a number of things. have you swapped back to the original coils to test if the MSD's are faulty? Assuming it was running fine before. If you have only changed 2 things being coils and leads and it was fine before, one of those 2 things is not working properly. basic deduction.
dc_todd is offline   Reply With Quote Multi-Quote with this Post
Old 20-05-2012, 06:57 PM   #3
bunnyr31
originals were snapping at the plug on one the them ... but ran alright ... dont have them on me atm to test tho ... ... wouldnt collapsed cats hinder the ability to reach 4000rpm comfortably ??? when my skyline dumped its cat it sruggled to my any power let alone high end power. i might be wrong and correct me if i am
brand new air filter also
Old 20-05-2012, 08:51 PM   #4
dieseltrain79
Broken plug ? Or faulty new lead ?
1998 AU VCT Ghia - Stock as a rock - Wifes car
1991 Toyota Soarer TT - 11.72 @ 116.7mph
2004 Ford Escape XLT V6 - Family Ride .
dieseltrain79 is offline   Reply With Quote Multi-Quote with this Post
Old 20-05-2012, 09:40 PM   #5
b2tf
not here much anymore
b2tf's Avatar
Put new plugs in it, if the plugs are worn the extra voltage from the MSD's can finish them off.
RAM 1500
Old 21-05-2012, 02:37 AM   #6
BOTTLEDUP
New plugs & have you got the firing order correct?
BOTTLEDUP is offline   Reply With Quote Multi-Quote with this Post
