Old 03-09-2011, 06:45 PM   #1
SirHenry
Falcon Unbelievable!
Default Throttle Body Cleans
Well after about 7 years of owning my AU I finally did a throttle body clean and replaced the air filter after trying to fix an annoying miss in the low rev ranges.
I used to be a non-believer of throttle body cleans (you know the how important could it possibly be mindset) well let me say after cleaning it ...
WOW! What a difference it makes to the power. I didn't realise how much power it had lost and how much it gained back after throttle body clean and air filter replacement.
Oh yeah the crud that came off the body and plate unbelievable.
I think it may have fixed the miss in it, if not it has certainly improved some much needed performance.
SirHenry is offline   Reply With Quote Multi-Quote with this Post
Old 03-09-2011, 08:15 PM   #2
dieseltrain79
Default Re: Throttle Body Cleans
DId you install new spark plugs afterwards ?
As normally shops will use the TB cleaner before changing plugs as they foul .
1998 AU VCT Ghia - Stock as a rock - Wifes car
1991 Toyota Soarer TT - 11.72 @ 116.7mph
2004 Ford Escape XLT V6 - Family Ride .
dieseltrain79 is offline   Reply With Quote Multi-Quote with this Post
Old 03-09-2011, 09:24 PM   #3
SirHenry
I've just changed the plugs before I cleaned TB
Old 03-09-2011, 10:59 PM   #4
rowan194
I'm also a fan of throttle body cleaning, makes a BIG difference... I noticed the improvement mainly when cruising and needing to accelerate a bit (eg overtaking), it's like it just pushes ahead rather than labouring for a moment, kicking down a gear then taking off.
I used clean lint free paper towel so I could clearly see the black deposits I was wiping off.
Here's something else I tried recently...
http://www.nulon.com.au/products/Aer...ntake_Cleaner/
This is a little different because you can also spray it into the spark plug holes to clean the piston crowns. I noticed sizeable improvement after doing this, taking off it's like it has a lot of extra oomph. At first I thought it was a placebo effect or self fulfilling prophecy (foot gets subconsiously heavier because I'm expecting a change) but the next day I wasn't even thinking about it and suddenly noticed how much more power it had when I first started off.
Never heard about throttle body cleaner fouling sparks? Surely you'd want to clean your TB more often than you replace your sparks?
rowan194 is offline   Reply With Quote Multi-Quote with this Post
Old 03-09-2011, 11:26 PM   #5
dieseltrain79
No need to over clean throttle bodies . Thats why most places will do it when changing plugs ( which i recommend changing them alot mroe often than the 25-50k dealers say ) .
Cant really say i felt a difference on the AU , then again its a slug compared to my other car .
Old 04-09-2011, 11:37 PM   #6
hendoau99
app diesel mechanic
i did a TB clean about 2 months ago. and i will agree that there is a massive difference in throttle response and just general feel. i don't think mine had ever been cleaned by the gunk i was faced with. big difference IMO.
daily driver: au series 1.5 forte sedan
mods: clarion head unit, 15" alloys, ex police sump guard, futura grill,clear side flashers, AU s2 tailights,BA xr6 spoiler, kenwood 12" sub, kenwood 250W amp, kings sports lows, 2.5" lukey catback.
mods to come: rims!!
hendoau99 is offline   Reply With Quote Multi-Quote with this Post
Old 05-09-2011, 12:30 AM   #7
Day-mow
rexnet
Day-mow's Avatar
just spray in carby cleaner and clean out with a lint free cloth yeah?
MY06 WRX Build Not Bought
Collingrove Hill Climb- 38.79
Remember it is the internet,So beware of trolls, If you argue with trolls the kids will laugh at you
Follow me on twitter @ Day_mow
Day-mow is offline   Reply With Quote Multi-Quote with this Post
Old 05-09-2011, 12:45 AM   #8
raised by monkeys
raised by monkeys's Avatar
3) Piston crown cleaning:
While the engine is still turned off, remove all spark plugs. Spray a 2 second burst into each spark plug hole. Leave the engine to stand for 5 minutes. NOTE: Before reinstalling the spark plugs, cover up the spark plug holes with clean unused paper or cloth and crank the engine several times. Reinstall spark plugs.
crank engine without plugs?
cheers
Shaun
Current
SY FPV F6X Territory #214
Previous
FG MkII G6E Turbo built by Heinrichs Performance and Tuning
BFII FPV TORNADO #0021 351rwkw - Heinrich Performance and Tuning
"Milk is for babies. When you grow up you have to drink beer" - Arnold Schwarzenegger
raised by monkeys is offline   Reply With Quote Multi-Quote with this Post
Old 05-09-2011, 01:09 PM   #9
rowan194
Yep. I used a big wad of screwed up paper towel to make sure the ignition lead ends were sitting well away from the block and other grounded metal. If you're really paranoid you could disconnect the coil pack control wiring (not the ignition leads) from under the car.
Sounds very strange when you crank it, I guess because there's no compression?
Guess I should have the accel pedal to the floor when cranking so the injectors don't fire? Didn't think of that until afterwards.
Unlike the demo video I didn't have any brown gunk splattering onto the paper covering the spark plug holes... I did it 3 times and they still came out clean... anyway, still made a diff.
Old 07-09-2011, 06:44 PM   #10
rowan194
Re: Nulon foaming cleaner
I've gone through nearly a full tank since, and my fuel consumption has dropped by roughly 1L/100km. The consumption is still excessive for some reason (see http://www.fordforums.com.au/showthread.php?t=11341363 ), but the foaming cleaner seems to have shaved a fair bit off the base consumption level. Can't wait until I fix the other prob to see how that improves things again.
1L/100km for the average car/driver is 200L of fuel saved per year! Even if it shaved only 0.5L or 0.25L/100km off it's still a significant saving, compared to the cost of the product (I think it was $12)
Another way to give your car a bit of extra oomph is to disconnect the battery and retrain the ECU/trans. My auto changing from first to second used to be a bit of a slap on the back, now it's nice and smooth.
Old 07-09-2011, 11:42 PM   #11
Day-mow
rexnet
Day-mow's Avatar
i think im going to have to give this cleaner stuff a go
Old 08-09-2011, 11:18 PM   #12
rowan194
Anyone using a catch can to lessen the gunk building up in the first place? Do they work? (And are they legal?)
Old 09-09-2011, 07:40 PM   #13
rob_liss_lms10
rob_liss_lms10's Avatar
I have been using a catch can for a couple of yeaRS NOW, THEY CERTAINLY COLLECT A BIT OF OIL, SO WITHOUT THE CATCH CAN THE OIL WOULD HAVE GONE INTO THE ENGINE. nOT SURE IF THAT REALLY MATTERS THOUGH. aFAIK THEY ARE COMPLETELY LEGAL AS LONG AS THEY ARE PLUMBED CORRECTLY.
sorry for caps, hit button while typing and cant be bothered retyping it all, mainly cause I have already forgotten what I wrote.
Red bull gives you wings?: nahhh.... we got our wings from TICKFORD
rob_liss_lms10 is offline   Reply With Quote Multi-Quote with this Post
Old 09-09-2011, 07:46 PM   #14
Day-mow
rexnet
Day-mow's Avatar
hahaha thanks for my daily lol
Old 09-09-2011, 08:11 PM   #15
Stav
Smile
Stav's Avatar
The best way to clean the throttle body is to remove it on the au. The reason is that the crud flows down to the map sensor and clogs that as well. Remove it..clean it and then bolt it down.
