08-04-2008, 12:11 PM | #61 | |||
Sales Representative
Drove around Mount Panorama last night and not 1 singe glitch... Anyone know what sort of thermostat is needed for LPG?
Project InfernoSR - Back Burner Project FeralTerra - No longer Project Fairmont Prodigy - Sold Thanks go to: MY WIFE! Bathurst Brakepro Undacar eBay!! |
08-04-2008, 04:40 PM | #62 | ||
Thermostat wise, i've been told to just get the hottest one out there... 92degC...
Talked to LPG guy... hopeless... Want to replace the Stepper Motor as once previously discussed... been qouted $400 from Ford... and the LPG guy claims that with factory Dual Fuel, only the genuine Ford part works.... can anyone clarify this or offer other advice/info...
08-04-2008, 06:18 PM | #63 | ||
Blueprint,
My dual fuel wagon was tending to stagger and sometimes stall just about every time we got to this one particular corner - for no good reason. Probably something to do will rolling down a slight drop and then turning left up hill. My AU is an auto but now I change down just before that corner and I think that the slightly higher revs are doing the trick.
. . Rob Ewart Bog standard silver BF Wagon, except for the Elvis doll , on gas. Victorian Rock'n'Roll Dance Association www.VRRDA.com.au 2015 Victorian Rock'n'Roll Dance State Championships 23 May 2015, Furlan Club, Thornbury |
08-04-2008, 07:33 PM | #64 | |||
08-04-2008, 08:39 PM | #65 | ||
Critical Thinker
Could it be something to do with the pick up or the float inside the tank?
08-04-2008, 08:46 PM | #66 | |||
13-04-2008, 04:42 PM | #67 | ||
Cleaned ISC motor... stalled again today... seems to be when the nose is in a decline... stepper motor?
13-04-2008, 08:44 PM | #68 | ||
is the idle mixture set properly? i know on mine before i set it up properly it would stall coming to a stop going down hill nearly all the time. i don't know what sort of adjustments impco converters have got, but omvl's have got an idle screw and a sensitivity screw, if it has both, then try turning the sensitivity one in until you hear the engine start labouring, then open the idle one out until it revs back up and sounds like it's idling normally, then see how that goes
14-04-2008, 09:30 AM | #69 | |||
15-07-2008, 01:45 PM | #70 | ||
About time i re-opened this... by simply saying... "it still aint going" :(
15-07-2008, 05:00 PM | #71 | ||
Jim
I adjusted my idle screw on mine so it still idles with the ISC disconnected. It idles just about 100 rpm lower (500-600RPM) and reconnected my ISC, doesnt do that drop the revs to 200 thing and just about stall anymore
The Daily. White 2017 ZG Escape TDCI AWD Wagon The Wifes. Grey 2015 MD Mondeo TCDI Hatch The Old Daily.......2003 Octane BA Taxi Pak Egas Falcon Build Thread |
15-07-2008, 11:15 PM | #72 | |||
15-07-2008, 11:38 PM | #73 | ||
Jim
idle screw on the throttle body not the convertor
16-07-2008, 11:15 AM | #74 | |||
16-07-2008, 11:30 AM | #75 | ||
Jim
on the throttle body where the linkage is for the accerator cable you should see a screw that you can adjust base idle for the ISC using a .75 feeler gauge. Screw this in a few turns so the car will idle without the ISC connected. (warm it up first tho). and set it to idle approx 500 to 600 rpm without the isc connected. replug in the ISC and revs should jump to approx 750 rpm. your done.
You might have to take off the plastic tube that sits on the inlet manifold to the throttle body to get it loosened properly cos they have this crap on it from the factory. trick here it to back it off first and get rid of this crap before you screw it in. when replacing the plastic bit on the manifold put some Sensor safe silicon around the t/boddy so you get a good seal as well.
16-07-2008, 11:32 AM | #76 | |||
16-07-2008, 11:37 AM | #77 | ||
Jim
it will stop it stalling when you do a sudden decelleration. isnt that what you trying to fix???
16-07-2008, 11:40 AM | #78 | |||
16-07-2008, 11:47 AM | #79 | ||
Jim
here you go just took a pic
16-07-2008, 09:12 PM | #80 | ||
I was talking to the guy that did my install the other day cause mine has a bit of a starting issue and he was telling me there is some crappy gas getting around. He showed me a converter that he stripped and there was this black sludge like crap inside. Might not be anything to do with yours but thought I'd share it with you.
16-07-2008, 10:20 PM | #81 | |||
