Old 19-01-2021, 01:25 PM   #1
mcfee03
Default Creating a spare key
Hi all,
I recently bought a Ford Focus 2011 LW. It only came with 1 key.
For sanitys’ sake- I would like to cut a spare.
  • What is the cheapest option (no remote is ok)?
  • Do I need to look for a specific chip? If so, which chip?
  • Can I program the key myself? Or is special equipment required?
  • Is it safe to buy a key from eBay (generic one) as long as its’ the same shape?
FYI, my key looks like this:
https://www.eurocarkeyshop.com/frd14...m-product.html
Thanks
mcfee03 is offline   Reply With Quote Multi-Quote with this Post
Old 19-01-2021, 02:44 PM   #2
11ford11
Default Re: Creating a spare key
See if locksmith can clone a key for you
Old 19-01-2021, 02:53 PM   #3
mcfee03
Yes they can, but by expensive to do ($250).
Was looking for an alternative
Old 19-01-2021, 04:58 PM   #4
marg99
keys have a chip in them that needs to be recognized by car computer as well as the key having the right teeth to turn the barrel.
Old 19-01-2021, 11:37 PM   #5
mad2
Regular...with metamusal
Originally Posted by mcfee03 View Post
Hi all,
Thanks
is that 'similar' to the BF/FG style of flip key? [looked at link & not sure]. if it is 'same' same ... would just need to check if chip is compatible with your car.
Old 20-01-2021, 10:37 AM   #6
mcfee03
Not sure it is similar to BF/FG. It is NOT the one with one side curved. Mine is fatter, and curved on both sides.
This might be a better angle:
https://www.ostanlock.com.au/wp-cont...3060352782.JPG
Yes exactly- but how do I know which chip is compatible with my car?
I've seen guides which show a simple process to program the key: turning the key "n" times in the ignition (to position 2), then simply pressing the lock/unlock buttons on the new unpaired key. Are they not correct?
The ones i"m looking at on eBay say they're 433Mhz & the 4D63 chip, and a HU101 blade
Old 20-01-2021, 02:24 PM   #7
11ford11
Turning key on and off only programs the remote not the key chip to the vehicle body module to allow it to start iirc.
How much does Ford want ?
Old 20-01-2021, 06:03 PM   #8
mcfee03
I see. I haven't asked Ford, but a locksmith is $260 + (that's for the remote). $160 if I'm happy with key'ed entry/starting.
Remote isn't important, I really just want a "peace-of-mind" spare that doesn't cost a heap. Any suggestions around Sydney or Coffs Harbour?
Old 21-01-2021, 02:18 PM   #9
11ford11
Price a clone thru mr minute or similar in shopping centres
Old 21-01-2021, 05:07 PM   #10
mad2
why would you want a useless clone as it still leaves you with only the one key that the car recognizes ?
have two cars bought with one key for each. i bought keys to match both cars [along with matching chip] so now both cars have three individual keys per car, and it IS so easy to do. blank keys were $24/25.50 for a pair to suit BA/BF. it then cost me $33 per key to be cut [so $66 for two keys cut per car] & then using ForScan i was able to program the keys to both cars which otherwise would have cost me $144 to cut & program thru the locksmiths [not sure if that was per key or not?].
have even swapped upper column over on my wagooon & programmed the keys ... again using ForScan & a laptop.
Old 21-01-2021, 05:38 PM   #11
mad2
ok, that key 'looks like' an aftermarket BF/FG key [altho i'm not sure, but the pic below it is an aftermarket flip key i believe?] & no you cannot program the main keys that way at all. i have bought these keys & programmed them to the car myself. https://www.ebay.com.au/itm/2-x-tran...72.m2749.l2649
and this is your 'style' re 'flip style' - https://www.ebay.com.au/itm/REMOTE-F...cAAOSwIzNXOt4m but i have no idea re chip.
Old 23-01-2021, 09:46 AM   #12
11ford11
It leaves you with 2 working keys that start your vehicle
But is only recognised as 1 key if you need to program a replacement engine computer or bcm and the op seems to be looking for the cheapest option and if to expensive you say thank you and walk away
I believe you will find the bf key is the same shape but uses a 4d60 chip but you require a 4d63 chip for the Focus
Don’t know enough about Forscan myself but don’t you need to purchase the extended licence to be able to program keys
Old 23-01-2021, 08:22 PM   #13
mad2
ForScan comes in very handy for the furd! ... yeah you don't need the extended licence as you can get a 'temporary' use licence which is just as goood.
as too the chip .......... no idea.
