Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Blue Power Racing Developments
Blue Power Racing Developments The home of Blue Power. Website Link
Old 21-02-2008, 03:03 PM   #1
OJ_Pursuit
OJ_Pursuit's Avatar
Default Thanks bluepower!
Well Im rapt, I just fitted the Bluepower cold air intake kit to my mkII Pursuit.
I thought it was fairly simple to fit, and the air cleaner is massive!!
Went to take it for a quick squirt down the road... WOW cracked the throttle wide open and the sound is insanely addictive he he thought it made
the exhaust bark louder. It is evil sounding now, you can burble along sedately... and then when you give it a bit, it sounds like the hounds of hell being unleashed!
Next step is to add some headers and cats to complete the exhaust side of things.
Quick question: I have an 80mm throttlebody sitting here, does anybody know if they make a noticable difference on the 290?
2004 BA MKII FPV Pursuit 6sp manual in Mandarin
MMR Built short motor, all the good gear.
Kenne Bell 2.6 intercooled kit from BPR
Tuned by Xtreme Ford Tuning - 400rwkw
Build thread here
OJ_Pursuit is offline   Reply With Quote Multi-Quote with this Post
Old 21-02-2008, 03:32 PM   #2
Grum
Bringing the Spartan back
Grum's Avatar
The 80mm TB goes great on my 260, can't see why a 290 would be much diff!
East Coast Suspensions
Road - Race - Performance & Prestige Car Service
BOSS 5.4L Silicon hose kits for sale
BA/BF FPV parts for sale
The only negative thing in your life should be camber
Blue Power Racing Enhanced
Chris & Craig - Thanks!
Grum is offline   Reply With Quote Multi-Quote with this Post
Old 21-02-2008, 03:42 PM   #3
OJ_Pursuit
OJ_Pursuit's Avatar
Thats why I have it laying about, I had it on the 260 and didnt notice much improvement, so I took it off and put the stock unit back on.
Im thinking I might give it a go, seeing as it only takes ten minutes to swap.
Build thread here
Old 21-02-2008, 05:12 PM   #4
Grum
Grum's Avatar
What 80mm TB is it? Mine feels like it goes harder on part throttle and fells much smoother through the rev range.
Old 21-02-2008, 06:05 PM   #5
OJ_Pursuit
OJ_Pursuit's Avatar
Im pretty sure its a BPT one, I think they used to do them on an exchange basis
Build thread here
Old 21-02-2008, 10:01 PM   #6
DABOSS
BA Black Edition
DABOSS's Avatar
Had one on when they first came out , bugger all difference, it was like 1 - 2kw..on the dyno.
"With enough money anything can be done"
"First BA to run a 12 on street Tyres and full weight back in the day, And still the quickest street BA GT in OZ"
DABOSS is offline   Reply With Quote Multi-Quote with this Post
Old 21-02-2008, 11:27 PM   #7
XRQTOR
XRQTOR's Avatar
If im not mistaken Wade took his off his car, on a 32orwkw odd car it made bugger all difference.
XRQTOR is offline   Reply With Quote Multi-Quote with this Post
Old 22-02-2008, 12:51 AM   #8
OJ_Pursuit
OJ_Pursuit's Avatar
Yeah your both right, made bugger all difference. In fact it ran like snot for some reason
the revs wouldn't settle back to idle... the idle was about 300rpm higher when it did settle down but mostly stuck on about 1700rpm, which made it hard to drive. I couldn't figure out whether it was damaged somehow or maybe it has been tuned at some stage.
I had it on my xr8 a while back and it worked fine on that? weird
Build thread here
Old 22-02-2008, 09:11 AM   #9
MYV8
Gota be happy with a Hump
MYV8's Avatar
Tried one with the inbuilt helix on mine for a short while. Most unimpressive on my car, so went back to the original.
:BA XR8 Ute Auto (Now with Pump Gears) :
12.756 @ 107.16..........1.915 60'
Genuine Unopened Time
BluePower Racing Developments ............... Best in the Business
MYV8 is offline   Reply With Quote Multi-Quote with this Post
Old 22-02-2008, 11:04 AM   #10
SpoolMan
Solution Was Boost 4?, 6 & 8
SpoolMan's Avatar
Chairman's Award: Chairman's Award - Issue reason: The exceptional contribution made to AFF events and sponsorship. Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Everything you do to help this place run smoothly! Technical Contributor: For members who share their technical expertise. - Issue reason: The awesome Technical and Service how to's in the FPV /XR6 /G6ET turbo threads..  and his own build threads that inspire people to have a go... enabling people to save money and realise the dream of working on their own cars as well.
Always had one on my BA XR8 very slight increase at the top but this also seems to loose a little down low.
If you have one sitting around you may as well try it, takes a few minutes to fit.
Or put it on ebay late last year we had 2 fetched around $400 to $450ea they were both used.
[SIGPIC][/SIGPIC]
AUTOTECH TUNED EDELEBROCK CHARGED
2017 GT Mustang Plenty of RWKW
SpoolMan is offline   Reply With Quote Multi-Quote with this Post
Old 22-02-2008, 09:54 PM   #11
Quadcams
Quadcams's Avatar
Location: Working, chasing after my daughter and working
Yeh had one on my car, caused more hassle than what there worth, erratic idle ran rougher with it on, they work about as good as a helix spacer great paper weights.
Quadcams is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2008, 01:14 PM   #12
OJ_Pursuit
OJ_Pursuit's Avatar
Yeah, anyone want a s/h 80mm throttle body?? lol
Next mod will be oil seperators I think, back of the stock t/b was black with oil
and probably some oil pump gears. Oil pressure seems to drop fairly low on idle once the engine is up to temp.
Build thread here
Old 23-02-2008, 05:08 PM   #13
Grum
Grum's Avatar
I can't fault mine at all! Maybe they are little help with the stock pod and snorkel? I am running BPR box, Larger power pipe and the shaker. I guess the air can't get in any faster if there is still the 75mm TB fitted so the 80mm unit compliments the rest of my CAI? Who know?
