Old 09-12-2016, 02:10 PM   #1
marcusturbo
marcusturbo's Avatar
Question Recirc Flap
2009 TDCi Titanium
When I push the button for the recirc flap on the control panel nothing happens anymore. I think the flap is stuck (open position) or the little solenoid that operates it is not working.
As you know the air-con is not the best and needs all the help it can when keeping the temp down on +35'C days.
Q: Where is the recirc flap and how do you get into it.
Accept that some days you're the pigeon & some days you're the statue.
marcusturbo is offline   Reply With Quote Multi-Quote with this Post
Old 09-12-2016, 03:07 PM   #2
rondeo
Default Re: Recirc Flap
Dunno. Here's some self test info:
http://workshop-manuals.com/ford/mon...ontrol_system/
Actuator is on driver's side of climate control housing.
Old 09-12-2016, 03:19 PM   #3
cobrin
Challenge Accepted!
cobrin's Avatar
recalibrate the system again: https://www.youtube.com/watch?v=lToMWjuma50
Old 09-12-2016, 04:59 PM   #4
marcusturbo
Re-calibrate System - This worked fine and no errors code showing. Didn't fix problem though.
Whilst doing the above and with the fan on it's slowest speed, I pushed the recirc button and you could here the flap move, coming from somewhere deep behind the centre of the dash. The trouble was that sometimes it would work and others nothing. It's like the flap is sticking, hence why I' like to inspect.
Old 10-12-2016, 12:00 AM   #5
cobrin
Challenge Accepted!
cobrin's Avatar
I couldn't say so you'll have to remove the glove box completely and eyeball for the blend door actuator.
http://workshop-manuals.com/ford/mon...tment_cooling/
Old 10-12-2016, 08:53 AM   #6
rondeo
See Haynes manual:
'Illustration 3.9.4b ... and remove the air recirculation flap housing'
As cobrin said, through the glovebox; not driver's side as I said before. I'm getting mixed up looking at diagrams.
