Old 25-07-2011, 12:27 PM   #31
burnz
VFII SS UTE
burnz's Avatar
Default Re: Worlds largest diesel engine
Originally Posted by au3xr6
thats heavy fuel oil not lubricating oil I used to service the heaters they used to keep this stuff at a consistency where it can be pumped in winter ( in winter it is almost like grease). they call this a diesel as it uses compression ignition but it doesn't use diesel fuel as we know it it uses this heave fuel oil
sure go to the drags take it up to 90 RPM and dump the clutch
i believe it's called bunker oil..
I don't often hear the sound of a screaming LSX.
But when I do, So do the neighbours..
GO SOUTHS
burnz is online now   Reply With Quote Multi-Quote with this Post
Old 25-07-2011, 12:44 PM   #32
FGII-XR6
FGII-XR6's Avatar
bunker oil is a name that is commonly used for it but it's correct name is heavy fuel oil. If I never see this stuff again it will be too soon it's a pain to clean off and it stinks
[SIGPIC][/SIGPIC]
Rides:
Old 25-07-2011, 01:40 PM   #33
Road_Warrior
Pity the fool
Road_Warrior's Avatar
Originally Posted by MexicanBatman
Need to see pics of the turbo, and how it can be fitted to my FG LOL
You mean how your FG can fit inside it!
Fords I own or have owned:
1970 XW Falcon GT replica | 1970 XW Falcon | 1971 XY Fairmont | 1973 ZG Fairlane | 1986 XF Falcon panel van | 1987 XFII Falcon S-Pack | 1988 XF Falcon GLS ute | 1993 EBII Fairmont V8 | 1996 XG Falcon ute | 2000 AU Falcon wagon | 2004 BA Falcon XT | 2012 SZ Territory Titanium AWD
Proud to buy Australian and support Ford Australia through thick and thin
Road_Warrior is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2011, 01:46 PM   #34
SB076
SB076's Avatar
Too bad the apprentice, knocked it over when doing the install
VIXEN MK II GT 0238
with Sunroof and tinted windows
with out all the go fast bits I actually need :
SB076 is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2011, 02:18 PM   #35
MAD
Petro-sexual
MAD's Avatar
It's funny that none of the pictures linked in the article show an engine with 14 cylinders. I saw this thing circulate about 7 years ago when I started my engineering course.
I wonder more about the credibility of this every time I see it raise it's head again. I'm sure it's spectacular, but I wonder about the details.
- The Story
Old 25-07-2011, 02:37 PM   #36
Paull
P6 LTD
Paull's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: For all the hard work performed around paint, trim, engine codes in the Classics section. General all round knwoledge and willingness to impart on others
Here is a link to the Emma Maersk showing its engine.
http://4.bp.blogspot.com/_bQML71Wqjj...ain+engine.jpg
You can just count the 14 exhaust valve actuator pipes.
Paull is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2011, 02:51 PM   #37
MAD
Petro-sexual
MAD's Avatar
Thanks for that. I just did a little more looking and found the manufacturers website, with details of the 14cyl.
http://www.wartsila.com/en/press-rel...enters-service
I just hate the way these sort of things tend to be embellished before they are passed on, not that it needs to sound any more spectacular than it already is.
- The Story
Old 25-07-2011, 03:24 PM   #38
ebxr8240
Performance moderator
ebxr8240's Avatar
This was featured on a Fox channel the other night..
Daily driver GTE FG..
Old 25-07-2011, 03:58 PM   #39
DJR-351
I am Groot
DJR-351's Avatar
Bunker(s) are nothing more than the name given to a ships fuel tanks which can hold coal, diesel or heavy fuel oil(HFO), dependent on the propulsion type. (Not so much coal these days)
A point to note, some ships carry bunker Diesel/HFO AND cargo Diesel/HFO, it’s important for the loading and unloading to know which is which...
Also when replenishing (topping up the fuel tanks) it's called bunkering...
McLaren F1
Dick Johnson Racing
"Those were the days when the cars were cars, they weren't built out of an Ikea pack like they are now and clothed in plastic; they were real cars." John Bowe
DJR-351 is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2011, 07:04 PM   #40
xtremerus
FG XR6T trayback
xtremerus's Avatar
I would like to see the starter motor for that.
xtremerus is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2011, 07:38 PM   #41
DJR-351
I am Groot
DJR-351's Avatar
Another interesting point about the ships these engines go in is they don't have a gearbox as such, to go astern the engine is stopped then restarted in reverse rotation.........unless it has a CPP that is, but that is a whole different kettle of fish....
McLaren F1
Dick Johnson Racing
Old 25-07-2011, 09:31 PM   #42
Paull
P6 LTD
Paull's Avatar
These engines use an air start system whereby a distributor allows 30 Bar air into each cylinder, at the correct time, which then forces the piston down. The distributor then shuts the air off prior to BDC and then opens up the next cylinder in line. This process continues until the fuel pumps are stroked up and when the revs rise, the air start system shuts down.
Old 25-07-2011, 10:00 PM   #43
ebxr8240
ebxr8240's Avatar
Hmm ?? A push start is out of the question...Lol...
Old 25-07-2011, 10:16 PM   #44
DJR-351
I am Groot
DJR-351's Avatar
They also use the air start to blow over the engine prior to ignition as a test by leaving the indicator cocks open and the fuel pumps jacked off...
One ship i was on had a V16 Stork Werkspoor (now Wartsila) that blew oil out of the #5 Indicator cocks when in pre-start on a regular basis, it wasn't until we put a boroscope down the injector port that we realised the piston crown (oil cooled) was cracked into three pieces. It still ran ok, it just made a hell of a mess on pre-start when it blew a 100 litre's or so of oil all over the engine room.....GREASER!! CLEAN THAT UP NOW!!
McLaren F1
Dick Johnson Racing
Old 26-07-2011, 04:18 AM   #45
kpcart
Originally Posted by Angeldust
these things give me a hard on.
just massive cubic inch capacity.. no 2ltr turbo's here and like they say, there's no substitute for cubes.. lol
2 ltr turbos are a lot of cubes in some applications, you see lots of harley riders talking about their cubes, and they equal a lot less then 2 litres.
kpcart is offline   Reply With Quote Multi-Quote with this Post
Old 26-07-2011, 10:14 AM   #46
nb_351
building the xe...
nb_351's Avatar
or a gokart with a 2litre turbo, different applications haha
slowly but surely fixing up the king of the road
WANTED
P5 ltd/landau taillight centre panel
nb_351 is offline   Reply With Quote Multi-Quote with this Post
Old 27-07-2011, 01:40 PM   #47
HULK EF
holden/HSV's new 4 litre straight six competitor? Holden went 5.0 to 5.7 to 6.0 to 6.2.. to try and beat fords.. history repeating itself? lol
HULK EF is offline   Reply With Quote Multi-Quote with this Post
Old 27-07-2011, 03:26 PM   #48
XR6_661
Cane Farmer
XR6_661's Avatar
WHAT ABOUT THE EMISSIONS. Disgusting. I’m going to protest or some junk. God damn bloody big engines, choking up our world.
1994 ED XR6T - Cobalt Blue.
2009 FG XR6 - Black.
Originally Posted by Tex
I couldn't give a crap how many are in their family, what gay passtimes they paticipate in, or whether they have a cat, dog or a freaken fish.
Keep your stinking family to yourself god damn it.
XR6_661 is offline   Reply With Quote Multi-Quote with this Post
Old 27-07-2011, 05:31 PM   #49
DJR David
DJR David's Avatar
So you want a car, fuel, food clothes tv, stereo, etct etc etc etc etc, yet you dont want them to come on a ship.
oooookay then........
The International Air Pollution Prevention regulations cover emissions from ships
DJR David is offline   Reply With Quote Multi-Quote with this Post
Old 27-07-2011, 06:30 PM   #50
falconnut
Exactly imagine how much weight a Hybrid/Solar Fuel system would add to the ships already HUGE weight?!
2001 Falcon Fairmont AU2
Big turbo coming
Lsd
falconnut is offline   Reply With Quote Multi-Quote with this Post
