20-08-2016, 06:58 PM | #1 | ||
Hi all, played with timing on 351c in the bronco today, was pretty retarded, I assume due to lpg (only on petrol at the moment). Couldnt see my timing light due to the sun so did it by ear, I turned the dist clockwise until the vaccuum advance diaphragm hit the thermostat housing. Heaps better but needs just a smidgen more. Am I able to move all the leads around one space, then go back to give myself more room? If so, would they all have to move one space clockwise or anti clockwise? Started to confuse myself so thought better ask first.
20-08-2016, 07:56 PM | #2 | ||
The lead position probably should have been moved forward when it was assembled originaly
20-08-2016, 08:35 PM | #3 | ||
No reason to retard on LPG.
I'd suggest waiting till the sun goes down, or parking in the shade. As for the leads, move them in the same direction you're trying to turn the dizzy. You're trying to move the number 1 lead into the correct position, you can do that by twisting, or by moving the lead, (then adjusting.) |
20-08-2016, 11:03 PM | #4 | |||
20-08-2016, 11:17 PM | #5 | ||
Maybe pull the dizzy out and advance it a whole tooth. Stuffing with the leads is a 90* jump in spark timing. A tooth is probably more like 15-20* and the distributor will still be in about the right spot.
LPG is both higher octane and slower burning than petrol, it should be more advanced
Chuck Norris beat Tetris
20-08-2016, 11:19 PM | #6 | ||
Wait, if it still has points, they could be worn down. It re-tards timing slowly over time, so last owner might not have noticed
Seriously I have to hyphenate that? Mods can you turn down the swear filter so I can use technical terms. What happens when my female dog thwarts my born-out-of-wedlock roosters plans to get laid? My ***** ******* my ******* ****** plan to **** the hens (only the last one required stars)
21-08-2016, 04:37 PM | #7 | |||
21-08-2016, 04:44 PM | #8 | |||
XC GS OLD SCHOOL MUSCLE Audi A4 S-line quttro Xc falcon Previous fords- xc falcon 500 ,250 x flow 3 speed xc gs worked 250 x flow 4 speed xa Fairmont 302 auto wagon xb falcon 250 log auto 4 door xb falcon 200 log auto ute xc gs project - had to sell :-( xc gs 302 4 speed 4 door xc gs 351 auto 4 door zf fairlane 302 auto zk fairlane 250 x flow carb auto zl fairlane 250 x flow EFI auto xg ute , BA falcon dedicated gas xd, xf x 3 ,ea,eb,ef,au x 3,telstar tx5 |
