Old 18-09-2019, 08:14 PM   #1
BlacktoppInc
Default New shed ideas help with ideas
Hey there , Im Currently planning a New shed build on my Property and would like a bit of feedback and maybe some ideas , Currently the Size is 7mx8.1mx3.4mH , Do you think this will be a sificient size for general Automotive work/Restoration/Engine Building ? i will be installing a 2 post Car Hoist .
I would love some Feedback and ideas cheers
BlacktoppInc is offline   Reply With Quote Multi-Quote with this Post
Old 18-09-2019, 08:34 PM   #2
arronm
BA/F6 BF/F6 SSV/R TTG
arronm's Avatar
Default Re: New shed ideas help with ideas
Build it big enough to install a 4 post as well. Then you car park one car under another..
BA BF FPV starter button repairs. PM me.
Nizpro equipped and Tuned by the BEST in the west
Xtreme Ford Tuning
479RwKw Fuel limited, more pumps and power too come.
F6#0507 & #0639 Pro racer and Tech expert
NIZPRO modifying falcons like Premcar can only dream of , see VIDEO below.
https://youtu.be/oa4IfguGQ-A
arronm is offline   Reply With Quote Multi-Quote with this Post
Old 18-09-2019, 08:41 PM   #3
Too small, ideally. What’s your wall height - or is that the 3.4?
Aim for 35° roof to maximise airspace or loft storage.
Old 18-09-2019, 08:47 PM   #4
yakcam
I drank what?
yakcam's Avatar
Rule of thumb when building a shed is, build it bigger than you think you need or you'll constantly regret you didn't.
I will not be taking any criticism, constructive or otherwise.
yakcam is offline   Reply With Quote Multi-Quote with this Post
Old 18-09-2019, 08:48 PM   #5
Jack91
Jack91's Avatar
Go as big as you can. You'll fill the space. I have 16x10x3.5(at edges so about 4m in middle) and it's still sometimes a pain. Also, plan to chuck a crapper and a kitchenette in it, it's a game changer
Jack91 is offline   Reply With Quote Multi-Quote with this Post
Old 18-09-2019, 08:54 PM   #6
Jack91
Jack91's Avatar
Also, if you are going custom, plan it to 8m lengths of rhs and you'll end up with portal frames about my size with no offcut
Old 18-09-2019, 09:32 PM   #7
Ventilation. Not so much for sniffing fumes, but more trying to keep the inside temp of the shed closer to the outside temp then being a sweat box in summer. Insulation and whirly gigs work, but whirly gigs only do so much. So, granted my house is built like a house not a shed, but im making the safe assumption your shed will have power. One thing that i wired into my house is an exhaust fan on a thermostat. So the mushroom housing protrudes through the roof tiles. The thermostat is set at 40 degrees, being a house, 40 for the temp in the ceiling space is around 28. It doesnt cool the house, but it prevents it getting more then a handfull of degrees warmer then outside. So i dont run mine off a switch. Its straight off the thermostat for my house, but i tend to live in my house every day. An in a sweaty shed working away, being slightly less sweaty working away in the warmer months may be of a minor advantage.
.:4:. is offline   Reply With Quote Multi-Quote with this Post
Old 18-09-2019, 09:56 PM   #8
jmack
go as big as u can afford and fit.mine is 15*25 with 3.6walls at 10deg pitch which gives 5m in the centre(about 4.8 clearspace)if u ever want to get on the roof 10deg is good 22deg is most house roofs which can be a bit slippery at that angle.def another vote here for a toilet ,ive got a kitchen and shower as well which comes in handy.ive had to build another shed as i have a compulsive toy buying dissorder and ran out of room
jmack is offline   Reply With Quote Multi-Quote with this Post
Old 18-09-2019, 10:14 PM   #9
BlacktoppInc
Cheers for the feedback, the design at the moment is 3.4 high walls with 15degree pitch , I'm starting to intrude on my back yard space a little. At 8.1 long by 7m wide will this be big enough for worship space ? , I'd love to go bigger but the property size is only 750m2 , and yes the shed will be powered , including 3 phase
Old 18-09-2019, 10:38 PM   #10
Depends on the size of your congregation.
A car, dismantled, requires practical workspace equal to at least three whole cars.
Old 19-09-2019, 07:59 AM   #11
roKWiz
Cabover nut
roKWiz's Avatar
And don't get addicted to playing with trucks.
Old 19-09-2019, 08:17 AM   #12
Electrolyte Burns
By definition a shed can only ever be adequate. It can never be sufficient.
You will fill whatever you build.
Electrolyte Burns is offline   Reply With Quote Multi-Quote with this Post
