12-10-2007, 08:00 PM | #1 | ||
can someone please tell me how to replace the O RING on the TENSIONER. Im assuming ford mean the tensioner pulleys.
2001 Ford Falcon Futura Classic SVP Web-Site: http://www.aufalcon.com/cgi-bin/index.cgi?act=item&i=394 |
12-10-2007, 08:33 PM | #2 | ||
Sly like a G6
That'd be the oil seal on the timing chain tensioner. Remove snorkel, fans, loosen belt, remove power steering pump from bracket, remove bracket and there's the tensioner on the driver's side of the engine. Inner bolt may undo cleanly or the whole assembly may undo. I've done this numerous times (once for each camshaft change) but I can't tell you exactly where the O-ring is. I have to do this myself soon as I have quite a good leak, but I suspect you'll be doing yours before me.
The Frankenfalcon... AU1.5 Wagon, BA brakes, AU2 booster, BA2 XR6T engine, stock from airbox to turbo, 8psi/98 octane tune 240RWKW, BF XR6T cat, quiet 3" zorst, Pex BSO660 & BSO439 mufflers, 84 db, built BTR box, 3.08 LSD, Emer SVI LPG, AU1 XR8 alloys, Momo wheel, JVC KDR746BT head unit, Aerpro steering wheel control wiring. Sleeper, anyone? |
13-10-2007, 12:30 AM | #3 | ||
I build your wish list...
There is no good fitting " O " ring that you can buy
on this part there is 2 "O" rings on the filter And when you remove this part there is also a O ring on there as well BUT there is not a good " O " Ring that you can get to fit this part
If it weren’t for physics and the law enforcement, I’d be unstoppable.
13-10-2007, 01:29 AM | #4 | ||
Sly like a G6
Some others on here reckon they've got kits from Ford dealers for around $20 that stop the leak. Haven't tried myself yet, will find out eventually. Great photos though, spot on. Is that the "special tool" for releasing the tension or did you mod the allen key yourself? I always use a bog stock 3mm allen key.
13-10-2007, 09:37 AM | #5 | ||
Yep I " Modded " it
at Work I was doing from 2 to 5 Head gaskets a week So I have it down Pat ..
13-10-2007, 09:56 AM | #6 | ||||
Blown 5L coming
1995 EF Fairmont was stocko 6cyl with open single spin diff....NOW WITH XR8 ENGINE, DRIVELINE AND SUSPENSION!!!!! Maybe by the end of 2010 there may just be a blower as well ;) NEW CLUB FOR SUNSHINE COAST !! www.f-p-e.proboards.com Contact Col (au2sw) via PM or on MSN @ efmonty@hotmail.com Quote:
13-10-2007, 10:25 AM | #7 | ||
goto Motion Industries(www.motionind.com.au).. we have a million different size O rings
compared to supercheaps "assorted" pack also there is some good loctite products that may help
13-10-2007, 10:34 AM | #8 | |||
Sly like a G6
Fair enough he should try it without removing fans & snorkel first, but it's not too hard to do so if he needs to.
13-10-2007, 11:18 AM | #9 | |||
13-10-2007, 10:57 PM | #10 | ||
Yep I fell asleep and left that Pick out ...
even the O ring there is hard to find to get one to fit right. I like to use selastic to put behind it so it does not course any trouble.
14-10-2007, 01:33 AM | #11 | |||
Sly like a G6
14-10-2007, 01:33 PM | #12 | |||
LoL Yep I don't work as a Mechanic now But still do "back-yard's"
14-10-2007, 07:32 PM | #13 | ||
Walking with God
Great pics trick!
Cheers, GK
14-10-2007, 07:47 PM | #14 | ||
is that an e series tensioner,looks quite a bit different to the ones i've seen in my au engines.
the au tensioners i've seen don't have an o ring on them .just the black housing that screws into the block.
au2 s i6 5 spd , au series 1 xr6 hp motor, cam advanced 5*,jmm cai ,topgun leads,pacey 4480's,3 inch cat,lukey 2 1/2 sports zorst and 3.89 lsd,standard ecu. current best,14.939 @ 93.17. |
14-10-2007, 08:00 PM | #15 | ||
here's a pic of an au one
14-10-2007, 08:23 PM | #16 | ||
That is the tensioner You have a pic of there ... It sits behind the "Disc" in the pic of mine
Where the Allen key is sticking out of is the tensioner that you have picks of. GK ...I did a hole step by step guide with pic's and what tools needed to do a Head gasket change and also a water pump change .
14-10-2007, 08:40 PM | #17 | ||
ok now i'm confused,whats the bit in your bottom pic sitting above the alum key to the left? (in your 1st post)
i assumed it was the tensioner,my au i6's don't have this piece.
14-10-2007, 10:41 PM | #18 | ||
OK first you have this
So you undo the 14mm "bolt" and remove it like this Then you put the Allen Key into the center and turn it anti clockwise While you Put a screw driver down from the Top and Help push the tensioner back By pushing on the chain Guide. Then when You undo that "Disc" you will see the tensioner .... BUT if all you do as I say You DO-NOT have to do anymore to the tensioner then remove the "bolt" and release the tensioner with the Allen key and screwdriver
05-10-2011, 03:48 PM | #19 | ||
Next upgraded Mk1 Leopard
Help,
I can not get the inside blot to undo. Each time I turn the bolt the ouside ring starts to unscrew as well. Does this matter? Do I have to remove the whole outside case then undo the centre bolt? UK
05-10-2011, 04:58 PM | #20 | |||
AU DIE HARD
The 1 I did. did the same just took the whole lot out then replaced in 2 separate pieces
05-10-2011, 05:44 PM | #21 | ||
Its all out now. Have ordered the new o rings. Pick up tommorw.
UK
23-10-2011, 12:21 PM | #22 | ||
Ok after a week or so he chain is nosiy and stalling when run on gas. So I have removed the tensioner (again) and it has three states
1. undone 2. half way tight 3. Fully closed You can see from this picture what the case locks onto So my questions are. a. Can I reset the tension outside the case, slide it in and then just tight it up or b. slide back the outer caseing, then slide it onto the untighted spring (makeing sure nothing goes into the engine) and then set it? And what settings, undone, half thighten or full? UK
23-10-2011, 04:18 PM | #23 | ||
Its back in now. Taking it for a run soon. Questions above still stand
Uk
26-10-2011, 11:02 PM | #24 | ||
you can swap the larger oring for an alloy sump plug washer, tends to work alot better
27-10-2011, 04:54 PM | #25 | |||
UK
