Old 22-02-2010, 06:37 PM   #1
Pepi69
PEPI69
Pepi69's Avatar
Default Irs Conversion Question
Howdy,
Apologies for putting this in the wrong section :togo:
I'm able to get my hands on an entire IRS set up from an AU3 xr6 for free - it's all cleaned diff reconditioned new bushes etc - am I able to swap this set up into my au2 that has live axle set up? If it's just a straight bolt on - the only thing I'll need to get will be a rear castor/camber gear......
thanks
aims to please.................
Pepi69 is offline   Reply With Quote Multi-Quote with this Post
Old 22-02-2010, 06:40 PM   #2
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
Like any sort of conversion it's not a case of if you can but how hard/how much $ do you have...
Also,
don't do it - it's not worth it.
Old 22-02-2010, 09:09 PM   #3
mik
mik's Avatar
if no one pipes up perhaps talk to ferntree gully auto salvage , one of the site sponsors, i`m sure they would have been asked this question before.
Old 22-02-2010, 10:30 PM   #4
MAD
Petro-sexual
MAD's Avatar
If it can be done to an E-Series (which it has been a few times) then it can be done on the model it came from.
You will need to remove the watts link mounting points and replace a panel under the boot with one for the IRS unit.
- The Story
Old 22-02-2010, 10:50 PM   #5
JC
JC's Avatar
Why would you want to add an extra 80kg of rear end for not much gain?
Ford Performance Club ACT
Old 22-02-2010, 11:08 PM   #6
bartsau
bartsau's Avatar
I can't be sure but i am pretty sure you will will find that it should bolt up as they use the same mounting points. I can't remember who or where i saw this but i think they made them this way in order to be able to fit irs (option on lower models) without any hassle.
Cheers, Rhys
AU III Forte wagon - V8, 5spd man, lowered, 18" Honeycombs, Stock diff rebuilt with TruTrac LSD, Leather Ghia interior/dash, custom twin 2.5" into single 3" exhaust.
Wagon Build
AU I Forte Sedan - No longer
Toy Car Build
bartsau is offline   Reply With Quote Multi-Quote with this Post
Old 22-02-2010, 11:51 PM   #7
grandpa_spec_F6
AFF Whore
grandpa_spec_F6's Avatar
for the love of god DON'T! I've had so much effing trouble with it I even wrote a guide hahahaha
Favorite Quote:
Originally Posted by Big Damo View Post
My GMC Sierra is banned under Victoria's high powered vehicle laws, and its a 4082kg apartment complex on wheels.
Current Ride: Not a falcon, the struggle is real
grandpa_spec_F6 is offline   Reply With Quote Multi-Quote with this Post
Old 22-02-2010, 11:57 PM   #8
cedric
yep if it aint broke don't fix it. new mustangs (2005 and on) went back to live axle because less weight,stronger,cheaper to maintain and 99% as good, why would you bother
cedric is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2010, 12:33 AM   #9
svo supporter
Fixing Ford's **** ups
svo supporter's Avatar
IRS makes the rear handle alot better than any live axle rear, as both rear wheels are working independently, rather than together.
As for the change over. It depends on the $ factor and the patience factor
A wheel alignment fixes everything, when it comes to front end issues. This includes any little noises.
Please read the manual carefully, as the these manufacturers spent millions of dollars making sure it is perfect.....Now why are there so many problems with my car, when I follow the instructions to the letter?....Answer, majority rules round here
Lock me up and throw away the key because I'm a hoon....I got caught doing 59 in a 60 zone
Old 23-02-2010, 01:30 AM   #10
T3man
T3man's Avatar
It is not a bolt-in job. Much underbody panel work has to be done and it simply isn't worth it. You can just go buy a car with IRS.
And I am a big fan of the Ford Watts link rear end over almost any other for weight, cost and effectiveness ... yet there is absolutely no way it comes near the AU IRS. I have driven Jags, Mercs and BMWs (amongst others) and I can assure you the AU IRS is right up there, and even better than most of them. It leaves the "control blade" and any Holden swing arm style lagging far far behind.
Old 23-02-2010, 01:46 AM   #11
SLO AU XR8
I've currently got my IRS cradle out of the car at the moment, I'll grab some pics of the mounts for you. Also, removing the cradle is no fun, let alone replacing it.
GT 335
11.3@124.1mph
383rwkw/513rwhp
Forced Performance Tuned
SLO AU XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2010, 03:14 AM   #12
Bam
XB,XF,ZL,EA,EL,BA,SY,SZII
Bam's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Excellent write up on Air bag installation.
Which is consistent with Ford's reluctance to go IRS even under intense motoring journo criticism until years after their competitors did. Their competitors of course (well Holden at least) botched their early designs.
Is there something wrong with the handling of an AUII XR6 to justify all this work? My EL XR8's handling was excellent.
Bam is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2010, 11:01 AM   #13
T3man
T3man's Avatar
AUII XRs have IRS standard don't they? I think he has a base model.
Old 23-02-2010, 06:50 PM   #14
Pepi69
PEPI69
Pepi69's Avatar
Gentlemen,
thank you for the replies - I think it may be worth just keeping with what I have got - I't not really that bad having one wheel in the air going up the driveway.....stiff suspension.
Old 23-02-2010, 07:57 PM   #15
The Monty
Just slidin'
The Monty's Avatar
Only HP XR6's came with live rear for the AU's. Anything VCT had IRS and the V8's in the high end models, Fairmont Ghias, and Fairlanes.
MD Mondeo - For the family
NP Pajero - For the adventure
Old 16-12-2018, 06:00 PM   #16
Watermelon71
Default Re: Irs Conversion Question
hey anyone got a link to the irs conversion cant seem to find the guide that grandpa_spec done
Watermelon71 is offline   Reply With Quote Multi-Quote with this Post
Old 16-12-2018, 11:41 PM   #17
FTe342
FTe342's Avatar
Mate there are 2 different body types with different mounting points for IRS and non-IRS.
Basically, it cant be done without having it engineered. Forget it.
T3 TL50 #147 Silhouette Auto ESS - Brembos - Last of 3 in T3 spec, only AUIII TL50 ever built -14.2 sec @ 98mph bog stock. Only customer ordered T3 TL50 built, only LWB sedan plated AUIII and the last performance enhanced LWB sedan built by Ford Aust.
AUII Fairlane Ghia Sportsman 5.0L in Blue Pearl
OWN THE ROAD
FTe342 is offline   Reply With Quote Multi-Quote with this Post
