12-02-2007, 06:27 PM | #61 | ||
V8 wannaabeee
yeah it's alright , was driving mates car from qld to vic .. his car registration is qld and under his name... hopefully he doesn't get the fine because he doesn't have a way of getting mail :P
The time distance cams are pretty far apart so mostly pulled over for 10 mins fuel/rest etc. then cruise back to 120 on the dial but slow back to 100 for the cameras. |
12-02-2007, 06:54 PM | #62 | ||
if you are caugfht with Laser they dont take anything off...laser is accurate to +/-1km/h...
12-02-2007, 09:17 PM | #63 | |||
SV6000. Yum
12-02-2007, 09:19 PM | #64 | |||
SV6000. Yum
That said I am in no way condoning excessive speed. Crossing the lake george flats or the Bargo ramp is very different to travelling through the goulburn hills in torrential rain...... Drive safely to the conditions. |
12-02-2007, 10:11 PM | #65 | ||||
Force Fed Fords
They can be successfully argued against in court. As for the speed tolerance thing, I believe we need to have limits, but I don't believe we need to be so anal that we spend the majority of our time focussing on the speedo and not the challenge of managing an 1800kg moving hunk of metal. This is where a lot of fatalities occur, as we have all witnessed changes in conditions over a split second. In real terms, we have focussed on speed over the years where a zero tolerance approach has been adopted, yet cars have gotten safer, roads have been upgraded, and the road toll (not to be confused with toll bar) has remained largely unchanged. Obviously something has not moved forward in line with other improvements. I think a little more tolerance and leniency should be fostered in order to allow for less frustration. Don't make it such that it can encourage speeding but don't make it so stingy either, where a gust of wind can see your licence evaporate in the flash of a money box err, speed camera. Yes, cop it on the chin if that turns you on but for goodness sake, if you feel as though you have been dudded then challenge for the sake of your sanity. Bracks will not miss it, he'll only use it to change his name from Bracks to Tax.
If brains were gasoline, you wouldn't have enough to power an ants go-cart a half a lap around a Cheerio - Ron Shirley Quote:
12-02-2007, 10:25 PM | #66 | |||
If the guns are calibrated correctly they will be 99% accurate...you may get some difference over 1500 feet but under 1000 feet these things are more accurate than any radar or speedo out there. |
12-02-2007, 10:44 PM | #67 | ||
yeah SA os a much nice state to drive in i set the cruse at 117 and never had a problem, i set the cruse on 103.0 in Vic and the copper flashes his high beems at me!
12-02-2007, 10:58 PM | #68 | |||
V8 wannaabeee
13-02-2007, 12:31 AM | #69 | ||||
Force Fed Fords
Secondly, the lidar guns require calibration just as the radars do. Before you try and woo me with averages etc ask yourself this; can you definitavely prove that they are 100% accurate? And I don't mean can you argue the point I mean really prove in say a courtroom setting where these matters are resolved that these measurement instruments are not succeptible to external and unintentional interruption, that they are specific down to the 0.1 of a metre, that they are reliable and are clearly able to consistently measure the same distance on a fixed let alone moving object? I work with measuring equipment that has peoples lives depend on it and I can tell you that there is nothing electronic out there that is 100% reliable all the time. Believe me sunshine, there aint no case that can't be argued and won. If you have the time and are prepared to part with some cash, you can cast doubt in the judges mind sufficient to walk away with your licence and points intact.
13-02-2007, 12:48 AM | #70 | ||
yeah i can, its called a calibration certificate...thats a legal doco and will hold up in court...ive seen it with my own eyes...and don't call me sunshine buddy!
13-02-2007, 09:47 AM | #71 | |||
SV6000. Yum
Civilian GPS is not all that accurate. You need Military grade GPS for that. Civilian GPS horizontal position fixes are typically accurate to about 15 meters. Sources of errors Ionospheric effects >> ± 5 meter Ephemeris errors >> ± 2.5 meter Satellite clock errors >> ± 2 meter Multipath distortion >> ± 1 meter Tropospheric effects >> ± 0.5 meter Numerical errors >> ± 1 meter or less |
13-02-2007, 10:48 AM | #72 | ||
inluv with the bulge
i've been told that the tolerance in victoria at the moment is 3kph. but i've also heard that's due to our state being run by labour, and that the liberals allow a tolerance of 10%. don't know how true that is tho...
i'm pretty sure that on freeways the tolerance is more than 3%. i went past a parked cop while on my Ps doing just under 110kph and they didn't do anything. |
13-02-2007, 10:52 AM | #73 | |||
Virtuous Bogan (TM)
My speedo says 110, but I am really doing 103ish, according to those electronic speed checkers, and I assume that police radars are a similar spec. Which is why all this 3kph over is BS, most speedos are not that accurate.
13-02-2007, 11:13 AM | #74 | ||||
Force Fed Fords
For example a laser based speed detection device in London recently clocked a cabbie doing 885kmh. Physically not possible but hey, they had a calibration certificate.
13-02-2007, 01:56 PM | #75 | |||
i got my first and only speeding fine 2 years ago, and 3kph was taken off the speed in which i was snapped. plus i've been told this by an ex-cop but i suppose it may no longer be the case, but that was my reasoning behind it |
13-02-2007, 02:03 PM | #76 | ||
I got a speeding fine over the Xmas break and only got the speed reduced by 2km/h (114km/h, radar got me at 116km/h) the copper then wrote the wrong thing up stating I exceeded limit by 15km/h but less than 25, in fact it was meant to be more than 10 but less than 15, I didn't really care because the fine was the same either way.
The Old: 1993 ED Fairmont 1994 ED Futura Classic Manual, 2004 BA MkII XR6 Turbo 2009 G6E Turbo (277.2rwkw @ Tuned at Bullet Performance Racing) 2007 Audi S5 4.2L V8 manual (Supersprint exhaust, MMI 3G+ retrofit) The New: 2015 SZ MkII Territory Titanium Petrol RWD (With Sync 3 Upgrade) Other Road Toys Silver Surfer 2014 S-Works Roubaix SL4 road bike with Roval Rapide CLX 40 wheelset The Adventurer! 2023 TREK Domane SL 7 AXS Gen 4 |
13-02-2007, 06:51 PM | #77 | |||
14-02-2007, 04:53 PM | #78 | |||
Former BTIKD
14-02-2007, 05:16 PM | #79 | |||
14-02-2007, 05:46 PM | #80 | |||
Former BTIKD
14-02-2007, 06:15 PM | #81 | ||||
Force Fed Fords
What your suggesting is that time and space stops whilst the beam is focussed on your car, as nothing could ever possibly intrude upon the beam could it? Also, it doesn't leave a tag or a mark so it is difficult to prove it was focussed on your vehicle and not any other traffic. What I'm getting at here is reasonable doubt. If the laser left a time stamp on the car it could then be proven that yours was the offending vehicle but without it how can you definitavely prove it? My position on this is not on accuracy of apparatus but on the variables which could affect the police claim that they detected you speeding. At common law, it is a difficult claim to prove and most people accept being fined. If you have no points to lose or don't mind a challenge it is impossible for the police to prove their case against you, especially when you employ experts that can offer a rebuttle to the police' claim. You might be right, but I can prove you wrong in court.
14-02-2007, 06:20 PM | #82 | |||
Force Fed Fords
2021 Focus ST-3 Mountune Enhanced |
14-02-2007, 07:17 PM | #83 | |||
I checked a photocopy of my fine and it was as you stated code "1911"
15-02-2007, 10:28 AM | #84 | |||
I hope your parole officer doesn't view this forum. |
15-02-2007, 11:45 AM | #85 | |||
Force Fed Fords
15-02-2007, 07:23 PM | #86 | ||
It always amuses me how NASA can use LIDAR instruments to measure speed and distance accurately in the same manner police do, but if involves trying to slow people down so they don't kill themselves, lookout! Everyones an expert as to how they are unbelievably spurious! Always by people who aren't even aware of the guidelines of use of these instruments. Oh but how do we know these guidelines are adhered to?! It's a conspiracy! Spend a day at local Court and you'll learn more than a year on the internet.
Nah. It's just easier to believe whatever Naomi Robson tells you on the telly. Regardless of what people think regarding speed enforcement. I do pity the mexicans down south. You guys might as well learn how to drive whilst bending over and grabbing your ankles. |
16-02-2007, 12:08 AM | #87 | ||
V8 wannaabeee
what i find interesting is.. on the Western Ring Road.. do people actually realize there are those new "safety cameras' are even there? people are going under them at about 110/120 ... and considering they're time-over-distance .. they're screwed !
