Go Back   Australian Ford Forums > The Sales Yard > Cars Wanted
Cars Wanted If you want it this is the place
Old 13-08-2018, 01:01 PM   #1
Polyal
Now with more Chrome
Polyal's Avatar
Default WANTED: ZF/ZG (XA/XB) Front Bench Seat
Just putting some feelers out there.
I am after a bench seat to suit a ZF Fairlane. Looking for something complete, if all the belts are there then thats a bonus.
Trim code is S but I will more than likely get it redone anyway.
If anyone had any contacts it would be much appreciated.
I have found once in VIC but was hoping there would be something closer to QLD or in Saddle already.
  • 2017 Mitsubishi Pajero Sport
  • 2017 Toyota Hilux
  • 1973 ZF Ford Fairlane
Polyal is offline   Reply With Quote Multi-Quote with this Post
Old 13-07-2019, 04:23 PM   #2
Daly
Default Re: WANTED: ZF/ZG (XA/XB) Front Bench Seat
Did you end up finding a front bench seat or what did you use instead, been looking for one myself
Daly is offline   Reply With Quote Multi-Quote with this Post
Old 15-07-2019, 11:32 AM   #3
Polyal
Polyal's Avatar
Yeap. Used one from an XB then got it recovered.
I have a thread in the project cars section with some pics.
Ive seen a few on FB of late, in the XA/B/C owners groups and Ford Parts Sales etc
  • 2017 Toyota Hilux
Old 15-07-2019, 12:04 PM   #4
Daly
Thanks, was there much work in fitting it, saw your build thread, looks nice
Old 15-07-2019, 12:53 PM   #5
Polyal
Polyal's Avatar
No piece of cake, fitted up to all the factory holes, I bought a new nut and bolt kit just to be sure.
I also swapped my rails from the buckets to the bench, again, all fitted perfectly.
  • 2017 Toyota Hilux
Old 15-07-2019, 01:22 PM   #6
Daly
Sweet, thanks mate
Old 16-07-2019, 10:45 AM   #7
Electrolyte Burns
I used to do a modification to the front seats on every XB/XC/XE cars I ever had.
If the slides fitted from the buckets it should work with the bench also.
On the rear of each pair of sliders there are a couple of brackets that bolt them to the floor.
There is a longer one and a shorter one. Take both off and chuck the longer one away. Use the shorter one in the same position that the longer one was in. Use nothing on the other side (where the shorter one was) Then simply bolt the seat back in.
You end up with the rear of the seat much lower and get fantastic support for your legs, just behind the knee.
Electrolyte Burns is offline   Reply With Quote Multi-Quote with this Post
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
