Old 02-04-2008, 12:10 AM   #1
bloosted
Default which carby?
hi i have a 2L which i will have pretty warm and don't really want to do twins,i have heard of a 38weber or a weber off a XE falcon and a holley 350 could you please tell me the pros and cons of all these and how much less power they can achieve than twins.
thanks in advance
bloosted is offline   Reply With Quote Multi-Quote with this Post
Old 02-04-2008, 09:11 PM   #2
Sterling
BUMP! i would like to know this aswell as i have an xe or xf carby on my bench
Sterling is offline   Reply With Quote Multi-Quote with this Post
Old 02-04-2008, 10:07 PM   #3
ZA-289
ZA-289's Avatar
Arn't the 36/38 webber standard on the 2L?
If not their a good choice, The holley might be a bit big unless its a real hot donk.
ZA-289 is offline   Reply With Quote Multi-Quote with this Post
Old 03-04-2008, 06:31 PM   #4
Sterling
what about mine, i got the standard 2 litre with extractors, and i have an xe or xf carby on my bench if i hooked it up would it make a difference? or would i need a lumpy cam ported head etc
Old 03-04-2008, 08:55 PM   #5
greenmk2
75 MK2 2 Door
greenmk2's Avatar
I reckon the stock carb is good. If you dont have stock carb then use XE falcon carb. As far as i know the power outputs are much the same. I tryed the the 350 holley but had tuning problems. But if you were to find a good machanic you could have it running sweet!
My favourite setup was the linx single sidedraft manifold with a 45 delorto. with sig erson mild cam and extractors used to pull 0-100 in 8sec. And smoked a stock VR SS over the Q/mile. i was happy with that...
- FG MK1 G6ET - weekender
- Escort MK2 - Weekender
http://i76.photobucket.com/albums/j5...zaicos/Z-1.jpg
greenmk2 is offline   Reply With Quote Multi-Quote with this Post
Old 04-04-2008, 08:31 PM   #6
peachey80
Nothing stays standard !!
peachey80's Avatar
Don't bother with the 350 or the Falcon carb.
Keep it stock, or if you want any noticable difference, go the side draught, twins if you really mean business.
I've tried the 4.1 carby with no difference, put a set of 48mm dellorto's and redline manifold, instant power !
SHHHHHHH, Quiet, I'm hunting Lions !
Project Car : XA Coupe : XA Project
peachey80 is offline   Reply With Quote Multi-Quote with this Post
Old 04-04-2008, 09:47 PM   #7
digginganddirt
i disagree my mate put a 32/36 on and it hammers compared to standard (falcon is pritty much the same just dosent have a butter fly in the seconders but you would have to change the jets)
digginganddirt is offline   Reply With Quote Multi-Quote with this Post
Old 04-04-2008, 10:02 PM   #8
Sterling
what about it standard? origonal jets from the falcon? my engine has not been run yet and the last owner sed the carb probably needs a rebuild and i have a working falcon carb so what should i do? use the falcon or get the stock one rebuilt?
thats the million dollar question lol
Old 04-04-2008, 10:37 PM   #9
bloosted
the standard one is a 32/36 i think you will find
Old 05-04-2008, 01:22 AM   #10
digginganddirt
really well ya learn somthing every day well it made a big diff on the 1300
Old 05-04-2008, 02:52 AM   #11
bloosted
its standard on the 2 litre
Old 05-04-2008, 09:33 PM   #12
peachey80
peachey80's Avatar
Well, I reckon it would go better than a standard 1300 being they don't use a dual throat weber.
Falcon 4.1 carby will be no better than a Std 2L pinto carby.
