Old 27-05-2010, 07:16 PM   #1
GTLexus
GTLexus's Avatar
Default V8 AU Fairlane not running when hot Heeeeelp Pleeeeease!!
OK, I have looked on the search function, and on the forums and to no avail.
This is the issue
I have a 99 AU V8 Fairlane on dual fuel with 199000kms.
It was running rough at idle on both petrol and LPG and then when accelerating it would not want to accelerate and run even rougher. The idle is that bad that the whole car shakes.
I replaced the coil packs, spark plugs, and ignition leads.
Cleaned K&N airfilter
Checked wiring connections on engine
Cleaned throttle body
Cleaned contacts to airflow meter
Changed oil and filter while I was there
Changed fuel filter
After all this the car still idled roughly and I took it for a drive and the acceleration was like it was still misfiring. I ran it on both petrol and LPG and it had the same symptons. When I got back in the driveway the car temp was at normal. I shut the car off and when I went to start it, it did not want to fire. I rechecked the leads and connections and they were all OK, out of desperation I gave the airflow meter a tap and the car started. It idled roughly and was backfiring.
It seems the hotter the car gets the worse it becomes.
Does anyone have any idea what to do next?? I have had the car towed to 2 mechanics and both of them could not find anything wrong with it
GTLexus is offline   Reply With Quote Multi-Quote with this Post
Old 27-05-2010, 09:07 PM   #2
stavros68
Common problem with AU V8, harmonic balancer it will cause it to miss, the more you drive it the rubber seal gets hot causing it to vibrate .
stavros68 is offline   Reply With Quote Multi-Quote with this Post
Old 27-05-2010, 09:11 PM   #3
peterban
AULTD
peterban's Avatar
I had trouble after converting the V8 LTD to gas with it running rough on gas and petrol.
It wouldn't run properly on either fuel and it was like it was running on 4 cylinders
It turned out to be the mixer.
The gas guy took it off, pulled it apart and sprayed the inside with a carby cleaner.
Every now and again it plays up and I just carefully take it apart and clean it myself.
The system I have has an Impco mixer installed in the middle of the intake pipe.
It seems it gums up every now and again and as it also affects the air getting to the engine it affects both the gas and petrol side of things.
peterban is offline   Reply With Quote Multi-Quote with this Post
Old 27-05-2010, 10:00 PM   #4
jeffb
jeffb's Avatar
I would check the harmonic balancer, if the crank angle ring is not right it wont run, and if the weight has shifted it will vibrate running.
jeffb is offline   Reply With Quote Multi-Quote with this Post
Old 28-05-2010, 09:09 PM   #5
GTLexus
GTLexus's Avatar
thanks guys, will try the harmonic balancer, seems to make sense
Old 29-05-2010, 12:23 AM   #6
5.0 ED
5.0 ED's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Always willing to help out with sound technical advice. Technical Contributor: For members who share their technical expertise. - Issue reason: has helped a number of AFF members with their cars, particularly with EEC tuning
although im not discounting it, but the ring on the harmonic balancer isn't connected to the rubber side it is part of the centre solid part, have seen many faulty and not one that has caused running issue's apart from bad shaking, particularilly bad at about 1300-1400rpm.
I'd be more inclined to check the actual sensor itself.
5.0 ED is offline   Reply With Quote Multi-Quote with this Post
Old 29-05-2010, 12:31 AM   #7
mik
mik's Avatar
could it be getting gas and petrol causeing flooding? crank angle sensor?
Old 29-05-2010, 02:32 PM   #8
peterban
AULTD
peterban's Avatar
I thought that was what mine was doing as it ran the same on gas and petrol.
It was the fact that the alloy part connected to the diaphram that lets the gas in doesn't move freely and blocks some of the air entering the engine and so starves it of air.
Does your car have a mixer in the intake or just the ring like what is on the e-gas cars?
Old 29-05-2010, 09:11 PM   #9
GTLexus
GTLexus's Avatar
it has a mixer on the intake pipe.
this was checked by an lpg mechanic as well.
The car is definitely idling roughly and extremely rough on acceleration.
I will find how to chack the sensor first as it will be easier and if OK go the balancer route. Went to start it today and it has a flat battery so have put it on charge and with the weather we are having in Sydney I won't be able to test it until it clears up (the P6 LTD takes up both garages
Old 18-08-2010, 05:19 PM   #10
fordlover
FORD-LOVER
fordlover's Avatar
Exclamation
common on the 6cyd engines too
bf mk2.5 ego xr6
fordlover is offline   Reply With Quote Multi-Quote with this Post
