Old 13-07-2011, 07:50 PM   #1
jcto
JCTO AUII Falcon
Default Engine baulking when turning right
Hi all, I have a strange but true problem........when I am turning right from a standing start and accelerate, my engine seems to die then comes on again. It happens on a tight R/H turn or a not too tight R/H bend. Doesnt do it turning left or accelerating straight. It has me baffled. Any ideas??????
jcto is offline   Reply With Quote Multi-Quote with this Post
Old 13-07-2011, 08:14 PM   #2
Zero_PSI
Zero_PSI's Avatar
Default Re: Engine baulking when turning right
Could be a problem with the power steering pump
Zero_PSI is offline   Reply With Quote Multi-Quote with this Post
Old 13-07-2011, 08:17 PM   #3
sd1800
Is it a 6cyl?
First thing that comes to mind is power steering switch.......
Formerly LV Focus XR5, AU Fairmont Ghia V8 & EBII Fairmont I6.
Now......
2012 FG MK2 XR6 Turbo
- Manual & Luxury Pack
- 302rwkw
2019 Escape St-Line
sd1800 is offline   Reply With Quote Multi-Quote with this Post
Old 13-07-2011, 10:57 PM   #4
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
hmm i remember back in the day i had an old carby-fed car and it didn't used to like turning hard
come to think of it, there may have been opposite lock involved.
Old 14-07-2011, 01:16 PM   #5
macman
macman's Avatar
Might be a stupid suggestion but... traction control playing up or cutting in because of a sensor issue?
Does it feel like power being cut?
Do the ABS/TC lights come up on the dash when it happens?
macman is offline   Reply With Quote Multi-Quote with this Post
Old 14-07-2011, 03:25 PM   #6
jcto
JCTO AUII Falcon
Yes it is 6 cyl....
Power steering switch?? what is that and where is it?? Apology for the lack of knowledge.
Power steering pump? Seems to be working ok, no leaks or whining etc.
macman, It is a SII Forte....so no traction control or ABS....I am just a lowly pawper.
But yes it feels like the engine totally dies, i dont lose power steering just the engine hits a huge dead spot and then comes back to life like nothing has happened......sort of like my wife during sex rofl...sorry couldnt resist.
Old 14-07-2011, 03:37 PM   #7
Donny
Tickford 220kw Windsor...
Donny's Avatar
Could be a fuel issue. Maybe part of the fuel pump pickup is blocked on one side. Or a wiring short that only catches when the chassis is torqued in the correct way.. Could be a plug not correctly plugged in, or some corrosion on a plug that causes a break when turning in that direction..
1972 Falcon XY GT 351 Clevo 4V Big Port, 4 Speed Top Loader Manual, Ice Blue....
2002 Tickford AU Series III XR8 220kw Windsor, 5 Speed Manual, Liquid Silver...
Donny is offline   Reply With Quote Multi-Quote with this Post
Old 14-07-2011, 04:25 PM   #8
robbyj
Rob
robbyj's Avatar
how long has it been going on for ?
could be a simple thing like bad fuel, my au doesnt like shell fuel, engine cuts out when accelerating if i use it sometimes.
Supercharged Nissan 350z 280rwkw
Blueprint series 3 AU V8 manual
robbyj is offline   Reply With Quote Multi-Quote with this Post
Old 14-07-2011, 05:36 PM   #9
james22
With da Warlords
james22's Avatar
How much fuel do you have in the tank when this occurs?
If you have a 1/4 or less, it could be the fuel flowing to the side of tank, car starves of petrol as there is no pickup, straighten up and off you go again.
I know my xr8 did this till i rotated the pump/pickup 90*
Windsor Warlords
AU III XR-8220
300+ rwhp of Manual fun
Old 14-07-2011, 05:36 PM   #10
jcto
JCTO AUII Falcon
Its been happening for about 2 years and is just starting to get the better of me, especially when a silly Bomadore beats me because of it. Grrrrrrr.
I will look into the power steering pressure switch idea as that makes a bit of sense
