Old 04-09-2007, 09:29 PM   #1
blu falc
acclaimed user
Default ABS and Traction control turning themselves off!!
Sometimes after a full power gear change my ABS and/or traction control will de-activate (traction control light turn's on, abs light turns on)
This isn't just some warning as I slammed the brakes and they all locked up which proves that ABS was definately off.
Also when this happens I can't turn traction control back on using the button, I have to turn the ignition off then back on, after that the ABS and T/C are activated again and I can turn the T/C on or Off at will.
Why are the hard shifts doing this?
I have the S5 bypass shiftkit installed, but I ran it for at least 1.5months without any problems.
The problem started after I installed a K&N pod filter, this problem was just with T/C staying de-active.
Then just this week after installing the superlow springs the ABS problem has surfaced.
Help :(
blu falc is offline   Reply With Quote Multi-Quote with this Post
Old 04-09-2007, 09:52 PM   #2
AUXRVIII
The fault is with the ABS system, traction control works with ABS which explains the trac light coming on.
Fault could be a wheel speed sensor but without code testing I could only guess, maybe someone else has seen this happen and they could help.
AUXRVIII is offline   Reply With Quote Multi-Quote with this Post
Old 04-09-2007, 09:59 PM   #3
blu falc
acclaimed user
where can I take it to get a diagnostics reading cheap? this would have lodged a fualt code right?
Old 04-09-2007, 10:09 PM   #4
AUXRVIII
Yes there should atleast be a memory code present.
Old 04-09-2007, 10:20 PM   #5
blu falc
acclaimed user
thanks for your insight
Does anyone else have anything to add?
Old 04-09-2007, 10:47 PM   #6
blackers10
blackers10's Avatar
mine started out as both lights comming on intermitently
now both abs and t/c light are on constantly..
only thing i have is a spongy brake pedal..
has been fine for the 6 months plus the lights have been on for ...
so dont worry too much
On The Street Feature Winner Performance Ford Mag
See my car at:-www.aufalcon.com/blackers10
blackers10 is offline   Reply With Quote Multi-Quote with this Post
Old 04-09-2007, 11:09 PM   #7
blu falc
acclaimed user
my biggest concern is I don't have ABS when the light comes on, I usually turn T/C off anyway
what event/mod started your woes blackers?
Old 05-09-2007, 08:34 AM   #8
blackers10
blackers10's Avatar
im not sure what started mine..
Old 05-09-2007, 08:46 AM   #9
AUXRVIII
I should have made it a bit clearer, if there is an ABS fault the traction crontrol system is automatically switched off, hence the T/C light coming on.
Old 05-09-2007, 12:52 PM   #10
blu falc
acclaimed user
but the T/C light was coming on a few weeks before the ABS light was coming on, does that still prove your theory?
Old 05-09-2007, 05:32 PM   #11
eXi7w0unD
eXi7w0unD's Avatar
that what my car does, so im taking it to ford next monday :S
i won.
eXi7w0unD is offline   Reply With Quote Multi-Quote with this Post
Old 05-09-2007, 06:54 PM   #12
AUXRVIII
Could be some sort of ABS malfunction which was bringing on the light. Without seeing the car it's not really possible to diagnose the fault, could be wiring rubbed through causing a short, water entering a connector or even low tyre pressure or different brand/size tyres fitted. I have seen different brand tyres front to rear in the same size cause this fault.
Old 05-09-2007, 09:45 PM   #13
Brisbane ghia
Brisbane ghia's Avatar
My traction and abs lights came on every now and then, took it to ford and had a rear wheel speed sensor replaced, i think it was approx $150.
Brisbane ghia is offline   Reply With Quote Multi-Quote with this Post
Old 06-09-2007, 02:31 AM   #14
blu falc
acclaimed user
cheers guys, my front-rear tyres are different size and brand. I've had 18's sitting here for months but was holding out untill I got the car lowered. Hopefully the new rims sort the problem
Old 06-09-2007, 08:49 AM   #15
blackers10
blackers10's Avatar
but the size of tyres shouldnt change the speed the abs sensors roll at...
as the rear is at the diff
the front is at the wheel.
so it should roll the same??
Old 06-09-2007, 08:49 AM   #16
blackers10
blackers10's Avatar
deb had my wheels on(225/30/20 and 245/35/20) for about a week and her abs and tcs lights never came on
Old 06-09-2007, 09:53 PM   #17
AUXRVIII
The ABS sensors read off the tone wheels on the axles or drive shafts, if the rear wheel/tyre outside diameter is smaller than front then this can be read by the ABS module as loss of traction as the rears will be spinning faster than front or a fault can be logged as the ABS module thinks there is a correlation fault between the front and rear wheels.
Old 06-09-2007, 10:02 PM   #18
blackers10
blackers10's Avatar
fair enough
would be nice if the speedo ran off them too eh!! then we wouldnt need to get creative when we change diff gears hehe
Old 06-09-2007, 10:19 PM   #19
AUXRVIII
fair enough
You would think so but the speedo is still affected as the speedo is calibrated with the wheel/tyre size. If wheel/tyre size is changed on BA/BF the applicable modules need the parameters changed.
Old 18-07-2019, 02:31 AM   #20
TickfordTiger
Default Re: ABS and Traction control turning themselves off!!
Recently I finally had my ABS / Traction Control fault FIXED finally on my AU2 Ford Fairmont 280,000kms plus ( with LPG). After a couple of years with both the ABS & Traction control light on (note: Traction light always ON which denotes turned when LPG selected) and checking all 4 wheel speed sensors / abs tone rings that fault was with the Bosch ABS module itself. After plugging in a Snap On tools EU device it showed that it could not communicate to the ABS unit or 'was not present'. I found a auto elect guy on ebay who repairs these unit ( plus Bosch ABS units for other cars also). I sent the unit to him and had it returned repaired with LIFETIME warranty! The fault is with ABS & TRACTION models for AU 1 2 3. Apparently the wire connection inside the ABS control unit is weak over time inside the ABS control unit ( where the loom is plugged into) on the side of the ABS pump. Other Fords during this AU era that have ABS only were not affected with this issue. Available on ebay : https://www.ebay.com.au/itm/Ford-AU-...r/183771054714
T1 TL50 Build No. 014 - Liquid Silver
T1 TL50 Build No. 017 - Liquid Silver, Sunroof
TickfordTiger is offline   Reply With Quote Multi-Quote with this Post
Old 23-07-2019, 01:34 PM   #21
NorfyXR6
ⒷⒶ ⓍⓇ➏
NorfyXR6's Avatar
I recently bought a 98 AU S1 Fairmont Ghia. Both the ABS and TC lights are on and the TC button doesnt seem to do anything. Mechanic said not throwing any codes and suggested replace the master cylinder as it is leaking.
Quote is $610 + labour
My questions are:
-would a leaking master cylinder cause the abs/tc lights to come on? (My own research seems its more likley a abs module or abs sensor)
-are the abs module and master cylinder a single unit or separate? (Mechanic said it is a single unit but im not so sure)
-if a master cylinder is leaking can the washers or whatever be replaced or is it a case of chuck the full part?
Thanks for any advice.
2009 TS SY MKII RWD Territory - Mystic Green
1998 AU Fairmont Ghia - Amaretto
Only 170,000kms - Factory: Tickford Intech VCT 6cyl Engine, 17" Tickford Rims, IRS, ABS/Tracton Control, Premium Sound
First:
2003 BA XR6 - Vixen Red (RIP)
K&N/Typh CAI/Terry Intake pipe, 4490s, 100cpsi cat, Herrod 2.5" MS exhaust/3" SS Tips, 20% Underdrive,
PWR Transcooler, Elec Shiftkit, Destino wheels, Leather Interior/console lid, Interior Neons, SAASII Gauges,
Tint, BF Tail lights
NorfyXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 24-07-2019, 01:58 AM   #22
TickfordTiger
Hi NorfyXR6,
The master cylinder will have nothing to do with this problem I dont believe.
When your mechanic says " not throwing any codes " is probably because the ABS unit is faulty and will not communicate with the Scan tool device - ie will not detect or recognise the ABS module.
Feel free to do that test first and see if it can detect an ABS system.
If it cant see it -the module is faulty and should be replaced or repaired (better with lifetime warranty) as per the Ebay ad on my last post. only $150 !
Once my unit was repaired it worked perfectly immediatley and the lights cleared on start up and could be seen by the Scan tool when connected.
Good luck.
Old 24-07-2019, 03:57 AM   #23
NorfyXR6
ⒷⒶ ⓍⓇ➏
NorfyXR6's Avatar
Thanks for that.
Yeah i had a look at the ebay link before! Would much rather $150.
So the abs module is separate to the master cylinder?
As i said i was told they come as a unit for $610, but from reading around and what you wrote it appears they are separate parts?
A lot of money to spend on a 'it might fix it'.
As for the codes i took it to the mechanic and he tried to diagnose and just said no codes so he didnt know. Never mentioned about the module not communicating so assume he didnt consider that. And i dont have a scanner. Might have to get a second opinion.
Thanks for your help. Im new to the AU series
Sent from my SM-G920I using Tapatalk
First:
