Old 11-05-2009, 01:47 PM   #1
lindsay.hannay
Default oil leak
doe's anyone know if it is easer to replace the timing cover and sump gasket by taking the motor out ocan it be done in place.
lindsay.hannay is offline   Reply With Quote Multi-Quote with this Post
Old 11-05-2009, 08:16 PM   #2
FTe_XR8
formerly "3x-puursui7"
whats leaking? the timing cover or the sump gasket? because you can reseal the timing cover without dropping the sump, fairly easy job as i did mine last weekend, but don't know about the sump?
all hail the mighty V8's
http://www.aufalcon.com.au/3x-puursui7
FTe_XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 11-05-2009, 08:55 PM   #3
lindsay.hannay
Had diagnosed as both leaking at last service
Old 11-05-2009, 09:05 PM   #4
bodes-sh
you should be able to jack the car up and remove the crossmember to drop the sump. i got one out with the motor in the car in an ea, but that was a pain...
i think the lower suspension control arms bolt into the crossmember, so this is why you need to jack the front end up. shouldn't be a very difficult job...
i'm sure someone will tell you otherwise if it can't be done.
