Old 21-12-2020, 03:32 PM   #91
Bossxr8
Peter Car
Bossxr8's Avatar
Yes, but around $2200 each..
Ouch.
Old 21-12-2020, 04:46 PM   #92
G'day Blue i found this it may be of interest, i know it's not Motorcraft but it will be the next best thing Inox MX7 Made here in Australia - Queensland
Thanks it turns out it was a manufacturing fault and Toyota are fitting a whole new drive shaft. If you are interested in the back story see https://www.newhilux.net/phpbb/viewt...435231#p435231 and I had already bought this equivalent https://www.supercheapauto.com.au/p/...010708#start=8
Old 05-01-2021, 05:30 PM   #93
Dingo
Ford T3 Partsologist
Dingo's Avatar
G'day GT
Are you able to please do some digging to see if Ford may have some Parts Drawings on these 4 Part Numbers as i can't find anything on Micropuss
TAU3-15W202-A Driving Lamp Mount Bracket
TAU3-15K230-A Driving Lamp Reinforcement
TAU3-15260-A Stud
TAU3-15280-A Driving Lamp Mount Bracket
thanx Aaarrrroooooooooo
2002 Blueprint T3 TE50 Manual Koni Suspension # 161
T-Series Club of Australia - www.tseriesclub.org
Dingo is offline   Reply With Quote Multi-Quote with this Post
Old 05-01-2021, 06:17 PM   #94
GTLEGEND
Originally Posted by Dingo View Post
G'day GT
TAU3-15260-A Stud
Ill see what I can find out, but alot of that stuff has been archived with no access since it was a Tickford/FPV items.
Old 10-01-2021, 10:00 AM   #95
galaxy xr8
Giddy up.
galaxy xr8's Avatar
Chasing some OEM rubber bushes on the AUII XR8 IRS rear suspension, I'm not exactly sure what part but I believe they are the outer top and lower control arms ?
Old 10-01-2021, 12:57 PM   #96
GTLEGEND
Have a look at the image below, ID what number you need and we can see if they are still available and go from there.
Old 10-01-2021, 01:45 PM   #97
galaxy xr8
Giddy up.
galaxy xr8's Avatar
Thanks mate, I'm trying to attach a pic but its saying my files are to big, etc..
Old 10-01-2021, 01:52 PM   #98
GasoLane
Former BTIKD
GasoLane's Avatar
Use Postimage
https://postimages.org
Old 10-01-2021, 02:03 PM   #99
galaxy xr8
Giddy up.
galaxy xr8's Avatar
get picture url
It's the rubber either side of the "L" side control arm with the bolt going through, you can just see the rubber is perished but its the same on both sides and also both sides of the car.
Old 10-01-2021, 02:21 PM   #100
galaxy xr8
Giddy up.
galaxy xr8's Avatar
Does that look like part number'd 25 in that diagram ?.
Old 10-01-2021, 04:21 PM   #101
GTLEGEND
imageget picture url
Ok so thats parts 3, 4 and 5 from my image. Part numbers below.
3= ER 5B639 F
4= ER 5B639 G
5= ER 5A659 G
Will look around and get back to you..
Old 10-01-2021, 05:37 PM   #102
galaxy xr8
Giddy up.
galaxy xr8's Avatar
3= ER 5B639 F
4= ER 5B639 G
5= ER 5A659 G
It's only the ends that have the single arm, not where it splits and has a double arm, so I think its part number 5, I will take a better pic and see if I can show exactly the rubbers better,
Cheers.
Old 10-01-2021, 06:39 PM   #103
GTLEGEND
Cannot see the image, but 25 is part pf the lower arm where the lower part of the shock connects to as well.Part 25 has a part number of ER 5A659 F.
Do you need that as well?
Will need to check later...
Old 10-01-2021, 06:51 PM   #104
mcfly94
mcfly94's Avatar
You want the upper Hyme joint that the stub connects to? (Same place camber is adjusted)
Which is #5
#25 is the lower Hyme joint in the LCA.
#24 is a pressed rubber bush where the shock bolts too.
Current Car: 2002 AUII LTD
408ci Windsor, T6 S488, TH400, 2 Piece Shaft, Helicial LSD 3.23 IRS
Daily: 1998 Mitsubishi Super VR-4 Legnum
mcfly94 is offline   Reply With Quote Multi-Quote with this Post
Old 12-01-2021, 01:30 PM   #105
Bossxr8
Peter Car
Bossxr8's Avatar
FG G6E Turbo lip spoilers. Still available or NLA?
Old 12-01-2021, 03:50 PM   #106
GTLEGEND
Boot lip spoiler I gather you are referring to?
Yes but a around $1100 retail and you then need to paint it. I can get it for around $960 + postage if required.
Old 12-01-2021, 05:14 PM   #107
galaxy xr8
Giddy up.
galaxy xr8's Avatar
These are the rubbers I'm referring too, hopefully this makes it clearer.
Old 12-01-2021, 05:18 PM   #108
Bossxr8
Peter Car
Bossxr8's Avatar
Yeah boot lip. The prices are just silly. Problem is the factory ones split down the middle due to hot/cold cycling. And the aftermarket ones all look different/are chunkier.
Looks like repairing the original is the cheapest way. Problem is getting it off to fix it without scratching the bootlid at the same time.
Thanks mate.
Old 12-01-2021, 05:49 PM   #109
GTLEGEND
Ok unfortunately out of those two parts, the lower bush/joint is the only one I am able to get. I will need to find a price if you are interested. The upper one is obsolete from Ford.
Old 12-01-2021, 10:10 PM   #110
galaxy xr8
Giddy up.
galaxy xr8's Avatar
No worries mate, if you could get a price that would be appreciated , thanks.
Old 14-01-2021, 04:16 PM   #111
GTLEGEND
Hi mate,
I can get those bushes for $120 each plus freight to you. There are only two left then they are all gone. Let me know if you want one or both hoping they dont get bought before.
Up to you know.
Cheers,
GT
Old 15-01-2021, 06:57 PM   #112
Bluehoon
Hoon On The Rise
Bluehoon's Avatar
Hi Mate,
Is there any alarms kits for FGX lying around?
I'm pushing my luck I know.
Stomp 'n' Steer
FGX-XR8 Manual, BFII E-Gas, '11 GSXR 1000 - Love 'em!
FPV Tickford Club of NSW - www.fpvclub.com
Bluehoon is online now   Reply With Quote Multi-Quote with this Post
Old 15-01-2021, 07:07 PM   #113
GTLEGEND
Originally Posted by Bluehoon View Post
Hi Mate,
No good, if its any help the kit part number is BG 19A361 AA. Keep your eye out of ebay etc..
Old 15-01-2021, 07:20 PM   #114
Bluehoon
Hoon On The Rise
Bluehoon's Avatar
Cheers. Thank you.
Next one. Water pump kit for Coyote V8.
http://www.fordforums.com.au/showthread.php?t=11405157
BR3Z-8501H-HK1T
AC3Z-8527-A
7T4Z-8590-A
Will follow your advice on other parts needed.
Thank you
Stomp 'n' Steer
Old 15-01-2021, 07:37 PM   #115
GTLEGEND
Cheers. Thank you.
BR3Z-8501H-HK1T $200 + freight if required.
AC3Z-8527-A $30 each + freight if required.
7T4Z-8590-A $9 each + freight if required
Thank you
Yes all still available, prices above in red.
Old 16-01-2021, 06:05 PM   #116
notNA
Are you able to source a dash matt for the fgx with the cut out around the airbag and top of the ICC, all the new ones have it covered
notNA is offline   Reply With Quote Multi-Quote with this Post
Old 16-01-2021, 06:40 PM   #117
GTLEGEND
Sorry mate, all the genuine ones have been long gone. Part number you would be looking for is BG F042M82 AA.
Old 18-01-2021, 11:44 AM   #118
rare ss
rare ss's Avatar
Any chance of getting drivers side outer door belt seals for a BFII?
Screenshot 2021-01-18 074224 by LE Group 3 Brock, on Flickr
rare ss is offline   Reply With Quote Multi-Quote with this Post
Old 18-01-2021, 01:36 PM   #119
GTLEGEND
imageScreenshot 2021-01-18 074224 by LE Group 3 Brock, on Flickr
I can still get both fronts @$75 each plus freight.
Rears are obsolete, but I did manage to find RHR on eBay. See below, suggest you get that one because they are rare to find new now.
https://www.ebay.com.au/itm/Ford-AU-...oAAOSwjMteaelU
Old 21-01-2021, 10:21 PM   #120
SZterritory
My 2016 Territory is off the road due to needing a new brake booster. The dealer can’t source one as it doesn’t appear to be any in stock anywhere.
Recommendations of where I might get a brake booster for 2016 Territory?
SZterritory is offline   Reply With Quote Multi-Quote with this Post
