09-10-2006, 06:22 PM | #1 | ||
Thought I would get my 98 series 1 AU ready for the summer heat today so I went ahead and did a coolant flush and put in a new thermostat while I was at it.
I refilled with Nulon Ultra cool, it contains no glycol (what is that?),and is approved for motorsport use, I thought being approved for motorsport use,it might just give it an edge as they run hot at the best of times and it was only $10 I have heard good and bad about nulon,I did my diff with the gearbox treatment and it is like new, I am very happy with that,but the question is have I brought the right stuff for my beast as I would hate to cook her. any advice would be appreciated http://www.nulon.com.au/products.php?productId=r45 |
09-10-2006, 06:27 PM | #2 | ||
might I add that it seems to run cold,followed all directions,genuine Ford thermostat but the needle sits just under the N or just on it,I thought it might sit on O going by what I have just searched,flushed the system completely and refilled to exact specs on the bottle
09-10-2006, 06:34 PM | #3 | |||
09-10-2006, 06:35 PM | #4 | ||
I was going to get this for my AU, but was told it was no good for cars with aluminium radiators, so I've never bothered myself. Can't see why it wouldnt work but I just bought the Ford antifreeze/boil to be on the safe side.
09-10-2006, 08:04 PM | #5 | |||
09-10-2006, 08:42 PM | #6 | ||
im pretty sure glycol is the stuff that makes your coolant antifreeze or antiboil or both.
i know a while ago there was a coolant that was not safe for iron and aluminium at the same time use, might want to read the label.
My Cars: 2002 Ford Falcon AU S3 SR 2006 BF MKI Falcon XR6 2008 Mazda BT50 SDX 2004 BA XR8 ute 2006 AUDI A4 B7 2013 FG II XR6 Ute 2006 Ford Territory TX 2003 Ford Falcon XR8 2009 Territory Turbo Ghia Current: 2012 Audi A4 B8 2.0T Quattro |
09-10-2006, 08:43 PM | #7 | |||
09-10-2006, 09:23 PM | #8 | ||
SS Grunt
Basically what you have put in is just a lubricant for the pump and a anti rust and corrode in there, so your water will still boil at around 105deg and with the au's they run around 90-100deg so your not playing with much. But if it runs cool then it should be ok.
Shaun
The Beast has gone to a new home Morpheous VE SS 6LTR 6speed Manual in its place, Leather, Lowered, 20's, Ramjet OTR and Dual 3inch, 280RWKW I will also enter any part of the Forum I wish to enter. : |
09-10-2006, 09:53 PM | #9 | ||
Mr Polish
Sounds like a nice product. I am also using a glycol free coolant. Glycol is an anti freeze.
I ain't in victoria so I dont need it My AU's rad (original from factory) ain't aluminium.
Detailology colour fx detail studio and R&D Lab SA's leader in auto detailing and paint treatments |
10-10-2006, 12:17 AM | #10 | ||
i would change that coolant asap.. you are meant to have an even mix or glycol and water. 50/50. and was the thermostat you got the standard one with the correct temp.. if not, change instantly too.
11-10-2006, 12:03 AM | #11 | ||
Mr Polish
Don't think so. Been using another glycol free brand without probs for many years
