Old 08-10-2006, 09:34 AM   #1
JeffAU1
JeffAU1's Avatar
Default New Oxy Sensor - cant find it
I have the new sensor ready to fit, but for the life of me i cant find where it is...can someone tell me please ?
what do i have to do to replace it ? unplug first ? can i leave the batteryconnected?
unscrew counter clockwise like normal ?
how tight do i have to tighten it back up ?
anything else to be aware/careful of ?
Thanks
:eclipsee_ MY CAR :eclipsee_
JeffAU1 is offline   Reply With Quote Multi-Quote with this Post
Old 08-10-2006, 09:46 AM   #2
Casper
Contributing Member
Casper's Avatar
It plugs into the exhaust.. below the manifold.
Just unplug the ires first and then unscrew it as per normal. Screw the new one in (decent tightness, similar to a sparkplug) and replug in the wires.
You dont need to disconnect the battery but its probably better to do so to reset the ECU.
Older, wiser, poorer.
Old 08-10-2006, 10:06 AM   #3
JeffAU1
JeffAU1's Avatar
ive never changed a spark plug
say hand tightness plus 1 revolution with a shifter ??
Old 08-10-2006, 10:11 AM   #4
XRQTR
TBA Customs
XRQTR's Avatar
Disconnect the battery before you start, this way you can reconnect as soon as you have replaced the sensor, start the car and check for leaks and tighten as needed.
XRQTR is offline   Reply With Quote Multi-Quote with this Post
Old 08-10-2006, 10:23 AM   #5
JeffAU1
JeffAU1's Avatar
hmmm leaks ?
what will leak ?
will it leak when i take the old one off to replace it ?
Old 08-10-2006, 10:25 AM   #6
GK
Walking with God
GK's Avatar
Have a really good look at the old one, how far in it goes etc.
Undo the old one, and see the thread length.
Screw the new sensor in until it becomes hand tight. Check to make sure that there is no thread still needing to be wound in (Remembering from the old one, and what you can now see on the new one). Then using the shifter, nip it up a little. The sensor itself is small and won't need Herculean strength to keep it in.
See how you go.
All the best with it.
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 08-10-2006, 11:11 AM   #7
JeffAU1
JeffAU1's Avatar
All done
And it was that easy...
I left the battery unpluged for 10mins.
Then when i plugged it back in it came up with mode on the dash
It this enough time to reset the ECU ???
Old 08-10-2006, 11:38 AM   #8
TwistedEL
TwistedEL's Avatar
More than enough you will need to do the relearn procedure
Old 08-10-2006, 12:22 PM   #9
peterban
AULTD
peterban's Avatar
Thanks
Why did you need to replace it?
What symptons did your car have and did it fix them?
peterban is offline   Reply With Quote Multi-Quote with this Post
Old 08-10-2006, 12:53 PM   #10
JeffAU1
JeffAU1's Avatar
There was nothing wrong with my car, i just wanted to get better fuel economy.
I wont know if it has worked until i go through a few tanks.
Old 08-10-2006, 12:56 PM   #11
TwistedEL
TwistedEL's Avatar
1st tank will probably be worse than before due to ECU relearn. Tank after that should give you results.
Old 08-10-2006, 01:11 PM   #12
JeffAU1
JeffAU1's Avatar
What if i dont do the relearn process ???
Old 08-10-2006, 01:12 PM   #13
ratter
ratter's Avatar
it will relearn itself anyway, it will just take a little longer
Pit Lane Performance
Old 08-10-2006, 01:14 PM   #14
bodes-sh
it will learn anyway, it'll just take longer thats all, and probably use more fuel in the process...the learn procedure is just basically so it knows what speed to idle at in gear, out of gear, air con on and air con off...then the drive is just to get mixtures right for cruising and accelerating again
Old 08-10-2006, 01:17 PM   #15
JeffAU1
JeffAU1's Avatar
Sweet i'll let ir relearn itself.
Thanks all :P
Old 08-10-2006, 03:34 PM   #16
bodes-sh
i should warn you though that you may experience unstable idle and stalling if you let it relearn itself...you had better watch out for this especially in an auto being that you can't restart it in gear
Old 08-10-2006, 06:37 PM   #17
JeffAU1
JeffAU1's Avatar
Yeah it has alot of unstabling idling ATM, and it seems to have a little more troulbe starting up.
WIll this fix itself ? If so, how long will it take ?
Old 08-10-2006, 06:44 PM   #18
ratter
ratter's Avatar
O2 sensor should not effect starting
Old 08-10-2006, 06:57 PM   #19
bodes-sh
no, it doesn't, but disconnecting the battery does....maybe also give your ISC valve a clean if you haven't already
Old 08-10-2006, 07:30 PM   #20
JeffAU1
JeffAU1's Avatar
whats my isc valve ?
Old 08-10-2006, 09:34 PM   #21
poolkeeper
Its Resonating!
poolkeeper's Avatar
Im guessing this new oxy sensor will give you a wheee bit of performance/response?
poolkeeper is offline   Reply With Quote Multi-Quote with this Post
Old 08-10-2006, 09:48 PM   #22
bodes-sh
isc - idle speed control, looking from the front of the car, theres a metal thing with a wire hanging out of it on the throttle body, where the intake pipe connects to the engine, to the right of that...thats the isc valve, this is the thread relating to where it is and how to clean it
http://www.fordforums.com.au/showpos...9&postcount=43
