Old 17-07-2007, 08:17 PM   #61
russellw
russellw's Avatar
Originally Posted by Bokk
russellw great diagrams, was wondering if you have a schematic that covers the Oxy Sensor to the ECU, keep up the good work....I,m doing a project car that i'm installing the oxysensor in, have the ECU and fuel/air mixture gauge etc
The schematic for that (either 6 or 8) can be found HERE
Russ
Old 18-07-2007, 03:55 PM   #62
Bokk
Russ
Thanks Russ did have a look at that but doesnt cover the O2 sensor, I had a look at the other drawings on ECU and it does have the pin numbers for the heated exhaust (4 and 35) but cant see the signal pin on drawing.
Regards
Bokk is offline   Reply With Quote Multi-Quote with this Post
Old 23-07-2007, 03:05 PM   #63
pbellamy
Default Au falcon thermo fans circuit diagram
which wiring diagram has the thermo fans? I've looked on the BEM ones but can not find them
pbellamy is offline   Reply With Quote Multi-Quote with this Post
Old 07-08-2007, 07:02 PM   #64
99VCTFairlane
hey russell, i got au I fairlane.... double din premium sound setero with the 6cd stacker in the boot. Was wondering if you have the diagrams and legend for all the wires at the back of the head unit ie. which wire does what? there is two different plugs at the back as well as the antenna. Im putting a dvd screen in and would be great if i know what the wires all mean coming from the loom.
thanks
99VCTFairlane is offline   Reply With Quote Multi-Quote with this Post
Old 07-08-2007, 08:16 PM   #65
russellw
russellw's Avatar
You will need to look up the connector number and then look up the connector seperately in the connector diagrams - this should show you all the wirs and the master diagram will show you the actual assignments.
Russ
Old 10-08-2007, 12:32 AM   #66
99VCTFairlane
thanks buddy got it all under control now thanks alot, great diagrams
alex
Old 19-08-2007, 09:06 PM   #67
smee
FishermanDan
smee's Avatar
Is there underhood wiring diagram for sensors to ecu pin numbers ie cam angle, knock, T-map & ign coil pak?
smee is offline   Reply With Quote Multi-Quote with this Post
Old 20-08-2007, 12:35 AM   #68
russellw
russellw's Avatar
There are two tech docs in the technical area that cover the EEC-V system in detail along with simplified wiring diagrams.
Click on the link to Technical Resources on the menu bar above and then look under Technical Documents.
Russ
Old 24-09-2007, 09:13 PM   #69
dansau1
Cool
[FONT=Arial Black]does any one know where i can get a enigne to ecu wiring diagram for a 2000 au xl ute[/FONT]
dansau1 is offline   Reply With Quote Multi-Quote with this Post
Old 10-10-2007, 08:21 PM   #70
dansau1
Default au ecu wiring diagrarm
hey im looking for a wiring diagrame for an au falcon 4.l 6 so i can wire in my wolf v500
Old 14-12-2007, 08:36 PM   #71
dave610
thnaks was very helpful, ui have installed the dvd and the dvd radio adn tv all works i jsut cant get the soubnd to come out of the speakers.. any thing i may be doing wrong??
and the blue cord coming from the dvd saying back is not connected to anythin maybe this has something to do with it but everythin else is working
dave610 is offline   Reply With Quote Multi-Quote with this Post
Old 04-01-2008, 11:19 AM   #72
Adgum
Adgum's Avatar
Does anyone no if there is possibly a AUX port at the back of the Stock CD player/radio in the AU Fairmont?
Egotism is the anesthetic that dulls the pain of stupidity
Adgum is offline   Reply With Quote Multi-Quote with this Post
Old 04-01-2008, 08:04 PM   #73
last fairlane
last fairlane's Avatar
Question AU Fan
Hi can someone help
My aircon fan in the dash of my AU Fairmont Series 1 has gone troppo and only works on H which is flat out if I try 1 2 3 4 5 6 7 8 or9 I get no air at all only air on H any ideas thanks JOHN in Brisbane also looking for a rear wing in Mercury silver for my BA Ghia thanks
last fairlane is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2008, 05:44 PM   #74
joelmtj
jeffro
Default au xr6 wiring
hi
does any one know what colour the wire is (in the harness to my stereo) that makes the controls on the steering wheel work? and the colour of the one that you can put an amp into. cheersss
joelmtj is offline   Reply With Quote Multi-Quote with this Post
Old 01-03-2021, 02:25 AM   #75
brett nelson bay
Default Re: New Tech Article - AU Wiring Diagrams **UPDATED**
so google sent me to this link when searching for au falcon wiring info,
so will post on this old old thread.
the wiring shown on this link for au falcon
http://www.fordforums.com.au/vbporta...?articleid=688
it shows the pcm/ecm connector info, I have au1 1999 model, and colours
are different to that shown. so assume that shown is for au2 or au3
if anyone requires correct colours for au1 drop me a message
brett nelson bay is offline   Reply With Quote Multi-Quote with this Post
Old 02-03-2021, 10:39 PM   #76
brett nelson bay
have modified pcm wiring pinout for au1 falcon, it has two extra wires not yet established what they are for at pins 7 and 44. Colours for au1 that are different to au2 and 3 shown also.
had to split into 4 pics to upload, you can cut/paste them into one pic
tried to upload as one pic but to get the min file size ( 147kb) none of the
writing was readable.
