Old 14-08-2005, 04:46 PM   #1
henz79
Default Knocking sound after my lowering job
Hi mates,
Well i just finished lowering my EA with PEDDERS product and it looks so nice. But driving it theres a anoying knocking sound from the back. I double check itn and retighten the nuts and its still the same. Is this normal or not. Any ideas and thoughts will be appreciated. Thanks die hard EA fan
:SaiyanSmi
henz79 is offline   Reply With Quote Multi-Quote with this Post
Old 14-08-2005, 04:58 PM   #2
klawsterfobik
Bad Music and Litre Bikes
klawsterfobik's Avatar
Could be the exhaust hitting on the Diff, or rear axle. Have you checked the clearance between the two?
Does it do it just when driving, or more so when you go over bumps etc?
XY Wagon - NAKED!
Originally Posted by Gammaboy
Anyway. Enough reality, back to the topic.
klawsterfobik is offline   Reply With Quote Multi-Quote with this Post
Old 14-08-2005, 05:05 PM   #3
niko
likes falcon's
niko's Avatar
suspension works harder wen u lower.
www.carhubsales.com.au
Old 14-08-2005, 05:11 PM   #4
LUXO_8
windsor user
once the car settles you have to jack it up again and retighten all the shock bolts / nuts.
if you dont it will clunk like anything
chances are this is the problem
Old 14-08-2005, 07:35 PM   #5
INJECTED_250
Custom user title
INJECTED_250's Avatar
sounds like the shockers arnt tight.. cHeck the nuts inside the car
INJECTED_250 is offline   Reply With Quote Multi-Quote with this Post
Old 14-08-2005, 08:32 PM   #6
Age182
GMHKLA number plates
Age182's Avatar
my car makes a knocking noise i just put mi exhaust system on and its that hitting the body but my exhaust rubbers wer cracked so i might replace dem first
Currently owned: 1997 Hyundai Excel (the daily)
2009 FG FPV F6 Silhouette Auto
Previously owned:
1994 EF fairmont Ghia 4.0Ltr, AUTO
14.620@93.3mph
2000 Honda S2000
14.73@92mph (stock + no traction)
Age182 is offline   Reply With Quote Multi-Quote with this Post
Old 14-08-2005, 08:45 PM   #7
Low_Falcon
When i lowered my car i heard a knocking sound and it was the tailshaft knocking on the body.
Old 14-08-2005, 08:59 PM   #8
EA_Bender
Hmmm Gold!!!
EA_Bender's Avatar
when i got mine done it started knocking after driving a couple of k's, took it straight back and tightened them up, no more knocks
1990 EA Series 2 Fairmont, Low Springs and shocks, 17 x 7 Advanti Flash Mags running on Falken rubber :, EL XR8 Sway Bars, NGK Iridium Plugs, New Trip Comp, Pacemaker 4480, 2.5 system 4L ED engine with surecam
Now Sporting - OED666's 202+ RWHP engine!! :dj: fully
EA_Bender is offline   Reply With Quote Multi-Quote with this Post
Old 14-08-2005, 09:35 PM   #9
Stevo
It could be the bottom bolts on your shocks.. They dont tighten properly when you have the car jacked up.
What I did was jack the car up, sit the wheels on a brick (do this so you can get under it, and it keep the weight of the car on the shock bolts), then tighten up the bottom bolts for the shocks.
Steve
Heritage Green EL Ghia
Black AUII XR8 Ute
Stevo is offline   Reply With Quote Multi-Quote with this Post
Old 14-08-2005, 09:40 PM   #10
henz79
I Retighten all the bolts, that solve the other anoying sound. THEN i desided to bounce on the car at the rear and sound something is hitting the body or something. Jack the car up, there's a new rubbing marks on the end bolts or the stapiliser bar. But the shouldent be it , it maybe the tailpipe its a loud uncomfordable knock ...... Its really annnnoying...........
Old 14-08-2005, 09:45 PM   #11
fairmont1998
fairmont1998's Avatar
Welcome to the world of lowered cars! I had to have my tailpipe modified when I lowered the Fairmont.
Current Rides:
2012 KK Jeep Cherokee Limited CRD - Still going strong
2019 MG ZS Essence
1988 RD Mitsubishi Colt GL - 59kW of Fury
2022 Kia Stinger GT
fairmont1998 is offline   Reply With Quote Multi-Quote with this Post
Old 14-08-2005, 09:47 PM   #12
LUXO_8
windsor user
yep, that one definatley sounds like exhaust..
Old 14-08-2005, 10:18 PM   #13
BoZZa17
Lovin the Manual.
BoZZa17's Avatar
yeah i got a knocking sound after i lowered it
still there
but as the engine isnt working yet no point in fixing the knocking sound! lol
BoZZa17 is offline   Reply With Quote Multi-Quote with this Post
Old 14-08-2005, 11:11 PM   #14
hornet
hornet's Avatar
I'd say its either the exhaust on the diff or sway bar, or its your bottom bolts on the shocks.
I had this problem repeately, untill i learned that I had to tighten the bottom shock bolts with the car on the ground and not on the jack.
5 Speed EL Futura
140rwkw last dyno
hornet is offline   Reply With Quote Multi-Quote with this Post
Old 14-08-2005, 11:20 PM   #15
sphell
sphell's Avatar
if it's the exhaust hitting the diff, get a big rubber exhaust mount (the round ones) and some metal cable ties and tie it to the axle where the exhaust hits. Presto, no more knocking sound.
Old 14-08-2005, 11:22 PM   #16
oneredED
need more boost
oneredED's Avatar
I had a knocking sound in mine when it was superlow at the rear. I found that when i replaced the shocks, the sound went away, and then came back once the new shocks became buggered again after about a month. Anyone got other suggestions other than exhaust? (I torqued mine up on the ground as said in the workshop manual)
'94 ED Falcon GLi
Suspended by: kings, koni, pedders
Rolls on: 17" AJR Director's
Stops due to: bendix, DBA
Shifter connected to: T5 manual
Power from: ???
Interior: velour and woodgrain
Cost: stuff all :P
oneredED is offline   Reply With Quote Multi-Quote with this Post
Old 14-08-2005, 11:30 PM   #17
Stevo
Jared, it probably dosnt help that your car is super super super super low ?
Checked that its not ur seat rubbing on the road ?
Black AUII XR8 Ute
Old 15-08-2005, 12:08 PM   #18
TURBO_GHIA
hmmm boost
TURBO_GHIA's Avatar
i had knocking sound when i lowered my old EB it was the bottom bolts on the rear shocks so try that
EL TURBO GHIA
GT3582R
WOLF3D
TUNED BY JEM
TURBO_GHIA is offline   Reply With Quote Multi-Quote with this Post
Old 15-08-2005, 01:25 PM   #19
-jjM-
-jjM-'s Avatar
iv still got my knockin noise in the back, right hand, very sure its the shock, when chucked in the new springs, i chucked in new shocks for it too, noise is there, it makes noise whenn ever goin over bumps n potholes n other crap on the road, someone was tellin me grab the shaft of the shock wit sum multigrips and twist it around, nyone heard this before?
-jjM- is offline   Reply With Quote Multi-Quote with this Post
Old 15-08-2005, 01:46 PM   #20
Zedjay
Zedjay's Avatar
have you checked all the bushes????
Zedjay is offline   Reply With Quote Multi-Quote with this Post
Old 15-08-2005, 02:02 PM   #21
steven95falc
Originally Posted by henz79
Hi mates,
:SaiyanSmi
hey champ had similar problem check the shocks if they are the old ones they may be toping out or the bump stops around the shaft are stuffed either of the two or if there new shocks check they have the bump stops round the shocker shaft
steven95falc is offline   Reply With Quote Multi-Quote with this Post
Old 15-08-2005, 04:21 PM   #22
CruizinEB
Probly the exhaust
CruizinEB is offline   Reply With Quote Multi-Quote with this Post
Old 15-08-2005, 05:52 PM   #23
henz79
THANKS everyone, I follow all your advises and it works. I didnt jack the car up i just stick my fat heat and long arms down there and retighten the back lower shockc bolts and it works. So my car is not that low.
THANKS HEAPS........................
Old 15-08-2005, 09:39 PM   #24
hornet
hornet's Avatar
Glad to see it worked. That noise drove me insane for months. After removing and reinstalling my shocks, it went away for a couple of days then came back. Once i learned about tightening them on the ground, problem solvered.
5 Speed EL Futura
140rwkw last dyno
Old 16-08-2005, 09:27 AM   #25
Kenaz
Kenaz's Avatar
I never knew about this tightening the shocks on the grond business. Might have to give it a go and see if it fixes the knocking sound coming from mine.
02 BA XR6 T U R B O
Venom Red, Auto 13.97 @ 101mph
Originally Posted by Wheels Nov 02
It's suave, more subtle, and yet no less stirring. In fact, the boosted Ford is more polished than any big sedan Australia has ever produced. It's just so damn good, it makes the SS feel crude... Ignore the WRX. Forget the E49. Falcon XR6 Turbo is king.
Kenaz is offline   Reply With Quote Multi-Quote with this Post
Old 16-08-2005, 10:11 AM   #26
gozza
gozza's Avatar
i got s'low king springs all round with monroe gt's
no problems or knocking except for the front wheel guard which i pushed back into place
gozza is offline   Reply With Quote Multi-Quote with this Post
Old 23-04-2012, 10:58 AM   #27
toothless
toothless's Avatar
Default Re: Knocking sound after my lowering job
I know its a old thread but its the exhaust hitting the diff's control arms because i have this issue aswell and you just learn to live with it even though i have new exhaust mounts on
phat ltd in the making very lowly
toothless is offline   Reply With Quote Multi-Quote with this Post
