Old 04-12-2019, 12:02 PM   #1
Default Q: Kia Diesel Interchanges
Got an 04 Pregio van that’s almost too good to weigh in. Needs shackle bushes, a friction disc and a screen. Nil rust, 300-odd K of mostly freeway use.
Oh, and no engine. That went into a K2700 truck.
I can’t find a motor at sane prices, or at least a crank and maybe a rod. (Crank is cracked, rod damaged where its bearing spun). Crank doesn’t interchange with the smaller Mazda diesels I believe inspired the J2 motor.
Without being silly, any suggestions of motors that either bolt up to the J2 pattern bellhousings or a readily adapted swap? The aim would be to keep it tractable and suited to design function.
Cheers for any thoughts on how this might be achieved practically and thriftily.
Old 04-12-2019, 03:00 PM   #2
GasoLane
Former BTIKD
GasoLane's Avatar
Default Re: Q: Kia Diesel Interchanges
It's a long shot but you might try Dellows in Revesby, they've been making bellhousings for all types of conversions for years.
https://dellowconversions.com.au/
Old 04-12-2019, 03:17 PM   #3
That would be a fallback position, I’m hoping to hear there is a coincidental Asian diesel swap, eg a Hino crank drops into the Kia block or a Dyna motor bolts straight up.
Have a blighted 4M40 to hand (bored and new slugs but oil pressure issues), an FG Barra (way too big), had considered an Ecotec swap but still a lot of hassle.
Old 04-12-2019, 04:39 PM   #4
Vesper Martini
Vesper Martini's Avatar
2nd hand engines seem to demand ridiculous prices here.
it was a long time ago but I knew a place in Otahuhu, Auckland where you could get a used Jap engine for $150-500.
surely you could get one send from Asia for SFA with a bit of digging try Alibaba
______________________________
2015 Territory Titanium RWD Diesel - SOLD
2016 BMW X5 xdrive 30D Msport
Seadoo Challenger 210SE 310HP
Vesper Martini is offline   Reply With Quote Multi-Quote with this Post
Old 04-12-2019, 04:39 PM   #5
Vesper Martini
I think this is the place, but as I said a long time ago.
http://www.japanesespares.co.nz/contact.html
Old 04-12-2019, 06:05 PM   #6
roKWiz
Cabover nut
roKWiz's Avatar
Some of the bigger Kia Asia used (and still do) the Mazda T3500 3.5 SL diesel same as the Ford Trader 0409.
Some even used the later Mazda T4000 TM 4.0. That should get it going down the superslab.
Old 04-12-2019, 06:12 PM   #7
The T3500 bellhousing bolt pattern looks very similar!
Old 04-12-2019, 06:17 PM   #8
roKWiz
Cabover nut
roKWiz's Avatar
A few of the new Kia have 3.8 as well.
I found I could buy new parts for my diesels from Perkins, Mazda, Ford, and Kia.
3.5SL is basically a Perkins made under licence by Mazda. So look at those bellhousing's also
Wreckers in Berkeley Vale (might have moved to Tuggerah now) Japtrucks, not to be confused with the one in Qld.
Old 04-12-2019, 07:19 PM   #9
CyberWasp
CyberWasp's Avatar
You can buy a whole shipping container of them.
https://www.alibaba.com/product-deta...6e19213fixoV0U
2004 Mercury Silver Falcon XR6T - 5 Speed
2017 Platinum White Mustang GT - 6 Speed
2022 Blue Thai-Special for Daily Duties - Auto
CyberWasp is offline   Reply With Quote Multi-Quote with this Post
Old 05-12-2019, 05:54 PM   #10
dunga
That 4 litre Mazda motor was a kia motor the parts were interchangeable I think so the 3.5litre would be the same bell housing pattern.
dunga is offline   Reply With Quote Multi-Quote with this Post
Old 05-12-2019, 08:31 PM   #11
ozpacman
That T3500/4000 is a pretty big lump of an engine. I doubt it would fit in the engine bay of the Pregio, but I guess anything's possible.
ozpacman is offline   Reply With Quote Multi-Quote with this Post
Old 05-12-2019, 09:07 PM   #12
Fair call. I will need to find some nose-to-bellhousing flange measurements for comparison. There's a little bounce in the height available.
Old 05-12-2019, 11:25 PM   #13
hayseed
Are you going to register It..???
https://www.rms.nsw.gov.au/documents...ifications.pdf
hayseed is offline   Reply With Quote Multi-Quote with this Post
Old 05-12-2019, 11:36 PM   #14
Yes. I’m aware of the potential issues with permissibility of some swaps and have no intention of putting anything on the road that is not “...suitable for subsequent resale to a person of average driving ability” as the code says in multiple places.
Old 06-12-2019, 01:11 PM   #15
Vesper Martini
Whats an 04 Pregio worth?
Old 06-12-2019, 06:23 PM   #16
ozpacman
Mate I just happen to have an old T3500 bus sitting down in my shed. Would you like me to try and get some approximate measurements for you over the weekend?
Old 06-12-2019, 07:04 PM   #17
If it doesn’t risk a blue with the resident wildlife (snakes, spiders whatever) and won’t injure you - yes please. Ideal things to know are harmonic front or crank nose to machined mating face at rear of block, approx width between motor mount pad spotfacings, crank CL to top of rocker cover.
Bevsta - the question is more how much might a durable and simple diesel van cost a pensioner who does the odd lawn or gardening job. Hiaces etc are going to be dearer for equivalent condition.
Old 06-12-2019, 09:34 PM   #18
roKWiz
Cabover nut
roKWiz's Avatar
Just measured the 3.5SL in the 0409.
And what I remember in sizing up a Cummins 4BT about the same size. Ask me why I know this.
CL crankshaft front of timing cover to machined face at bellhousing 530mm
CL crankshaft (bottom of block) to top of air breather pipe outlet 480mm
centre to centre engine mounts surfaces 450mm
engine overall including fan from bellhousing face 700mm
my diesels harmonic balancer excepts double pulley belts depth of 70mm
As others have said its a large lump of engine.
Have you contacted SMS diesel parts of Lidcombe or Engines Australia who stock Perkins/Mazda diesels.
Old 07-12-2019, 10:34 PM   #19
That is massive!
I'll have to check the Kia block in the coming week. Have been off crook a few days (flu, then tweaked back).
Old 09-12-2019, 08:39 AM   #20
roKWiz
Cabover nut
roKWiz's Avatar
Get the Sawzall out.
Old 09-12-2019, 09:01 AM   #21
My back isn’t that bad!
Old 09-12-2019, 09:05 AM   #22
roKWiz
Cabover nut
roKWiz's Avatar
It will be. Did you try SMS for the little Kia parts needed.
Old 09-12-2021, 10:06 AM   #23
…Two years later, here we are and it’s Stuffed Diesel Time again. I think a Stihl battery hedger might be slightly more durable.
I am at the point where I think a transplant of something everyday and petrol, would be smarter. Seemingly, my mate is not dedicated to looking after a diesel and my part time colleague not keen on fixing this one properly.
What about an Ecotec swap?
Old 09-12-2021, 10:46 AM   #24
prktkljokr
praek tih kl jo kr
prktkljokr's Avatar
Had a mate fit a VN Commodore V6 and Auto to a K2700 ute years back, used to chuck wicked skids
prktkljokr is offline   Reply With Quote Multi-Quote with this Post
Old 09-12-2021, 12:23 PM   #25
Vesper Martini
For the same Pregio? what did you end up fitting, couldn't see above
Old 09-12-2021, 12:30 PM   #26
Vesper Martini
V12 LS swap?
https://youtu.be/-kMeztwjou4
didn't know such an engine existed..
Old 09-12-2021, 12:41 PM   #27
It’s not a Preggo, that was the last donor. Then he cracked the head on that motor twelve months ago, so the head from the cracked crank motor went on. It’s getting silly, patching up the same driveline every year.
Old 09-12-2021, 03:18 PM   #28
hayseed
Sounds Like the Pregio is well truly Fu..... Pregnant...
Time to Throw It away & get another Van.. IMHO
Old 10-12-2021, 05:56 AM   #29
It’s not a van. That was the last engine donor.
Old 10-12-2021, 06:11 AM   #30
Franco Cozzo
Franco Cozzo's Avatar
Those Kia K series trucks and Preggio vans are such ****boxes, every time you see one it's belching out blue smoke doing 60 in a 100 zone.
