01-01-2020, 05:09 PM | #1 | ||
This was mentioned in another thread, so I had a dig. Apologies if there was already a thread on it.
https://www.roadandtrack.com/new-car...details-specs/ First response, was "the madmen, don't they know we live in a time of coming electric cars and how dare they?!" But it was explained as such: "In vehicles with 14,000-plus-pound GVWRs—like the Ford Super Duty—Beltramo told us its critical for an engine to operate at peak power with an optimal air-fuel ratio (stoichiometric combustion). From there, Ford worked backwards. "We built a map of where an engine, can run stoichiometric air-fuel without a bunch of spark retard," Beltramo said. "That led us to a torque-per-liter value and a power-per-liter value, [which] knowing that, boxed us to 7.3 liters." For fuel efficiency's sake, Ford engineers determined they wanted the engine to generate peak power at what Beltramo considers "relatively low" RPM. "That's what led us to a pushrod two-valve. It really is the optimum solution for the over 14,000-pound [segment]." " Nice - creating the engine using deductive logic for who requires it, how they use it, and how to optimise it. Nicer still they ended up with a massive petrol V8!
I6 + AWD |
01-01-2020, 05:19 PM | #2 | ||
I know motorhome enthusiasts are excited about the new F59 chassis that this engine is being used in. The current 6.8 V10 petrol is one of the most popular engines in motorbikes in the US. This should be faster, more efficient and quieter
01-01-2020, 08:07 PM | #4 | ||
I've since learned that it is a smaller size than what it's replacing, is built for durability and inexpensive maintenance; is made to be able to be rebuilt; and is built in Windsor, Ontario. That's some really happy news! Sounds very old school and utilitarian, with modern improvements built in.
Here's an in-depth view of it done by hotrod.com: https://www.hotrod.com/articles/insi...3l-pushrod-v8/
I6 + AWD |
01-01-2020, 08:28 PM | #5 | |||
Deck height is said to be 9.77" which is also higher than the 6.2 Boss (9.4") |
01-01-2020, 09:43 PM | #6 | ||
01-01-2020, 09:57 PM | #7 | |||
yes still (as money n time permit) doing the rebuilding the zh fairlane with a clevo 400m 4v heads injected whipple blown with aode 4 speed trans to a 9" ....... we'll get there eventually just remember don't be afraid to try something new. Remember, amateurs built the Ark...Professionals built the Titanic! I have taken up meditation... at least it's better than sitting around doing nothing !! |
01-01-2020, 11:49 PM | #8 | |||
Peter Car
The front mounted tb is kinda high looking and would most likely need a reverse cowl bonnet though. Or a hole cut in it for clearance. |
02-01-2020, 03:48 AM | #9 | |||
These big blocks have so much power and torque down low to move big loads with authority, but we are used to comparing engines in terms of peak horsepower, we often think they are underpowered. I rented a UHaul F650 with the V10 to move last year, and I had no issues maintaining 75mph (its governed limit), even though it was fully loaded with all our crap, while pulling our Sonata behind it. I have fallen in love with big blocks so much, I picked up a 2001 GMC Sierra with the 8.1 Vortec V8 with the 5 speed Allison. They seem to make for a better daily driver than the big diesels. |
02-01-2020, 10:11 AM | #10 | ||
It's kinda like a modern take on the FE engine but with a lower deck height
and I can imagine that the 7.3 will fit into most Mustangs and Falcons if it has a low profile manifold. This engine has so much potential in terms of re-powering older vehicles, who would have thought that Ford would produce a 21st century big block. |
02-01-2020, 10:24 AM | #11 | ||
Every now and then they come out and surprise you with just how great a motor company they are. 445 Windsor... haha!
All we need now is for the head of Ferrari to insult the head of Ford and these babys will take out Lemans...
I6 + AWD |
02-01-2020, 10:32 AM | #12 | ||
Just tell Bill Ford he's not Henry Ford, he's not even Henry Ford the second.
4 users like this post: |
02-01-2020, 10:44 AM | #13 | ||
Ouch! Them's fighting words!
I was always a big Henry fan, really liked how Henry Ford II was played in the movie as well.
I6 + AWD |
02-01-2020, 11:34 AM | #14 | |||
Peter Car
3 users like this post: |
02-01-2020, 01:30 PM | #15 | ||
My understanding that this motor has been designed for heavy duty, low rpm work - trucks, etc., and therefore will probably have large diameter bearings to handle the load. Large diameter bearings are not good for high revs due to the higher surface speed. Probably many other design features that will make this engine unsuitable for performance applications.
02-01-2020, 01:42 PM | #16 | |||
02-01-2020, 02:34 PM | #17 | ||
How heavy is the engine?
02-01-2020, 03:23 PM | #18 | |||
For a lot of people that will make more sense to just get a 7.3 and skip the Mods and Coyotes. |
02-01-2020, 03:55 PM | #19 | ||||
02-01-2020, 04:24 PM | #20 | ||
Sounds like it's a great time to have an oldskool Ford project on the go.
02-01-2020, 04:25 PM | #21 | |||
3..2..1..
I know yanks like their bikes to handle like boats but a 6.8 v10 would be ludicrous. Sent from my iPhone using Tapatalk |
02-01-2020, 04:28 PM | #22 | |||
Cabover nut
Sounds like putting a 466 Louisville gasser in your car.
02-01-2020, 04:38 PM | #23 | |||
It’s actually physically smaller than a 429, a bit like a low deck FE. The project lead engineer was a devout drag racer who knew how to create an engine with a soul. So yeah, nothing like a 534 Super Duty gasoline engine. |
02-01-2020, 10:52 PM | #24 | |||
Peter Car
The beauty of building it for strength means it will handle reasonable rpm cause it will have a strong crank and rods. Plus it has forged pistons. |
03-01-2020, 01:17 AM | #25 | ||
I think I found the weight, apparently it's not much heavier than the 6.2. If so it's around 265kg, or a little heavier than the old 5.4 we had in the Falcon.
03-01-2020, 07:35 AM | #26 | ||
03-01-2020, 10:15 AM | #27 | ||
03-01-2020, 10:41 AM | #28 | ||
that's pretty crazy Franco, for eg the Sprint Windsor motor from the same era as your 304 has peak torque at 4000 and peak power at 5000 with a 5500 redline. Doesn't sound like much, but compared to driving any of the low-down torque 165kw Windsors fitted to the Fairmont, S-XR8 of that era, even through to AU1 XR8s - the Sprint motor feels like a completely different animal. Total beast over 3000 revs when it wakes up through to redline. All from the same block and cylinder dimensions. People will get outrageous with this one, give it time.
(Actually I'd like to see an EB with the 7.3 and some performance mods...)
I6 + AWD |
03-01-2020, 10:55 AM | #29 | ||
Looks like the 7.3 is only slightly bigger than the GM LS, modders are gonna love that.
03-01-2020, 11:31 AM | #30 | |||
Peter Car
