Old 15-02-2009, 11:38 AM   #1
Teknoslasher
Travis - 1999 Ford AU S1
Teknoslasher's Avatar
Default Series 1 Clock Fitting?
I bought a Clock from a Series 1 Futura for my Series 1 Forte, I was just wondering, do they have the wiring and the connector already in them as I can't seem to find it. If not, does anyone know how to put them in?
Teknoslasher is offline   Reply With Quote Multi-Quote with this Post
Old 17-02-2009, 01:19 PM   #2
LOWAU
___________
LOWAU's Avatar
I too would like to know, I have a clock but not sure on how to connect it.
LOWAU is offline   Reply With Quote Multi-Quote with this Post
Old 22-02-2009, 11:00 AM   #3
Teknoslasher
Still not having much luck.
Old 30-03-2009, 11:19 PM   #4
Rozwell28
Lurker
Man I wish someone would answer this one. I wanna know too.
Rozwell28 is offline   Reply With Quote Multi-Quote with this Post
Old 31-05-2009, 11:59 AM   #5
bodes-sh
ok, for anyone till wondering on this, i have done it.
it's only a month old, lol
anyway....i'm assuming you all know how to get the dash facia off? if not, you need to remove the head unit and the ash tray. there are 2 screws in behind where the ashtray sits, and one off to each side of where the head unit sits. undo all these and simply pull it away from the dash (it won't go far because the heater controls will stop it).
remove the falcon badge from the top of the dash and place the clock in the opening. screw the clock to the mounting brackets on the back of the facia. the wiring is as follows, i didn't use an actual plug, just small crimping terminals with electrical tape over the ends so they don't short out onto each other. you could also use heatshrink. for power, i tapped into the radio loom, you will have to check the wires if you have a stock head unit, as mine is aftermarket i tapped into the bridging loom between the 2 plugs.
as for the clock this is the diagram:
i'm pretty sure the dimming input is that one, but just check it. turn the parkers on and see if it dims, if it's not that one, it will be the one below it. acc power has to be those 2 terminals, otherwise you won't get any display out of the clock. as for the wiring, all power wires are available from the stereo loom, dash dimming included.
off:
(image 177)
just on acc:
with lights on:
image179 missing
(sorry for the really crap quality, you can just make out the difference. i also think there are pins for a light for the buttons, but i'm not sure which ones they are. and the series 2/3 haven't got them anyway, so...)
anyway, that's my quick write up on installing a clock into an au1. i think mine was out of an xr6, not that that should make any difference...
good luck guys, hope this helps
Old 14-11-2017, 07:51 PM   #6
cbrennan83
Default Re: Series 1 Clock Fitting?
any chance we can update the photo i can only see photo bucket seems to be happening alot
cbrennan83 is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2017, 10:21 PM   #7
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
updated bar one.
UK
